Rear wheel play - Polaris RZR Forum - RZR Forums.net
 3Likes
post #1 of 24 Old September 19th, 2019, 10:50 AM Thread Starter
RZRturbo1111's Avatar
Member #269144
View RZRturbo1111's Photo Gallery(0)
Rear wheel play
I have a 2017 polaris rzr xp turbo that I am getting some play in both rear wheels when I have the machine jacked up and grab each wheel at the 12 and 6 o'clock position. I have replaced both wheel bearings and even a heim joint. What else could be causing this play? Should I be concerned about it? Thanks in advance.
RZRturbo1111 is offline
post #2 of 24 Old September 19th, 2019, 11:44 AM
PaulK's Avatar
First Name: Paul
My RZR: 17 XP Turbo
Member #34432
View PaulK's Photo Gallery(2)
Re: Rear wheel play
look at the radius rod ends to see of they are moving,, stock rods are non serviceable and the ends do wear out
PaulK is offline
post #3 of 24 Old September 19th, 2019, 03:44 PM
Denver, CO - 303-400-0205
American Rock Rods's Avatar
First Name: Chris @ ARR
Member #25882
View American Rock Rods's Photo Gallery(0)
Re: Rear wheel play
Yep, check radius rods. Also, what did you torque the rear hub nut to?
Chris @ ARR
303-400-0205-shop #
We are Colorado's Premier UTV Parts/Accessory shop!
American Rock Rods is offline
post #4 of 24 Old September 19th, 2019, 04:57 PM Thread Starter
Member #269144
My upper rear radius rods are stock and my lowers are highlifter high clearance which are maybe a year old so it's probably the uppers is my guess. It's hard to tell exactly where the play is coming from though. And I currently don't have a tool that measures the torque in lbs of the hub nut but I put it on tight lol. What is the torque supposed to be?
post #5 of 24 Old September 19th, 2019, 05:06 PM
PaulK's Avatar
First Name: Paul
My RZR: 17 XP Turbo
Member #34432
180 ft.lbs
PaulK is offline
post #6 of 24 Old September 20th, 2019, 09:09 AM
Standard Vendor
dmcmark's Avatar
Member #36968
View dmcmark's Photo Gallery(0)
Re: Rear wheel play
180 seems high for wheel bearings. If you have their older style radius rods that have the plastic bushings they wear out really fast and you will have play in the rod.
Regards,
Mark
Feel free to contact us at 760-955-1409 if you have any questions about any of our products.
Visit our website at Desertcraft
Like us on Facebook
dmcmark is offline
post #7 of 24 Old September 20th, 2019, 10:29 AM Thread Starter
Member #269144
Found out why I was getting play. Hole that lower bolt goes through is egg shaped on outside plate and plate behind the engine on lower radius rods. What can I do to fix this problem?
post #8 of 24 Old September 20th, 2019, 11:09 AM
RZR_Joe's Avatar
Member #23438
Feedback Score: 6 reviews
Re: Rear wheel play
This happens because the bolts were loose. You need to drill them out and weld in 12mm threaded bungs. This will fix the issue permanently or you can replace the plate.
https://www.performancesxsbushings.c...-in-frame-bung
RZR_Joe is offline
post #9 of 24 Old September 20th, 2019, 03:17 PM
Standard Vendor
dmcmark's Avatar
Member #36968
Re: Rear wheel play
Yea, only way to go, we use Hess's and they make it so much easier to prep between races. No more trying to get my fat fingers behind the plate to put the nuts on, lol.
If you go that route start with fresh bolts and make sure you use thread locking compound.
Mark
Like us on Facebook
dmcmark is offline
post #10 of 24 Old September 20th, 2019, 03:29 PM
PaulK's Avatar
First Name: Paul
My RZR: 17 XP Turbo
Member #34432
Re: Rear wheel play
Name:	rzr axle torque.png
PaulK is offline
post #11 of 24 Old September 20th, 2019, 03:59 PM
BWXT's Avatar
My RZR: 2018 XP1000 Black
Member #241858
View BWXT's Photo Gallery(0)
Re: Rear wheel play
Pretty sure I torque mine to 110 lb-ft. 180 is more than a lot of car and truck bearings call for. I could be way off here, but so far Iíve had no problems.
BWXT is online now
post #12 of 24 Old September 20th, 2019, 04:03 PM
craigstumph
craigstumph's Avatar
My RZR: RZR 1000
Member #59177
Re: Rear wheel play
Try these from Keller. No welding.
https://www.proutvparts.com/products...dfd1b9a2&_ss=r
olddog likes this.
Call or Text 801 367 1395
www.proutvparts.com
craigstumph is offline
post #13 of 24 Old September 20th, 2019, 08:45 PM Thread Starter
Member #269144
Thanks for all the info! I will go with either the bungs or the Keller route to fix the egg holes. However, after I tightened the lower bolts I still noticed play at the hub. Is it possible that the hub is worn out too? (when I grabbed ahold of the axle and pulled in on it the play would stop--I'm running rhino 2.0 axles)
post #14 of 24 Old September 21st, 2019, 10:11 AM
XMARGH's Avatar
My RZR: 2019 RZR Turbo S Velocity
Member #241850
Re: Rear wheel play
Regards,
Polaris calls for 180ft/lbs on machines such as the turbo s in the service manual. Then again they also list 110 and 180 contracting themselves in other service manuals such as for the XP1000.
BWXT likes this.
Shawn
XMARGH YouTube Channel
XMARGH is offline
post #15 of 24 Old September 24th, 2019, 03:58 PM
Jrd223's Avatar
Member #258424
View Jrd223's Photo Gallery(0)
My 2018 xp1000 factory manual calls for 180 lbs
I have grrased bearings twice now and torque to recommended spec. I have had no problems as of yet
Jrd223 is offline
