After a few hrs and breaking one of my dragon fire seat bezels I managed to get my click 6 harnesses installed. Have to take bezels outta the seat and do it all on the floor then connect the seat bezels together. PIA
You dont have to take the bezels out of the seat if you take the seat belt buckles apart with a torx security bit. 3-4 screws come out the buckles come apart, slide them through and reassemble. Quick install.
I wish I would have looked harder at the buckles. I took the rollers apart and ran the belts through from the front. Had to rewind and re-tension the belts, but it all worked our also. First one took a while, but the others went quick once I figured out the technique.
No need to take anything part. Just take the lap belt apart. It takes me about 30 second to take them apart and remove my seat. Cut the lap belts at a 45 angle and heat the ends so they won't fray. Cutting them at a 45 makes putting them back through the buckles easy.
