400 ton press - Polaris RZR Forum - RZR Forums.net
post #1 of 16 Old October 19th, 2013, 08:55 AM Thread Starter
Bent's Avatar
First Name: Kevin
My RZR: XP900
Member #37740
View Bent's Photo Gallery(0)
400 ton press
Hey guys, I figured I would show off my latest creation.
This press is my own design and I wanted it to be versatile, so I decided to add a brake attachment for metal forming.
I want to cut out some custom aluminum roofs for some buddies rzr's and I like the clean look of bent seams, so I fabbed up this unit.
I made the cylinders out of tubing with a 12 3/4" ID and a 3/4" wall thickness. The top, bottom and plunger plates are 2" thick. The rams are 4" 4140.
If I run the pump at 4000 psi, she would be a 540 ton press but I don't think I will ever need to...
Bent...
Bent is offline
post #2 of 16 Old October 19th, 2013, 09:11 AM
dmax61's Avatar
First Name: Tom
My RZR: 2010 RZR-S White
Member #10609
View dmax61's Photo Gallery(0)
Re: 400 ton press
Impressive!!
Nice work
dmax61 is offline
post #3 of 16 Old October 22nd, 2013, 07:40 AM
Eric Carroll's Avatar
First Name: Eric
My RZR: 09' S & 11' xp900
Member #7305
View Eric Carroll's Photo Gallery(0)
Re: 400 ton press
Nice job! Where did you get the cylinders? I have a project like this that Ive been saving some heavy channel and i-beam for.
Eric Carroll is offline
post #4 of 16 Old October 22nd, 2013, 02:47 PM Thread Starter
Bent's Avatar
First Name: Kevin
My RZR: XP900
Member #37740
Re: 400 ton press
Thanks dmax61, I am pleased with it.
Bent...
Bent is offline
post #5 of 16 Old October 22nd, 2013, 04:06 PM
domestictuner's Avatar
Member #21859
View domestictuner's Photo Gallery(23)
Re: 400 ton press
i dunno, i hope it's enough for those roofs...
domestictuner is offline
post #6 of 16 Old October 22nd, 2013, 04:57 PM Thread Starter
Bent's Avatar
First Name: Kevin
My RZR: XP900
Member #37740
Re: 400 ton press
I hear ya...that 1/8" aluminum plate is tough $hit!
Time will tell
Bent...
Bent is offline
post #7 of 16 Old October 22nd, 2013, 05:54 PM
Olmoggy's Avatar
First Name: Brian
My RZR: 2013 rzr s 800LE
Member #59058
View Olmoggy's Photo Gallery(0)
Re: 400 ton press
bent that like it was butter
sent thru smoke signals directly out the top of my teepee!!!
Olmoggy is offline
post #8 of 16 Old December 12th, 2013, 10:55 AM Thread Starter
Bent's Avatar
First Name: Kevin
My RZR: XP900
Member #37740
Re: 400 ton press
I finally had some time to do up a roof, back window and front grill for a buddy's rzr S. He gave me artistic freedom, so I cut "Anita's Ride" into the back window, (thats his girlfriend), just to piss him off! He hasn't seen it yet
I had a 1/2 day to do this yesterday, so I never had a chance to get fancy. Maybe this spring I can add a few bells and whistles to it, so it doesn't look to plain.
But...The press works well!
ID:	90886   Click image for larger version
ID:	90887   Click image for larger version
ID:	90888   Click image for larger version
Bent...
Bent is offline
post #9 of 16 Old December 12th, 2013, 06:08 PM
dmax61's Avatar
First Name: Tom
Member #10609
Re: 400 ton press
Looks good
dmax61 is offline
post #10 of 16 Old September 27th, 2014, 10:12 PM
Trashpicker's Avatar
First Name: Trashpicker
My RZR: 2015 Titanium Matte LE 900S
Member #21858
View Trashpicker's Photo Gallery(11)
Nm Flag Re: 400 ton press
what's the white stuff all over it?
Trashpicker
"The Jokers Wild"
2015 Polaris RZR LE 900S Titanium Matte, Toys for Big Boys Cage,roof, rear spoiler and bumper, Pit bull tires, No limit wheels, Polaris full doors, PRP seats, rock sliders, skid/a arm plates, front bumper, door bags,5 point blue harness, Invision Artworks full wrap,Seizmik Pursuit Mirrors,Trailbright 30"curved LED light bar,double LED whips, WVOFFROAD 3" cubes,ipad GPS with Ram mount. Shock Therapy Stage 2 shocks.
Trashpicker is offline
post #11 of 16 Old September 27th, 2014, 10:53 PM Thread Starter
Bent's Avatar
First Name: Kevin
My RZR: XP900
Member #37740
Re: 400 ton press
Frozen precipitation in the form of white or translucent hexagonal ice crystals that fall in soft, white flakes. Sometimes referred to as Northern White low grit sand flakes
You "spoiled" New Mexicans should Put some studs on ur Harley tires and come up and try it out some time Eh!
P.S. Nice job on your roof build last year! One of the best I've seen...
Bent...
Bent is offline
post #12 of 16 Old September 28th, 2014, 07:30 AM
cc.canada's Avatar
First Name: Craig & Cindy
My RZR: 2012 Polaris RZR 800 EPS LE - Boardwalk Blue
Member #33835
View cc.canada's Photo Gallery(0)
Re: 400 ton press
Hello Bent nice press / break what thickness / gauge of steel is the body of the press made of and size of the Channels I have a friend in Calgary that will build one like yours for me
cc.canada is offline
post #13 of 16 Old September 28th, 2014, 08:29 AM Thread Starter
Bent's Avatar
First Name: Kevin
My RZR: XP900
Member #37740
Re: 400 ton press
Hey CC.Canada,
The channel is 10" but it is re-inforced internally. It's built out of QT100 plate steel. The pins are made of 4340. I built the hydraulic cylinders from A333 Sch. 80 12" pipe. The rams are 4340 as well. The plunger/gland, base and head of the cylinder are QT100 2" plate.
The rest is pretty straight forward...
Good luck.
Bent...
Bent is offline
post #14 of 16 Old September 28th, 2014, 08:46 AM
cc.canada's Avatar
Member #33835
Re: 400 ton press
Thank you
post #15 of 16 Old October 19th, 2014, 02:14 AM
Member #21858
Thanks Bent
It was probably the most photographed roof at the Taylor Park event in August.
Trashpicker
"The Jokers Wild"
Oil press question flyer05 Engine and Drivetrain 27 July 11th, 2012 07:02 PM
ROTR Press Release ROTR Rally on the Rocks 2 April 24th, 2012 08:58 AM
Press Release!! MTR Local Rides and Events 1 March 1st, 2012 12:57 PM
Some Good Press... jmattor General RZR Discussion 11 February 23rd, 2011 07:00 AM
