Lift points for XP1000 - Polaris RZR Forum - RZR Forums.net
post #1 of 4 Old May 26th, 2018, 08:35 PM Thread Starter
Matthew Brown's Avatar
First Name: Matt
My RZR: XP 1000 EPS
Member #254625
View Matthew Brown's Photo Gallery(0)
Usa Lift points for XP1000
Hi all - I have a 2 post lift in my shop. Wondering if the lift points I've picked are reasonable. Sure appreciate any advice you can give! I'm using the diagonal frame bar that goes from the central front to the side frame - the parts catalog calls is the WELD-MAINFRAME,FRT,SWAY for my front lift point. I'm lifting in the rear on the trailing arm. I've attached some pictures. Thanks for any advice you can send my way!
ID:	550233   Click image for larger version
Matthew Brown is offline
post #2 of 4 Old May 27th, 2018, 08:18 AM
Abner
Abner's Avatar
First Name: Brian
My RZR: Xp1k
Member #218393
View Abner's Photo Gallery(0)
Re: Lift points for XP1000
I use the same spot in front however I put the large spacers on rear and catch frame in rear as well to allow suspension to unload at all four corners. Lifting from the trailing arm will allow the rzr to shift or move while you are working on your rig. That can be a bad idea.
Abner is offline
post #3 of 4 Old May 27th, 2018, 10:12 AM
Smlarkin's Avatar
Member #167313
View Smlarkin's Photo Gallery(0)
This is what I do too never any issues. Depending on what Iím doing I will use a tall frame stand on the front or rear just to keep it from rocking if your doing a lot of wrenching.
Smlarkin is offline
post #4 of 4 Old May 29th, 2018, 02:24 PM Thread Starter
First Name: Matt
My RZR: XP 1000 EPS
Member #254625
Thanks all!
Tags
lift point
HL 3-5" Signature Lift AllenAyres RZR XP 1000 High Lifter Edition 3 May 20th, 2017 11:40 AM
Highlifter only offers a 1" lift for our Trails now? Koko RZR 900 - 50'' Trail Models 17 February 3rd, 2017 06:34 AM
Installed an RT Pro 2" lift UGH.......... Rrudzi RZR 900 - 50'' Trail Models 10 November 9th, 2016 08:29 PM
3" lift or not 3" lift - that is the question Champ RZR S 900 14 August 19th, 2016 08:39 AM
Running with just rear lift? Katnapper RZR 570 Specific Discussion 3 December 13th, 2015 10:49 PM
