Anything Special Required Before Welding On Fraame - Polaris RZR Forum - RZR Forums.net
post #1 of 10 Old September 23rd, 2013, 06:58 AM Thread Starter
BENCH's Avatar
My RZR: 800
Member #58959
View BENCH's Photo Gallery(0)
I gouged my roll bar pretty bad, and going to TIG weld that area.
Aside from disconnecting the battery, do I need to do anything else?
Read somewhere to drain coolant to prevent elecstrolisis/corrosion in radiator and engine block. Sounds kinda out there, just asking.
TIA
Robert
BENCH is offline
post #2 of 10 Old September 23rd, 2013, 07:03 AM
Old but not slow
Rokitman's Avatar
First Name: Randy
My RZR: 2016 900 S
Member #47058
View Rokitman's Photo Gallery(0)
Re: Anything Special Required Before Welding On Fraame
I did quite a bit of MIG welding on my cage and had no adverse affects. Didn't even think to disconnect the battery.
New owner of a 900 S EPS. PRP harnesses, UTV Giant lower door inserts, SuperATV vinyl roof, DMC/Desertcraft pre filter system, Rugged Radio Moto Kit, Rocky Mtn ATV cage extender, Bandit Springs.
Rokitman is offline
post #3 of 10 Old September 23rd, 2013, 07:15 AM Thread Starter
BENCH's Avatar
My RZR: 800
Member #58959
Thanks. Just bouble checking .
Robert
BENCH is offline
post #4 of 10 Old September 23rd, 2013, 07:28 AM
8ball_99's Avatar
My RZR: 2013 Black RZR4 XP LE
Member #7209
View 8ball_99's Photo Gallery(0)
Your fine weld away.. If you clamp close to the weld I'd say you don't have to worry with the battery.. My father N law has been a welder for 30 some odd years.. He welds on trucks, equipment, ect all the time.. The way he explained is the current goes from the rod to the clamp.. As long as your not clamped on one end and welding on the other. Or your not welding up close to the battery your fine. I've never heard of draining antifreeze or any other thing like that.
Isn't is it a bit unnerving that doctors call what they do "practice"?
Why do we drive on the parkway and park in the driveway?
Problem with political Jokes is,, they get elected..
8ball_99 is offline
post #5 of 10 Old October 4th, 2013, 11:34 PM
Nick tha ****....
Nick_c's Avatar
First Name: Nick
My RZR: 900 xp
Member #54849
View Nick_c's Photo Gallery(0)
I tiged up my whole cage and I didn't do either.
Just make sure the metal is clean, inside and out side. Super clean.....
Also inverter driven welders require less amperage. So have fun.
NtD
Nick_c is offline
post #6 of 10 Old November 17th, 2015, 08:31 PM
Finman's Avatar
My RZR: 2015 900 S
Member #78899
View Finman's Photo Gallery(0)
X2...I've welded my 900s frame several times and just keep the ground real close to the weld. All is fine so far and I've never disconnected the battery.
Finman is offline
post #7 of 10 Old November 18th, 2015, 07:00 PM
Tjenus's Avatar
Member #86032
View Tjenus's Photo Gallery(0)
You should be fine. Over the years i have had a few bad experiences with hifreg tig welding on aluminum frames. But straight dc is prety safe. But some use the hifreg to start the arc in dc. But if it a totch to start or scratch start les of a problem. The new ecms unplug so easy i do it just to ease my mind. Thanks KH
Sent from my SM-G920V using Tapatalk
Tjenus is offline
post #8 of 10 Old November 19th, 2015, 12:39 AM
Fimea's Avatar
First Name: Rick
My RZR: 2015 XP1000, 2014 XP4K, 2011 XP900
Member #29192
View Fimea's Photo Gallery(0)
I agree that since he will be using DC Straight, and not AC - everything should be fine as long as you keep the ground on the cage. For piece of mind, I disconnect the battery.
2013 Ram 2500 & 3500 dually, diesel, crew cab
2002 Ford F-250 7.3L diesel, crew cab
2004 Wanderer Toyhauler
2015 RZR XP1000 Voodoo Blue
2014 XP4
2011 RZR XP900 LE White Lightning
2008 LTR450, 2004 YFZ450,2003 YFS200
Fimea is offline
post #9 of 10 Old November 19th, 2015, 05:20 AM
swingarm1's Avatar
First Name: Tim
Member #7690
Feedback Score: 176 reviews
Robert
Just remember the cage / roll bar is only .065 wall, it doesn't take much to blow a hole in that thin of tin...
swingarm1 is offline
post #10 of 10 Old November 23rd, 2015, 03:04 AM
Layvon's Avatar
My RZR: Subaru STi
Member #82294
View Layvon's Photo Gallery(0)
Whether you need to or not, to keep things safe as possible, I disconnected the ECU and battery. Total combined time is 3-5 minutes, so for me it is way worth the risk mitigation.
Layvon is offline
HELP! welding nate.920 General RZR Discussion 7 March 17th, 2013 11:12 AM
Frame welding? Jkl20 RZR 170 Specific Disccusion 0 April 17th, 2012 05:36 PM
Welding plastics? VirtualRider General RZR Discussion 23 December 6th, 2011 06:13 PM
Welding A-arms on RZR 4, or S RZR4RYAN General RZR Discussion 15 July 18th, 2010 07:15 PM
welding on my RZR.... GrayMitchell General RZR Discussion 6 October 26th, 2009 06:58 PM
