Belt change tool help - Polaris RZR Forum - RZR Forums.net
 8Likes
post #1 of 46 Old October 26th, 2019, 07:38 PM Thread Starter
Ryanbsimmcon's Avatar
First Name: Ryan
My RZR: 2019 rzr turbo xp2
Member #268984
View Ryanbsimmcon's Photo Gallery(0)
Please help. 2019 rzr turbo. These threads only go in about 3 turns. I tried vice grips on it but it's not going. What am I doing wrong?Attachment 586808
Ryanbsimmcon is online now
post #2 of 46 Old October 26th, 2019, 07:52 PM Thread Starter
First Name: Ryan
Member #268984
I have a lock n load stage 3 kit from Afyermarket Assassins and I can't even get my belt off. Boy am I in trouble. Haha!
post #3 of 46 Old October 26th, 2019, 07:54 PM
dartersracing's Avatar
First Name: DONNY
My RZR: 2014 PACE Z1 1000
Member #19554
Feedback Score: 15 reviews
Re: Belt change tool help
Did you try other hole?
sean.ostrand likes this.
209-373-5336 DONNY DARTER
dartersracing is offline
post #4 of 46 Old October 26th, 2019, 07:55 PM
First Name: DONNY
Member #19554
You can just remove bolt and then snap ring and belt will come off. Pay attention to order of washers.
post #5 of 46 Old October 26th, 2019, 07:55 PM Thread Starter
First Name: Ryan
Member #268984
Yes, both of them. Will not go with all my might
post #6 of 46 Old October 26th, 2019, 07:57 PM Thread Starter
First Name: Ryan
Member #268984
Oh ok. No snap ring on 19' though, I believe. So that's how I would remove on the trail or get a new cover from Polaris?
post #7 of 46 Old October 26th, 2019, 08:43 PM
olddog's Avatar
First Name: billy
My RZR: sold 2013 900 xp sold.......2017 turbo
Member #53180
View olddog's Photo Gallery(0)
mark each side with a magic marker as i believe the secondary unit is a balanced unit...but yes removing secondary bolt will work...once it is off i would run a tap into those 2 holes...
olddog is offline
post #8 of 46 Old October 26th, 2019, 08:54 PM
chuckscarstereo's Avatar
My RZR: 2016 XP4T
Member #80622
View chuckscarstereo's Photo Gallery(0)
You won't be able to get the belt back on without being able to spread the secondary. Use another bolt and see if it will thread into the clutch. If not then chase the threads in the clutch and the tool, or replace the tool... It looks like the threads at the end of the tool are a little jacked up.
Sent from my Pixel 3 using Tapatalk
chuckscarstereo is offline
post #9 of 46 Old October 27th, 2019, 07:55 AM Thread Starter
First Name: Ryan
Member #268984
Thanks guys. I have two of these tools, same issue. The threads are getting a little messed up because the threaded holes are just too small. Heading to the dealership today with the clutch cover to request a tool that works here. This should be interesting.
post #10 of 46 Old October 27th, 2019, 09:23 AM
Max H's Avatar
First Name: Max
My RZR: 2018 XPT 2 seat
Member #16311
View Max H's Photo Gallery(0)
This is not that uncommon ..It is probably the threads in the secondary
On one of the 2 ..2018 XPTs we have one of them had this same problem, the aluminum threads were not cleaned out and it needed to be tapped out
Once this was done on both holes no problem ...You will need that tool to do a proper belt change
I assume you have looked at the threads on the tool and they are ok?
Max H is offline
post #11 of 46 Old October 27th, 2019, 09:24 AM Thread Starter
First Name: Ryan
Member #268984
Yep both tools were brand new
post #12 of 46 Old October 27th, 2019, 09:45 AM
Max H's Avatar
First Name: Max
Member #16311
Just take the secondary outer sheave off and run the correct tap size thru the holes ...your problem will be solved....I can not remember what tap size it was but it was very common
Max H is offline
post #13 of 46 Old October 27th, 2019, 02:13 PM Thread Starter
First Name: Ryan
Member #268984
Well, it's confirmed by Bert's Mega Mall So Cal's largest sports craft dealership, the threads are wrong and need to be re-tapped. I bought this car from them a few months ago and they said there's nothing they can do for me. I need to buy and re-tap myself. They do not carry a 6x1.25 tap that they said is not common. Fortunately this didn't happen on the trail. It goes to show all the hype about learning how to change your belt in the driveway with a new car before you ride would be important for numerous reasons.
post #14 of 46 Old October 27th, 2019, 02:29 PM
Max H's Avatar
First Name: Max
Member #16311
1/4-20nc bolt will or tap will work fine ....that is what I used and it cleaned the threads perfectly
https://www.rzrforums.net/rzr-xp-tur...lt-change.html
RWB713 likes this.
Max H is offline
post #15 of 46 Old October 27th, 2019, 02:49 PM
Aspiring Perfectionist
RWB713's Avatar
First Name: Richard
My RZR: 2018 XP4 Turbo
Member #70552
1/4-20 bolt is what I carry for a belt tool, works perfect.
In reality, you can drill and tap those holes with whatever size suits your fancy, there’s no complex mechanism there, just threading through the outer half and pushing on the inner half
2018 XPT4 - Bailey
RWB713 is online now
