Tubing bender - Polaris RZR Forum - RZR Forums.net
post #1 of 14 Old March 20th, 2018, 08:27 AM Thread Starter
Mathew6254's Avatar
Member #231145
View Mathew6254's Photo Gallery(0)
Tubing bender
Looking at jd2 model 3 for 1.5 inch tubing. What are you using?
Mathew6254 is offline
post #2 of 14 Old March 20th, 2018, 11:47 PM
SNWMBL's Avatar
First Name: Caleb
Member #207521
Re: Tubing bender
I would get the model 32, the extra features are worth the price difference.
I have a model 32 and it works great. You can get the machined air/hydraulic ram mount from Swag Off-road for $180 SWAG Machined Tubing Bender Air/Hydraulic Ram Mount
And the 8 ton ram from Harbor Freight for $90. https://m.harborfreight.com/8-ton-lo...nt-_p_117.html
About the cheapest route you can go for an air/hydraulic conversion. If you can swing the money it’s worth it. The bender doesn’t need to be bolted to the floor since the ram is doing the work and you can watch the degree indicator and bump it with the air for fine increments. It’s much easier then manually bending bigger tube. Even manually bending 1” x .058 4130 takes some work.
Regardless, you will love it and look for excuses to bend tube.
2017 RZR XP4 1000
Alaska UTV Fab LLC
Instagram: alaska_utv_fab
FOR SALE
- Hunterworks secondary rollers, set of 2, $35 shipped
- Sinister Fabrication A pillar bungs, set of 2, $45 shipped
SNWMBL is offline
post #3 of 14 Old March 21st, 2018, 05:20 AM Thread Starter
Mathew6254's Avatar
Member #231145
What are the advantages of the 32 over the 3 I see the heavier metal and pins, anything else?
post #4 of 14 Old March 21st, 2018, 09:01 AM
SNWMBL's Avatar
First Name: Caleb
Member #207521
Re: Tubing bender
The anti-spring back arm is the biggest one.
2017 RZR XP4 1000
Alaska UTV Fab LLC
FOR SALE
SNWMBL is offline
post #5 of 14 Old March 21st, 2018, 12:19 PM
Mtrent3450's Avatar
Member #86174
View Mtrent3450's Photo Gallery(0)
Re: Tubing bender
Air/hydraulic conversion is a must. You can make your own brackets but it’s a pain in the ass. For $180 it’s worth every penny.
Mtrent3450 is offline
post #6 of 14 Old March 21st, 2018, 03:27 PM Thread Starter
Mathew6254's Avatar
Member #231145
I think I will just do the manual for now and add the Hyd later. What radius die do you recommend for cage work 1.5?
post #7 of 14 Old March 21st, 2018, 03:28 PM Thread Starter
Mathew6254's Avatar
Member #231145
Is the anti springback bar the second ratch bar?
post #8 of 14 Old March 21st, 2018, 03:40 PM
SNWMBL's Avatar
First Name: Caleb
Member #207521
Re: Tubing bender
Yes it is. Id get the smallest radius die that will work with the wall thickness youre using.
2017 RZR XP4 1000
Alaska UTV Fab LLC
FOR SALE
SNWMBL is offline
post #9 of 14 Old March 21st, 2018, 04:34 PM Thread Starter
Mathew6254's Avatar
Member #231145
I am wanting to build a rear seat cage in the bed for carrying the kids around the farm and mild trail riding. What size / thickness tubing would you recommend.
post #10 of 14 Old March 21st, 2018, 04:40 PM Thread Starter
Mathew6254's Avatar
Member #231145
Had 1.5 .120 dom in mind but might be overkill.
post #11 of 14 Old March 21st, 2018, 11:13 PM
speediburns's Avatar
Member #85344
View speediburns's Photo Gallery(0)
Re: Tubing bender
My first bender was a manual Pro-Tools 105 I think. I figured I was young, not in a hurry, and not making many cages so manual would be fine. Later I bought a hydraulic JD2 and realized the difference. It isnt just about the work of bending....which is a lot of work. It is the versatility and setup differences. A hydraulic bender can be mounted on wheels, rotated to fit long or odd shapes in your shop, rolled outside the shop on nice days, and even attached to a tube that is on the vehicle (I did this once and it wasnt easy, but wouldnt be possible with a manual bender).
I now have a Pro-Tools 302. I like it, but think I would actually prefer a hydraulic 105.
I have owned 2 pro-tools and one JD2. IMHO, the pro-tools is a better product. I also have several different SWAG tools and they all work perfectly. SWAG is probably my favorite fabrication tool company to buy from because they are real.
1.75"x.095 You will get more use out of 1.75 dies, and more interest when you sell it to buy a hydraulic bender.
speediburns is offline
post #12 of 14 Old March 24th, 2018, 08:05 AM Thread Starter
Mathew6254's Avatar
Member #231145
https://www.speedwaymotors.com/3rd-G...-Set,6614.html
What you think? 7 inch radius handles up to 2 Up to .96
post #13 of 14 Old March 26th, 2018, 04:06 PM
Member #85344
Re: Tubing bender
Pros and cons.
Price is right. Hydraulic and self contained make it easy to move around and work with large pieces of tubing.
Fixed 7" radius is not ideal. For 2" and 1.75 that is fine. You probably wont want 7" bends on your 1" tubes though. The red stock car type chassis in that video does not have 7" bends on the 1" tube around the front end.
At that price you can use it a few times and sell it on CL to just about break even. Go for it.
post #14 of 14 Old March 26th, 2018, 05:41 PM
joemamma's Avatar
First Name: doug
My RZR: 2-2008's, 2012 900xp, 2014 ace
Member #49733
Feedback Score: 6 reviews
View joemamma's Photo Gallery(5)
Re: Tubing bender
https://www.roguefab.com/product-cat...ubing-benders/
excellent bender
2008 rzr turbo,satv +6 suspension, 2008 rzr satv+5 with 2" lift,2012 900xp aerocharged aem ecu satv suspension,2014 ace,2003 honda rincon satv front discs
joemamma is offline
Tubing bender Mathew6254 Custom RZR Buggies and Builds 6 August 28th, 2018 02:04 PM
Tubing source Buffalobillcody Shop, Tools and Fabrication 2 August 30th, 2017 01:47 PM
Polaris rock rail tubing wall thickness? Draggermirage RZR XP 1000 4 November 19th, 2016 10:12 AM
best priced bender? joemamma Shop, Tools and Fabrication 12 June 1st, 2016 07:07 PM
Tubing software oldmanmiller Projects and How-To 2 January 27th, 2016 01:01 AM
