Having just picked this up last month I wanted to install 4pt harness's in it asap...
I ordered 4 pro armor 2" harness's figuring it would be an easy one and done install.
I believe I was wrong. The Pro Armor's come as 4 pt bolt in and in my 2012 4 seater they only have a bar behind the seats no mounting/brackets hole's like the newer models.
What has anyone else used? does anyone make a harness that is roll cage wrapped up top and bolt in on the bottom?
You should not need to weld anything. The bottom of the 4pt harness bolts to the seat bar.
The top of the 4pt harness wraps around the bar and goes through the buckle leaving it tightened.
On my Rzr 4 800 I used Dragonfire clamp on anchors just to keep the 4pt harness from spreading out wider. It keeps it on my shoulders better. If you go this route, the bar behind the front seats is 1.25" and the one behind the passenger seats is 1.5" https://www.dragonfireracing.com/product/3022/harness-anchor-kits-quick-release
See attached pictures for wrap around the grab bar, and the dragonfire clamp on.
You should need to weld anything. The bottom of the 4pt harness bolts to the seat bar.
Well I for sure don’t have that bracket, but am I understanding that the straps keep it tight and the bolt on part is to keep it tight? Sorry I’m just having a tough time grasping it.
Well thanks for the info guys, I took the day of to watch my sons who are both under 4...with their help we knocked out the fronts quickly and one rear is 50% done before they got too cold and i needed some more washers...
Related Threads
3.1M posts
141.5K members
Since 2007
