Questions about replacing starter on 2018 RZR XPT - Polaris RZR Forum - RZR Forums.net
 8Likes
post #1 of 20 Old September 1st, 2019, 09:06 PM Thread Starter
RZR newbie
Mikeyboy_esq's Avatar
First Name: Mikeyboy
My RZR: 2018 RZR Turbo
Member #72965
View Mikeyboy_esq's Photo Gallery(0)
Wrench Questions about replacing starter on 2018 RZR XPT
Looks like I need to replace the starter soon on my 2018 RZR XPT and looks like the starter is tucked up behind lots of stuff and hard to reach. Is the easiest way to go in from the side of the motor by removing the exhaust header pipe and heat shield? Or should I go in from the top? If the top is best, I'm not sure what all needs to come off to get to the starter.
Also, it looks like the OEM starter is $400 to $500. I keep seeing ads on ebay and amazon for other brand starters with same p/n (4014548) for only $100 to $200, but those ads don't mention the 2018 XPT. So I'm not sure if they are compatible or not. Thoughts?
Any advice or tips would be greatly appreciated.
2018 RZR Turbo
Happy trails...
Mikeyboy_esq is offline
post #2 of 20 Old September 1st, 2019, 09:08 PM
Got4wd's Avatar
First Name: Jeremiah
My RZR: 2017 XPT
Member #79606
View Got4wd's Photo Gallery(0)
Re: Questions about replacing starter on 2018 RZR XPT
Why do you think itís going bad?
You sure itís not the bolts backing out and getting stuck?
Got4wd is offline
post #3 of 20 Old September 1st, 2019, 09:13 PM Thread Starter
RZR newbie
Member #72965
For the last few months, the starter will sometimes fire up right away when I hit the ignition key and other times it does nothing. Seems to be happening more frequently lately, and occurs especially once the motor is warmed up. I replaced the battery and that did nothing. So now I'm thinking it is either a bad solenoid, bad ground for the solenoid (which I plan to clean up tomorrow so I can rule that out), or a bad starter. To be clear, the starter does not drag or turn slowly when it turns over. So it either fires up like normal, or doesn't turn over at all... very random. Thoughts?
2018 RZR Turbo
Happy trails...
post #4 of 20 Old September 1st, 2019, 09:17 PM
Got4wd's Avatar
My RZR: 2017 XPT
Member #79606
I would pull the stator cover and look to see if any of the heads have broken off. I canít see the starter going bad unless it sees a lot of water mud etc. Do a search on the broken bolt on the starter. One of the heads might be getting caught when starting etc. Just a thought.
Got4wd is offline
post #5 of 20 Old September 1st, 2019, 09:26 PM Thread Starter
RZR newbie
Member #72965
Thanks for the tip. I'll read up on that some more. I thought the broken bolt was reported when the starter SPINS, but didn't catch on the flywheel. My issue is that the starter sometimes does NOT spin at all... just hear one click.
FWIW, the starter has started slow (not that the starter spun the motor slow, but rather it seemed to delay turning over) ever since I bought it new 1.5 years ago. But early this year I started noticing it not turning over at all sometimes, which is very annoying at the starting line of a XC race! Grrr.
Just curious... is it possible to remove the starter without removing the stator cover?
2018 RZR Turbo
Happy trails...
post #6 of 20 Old September 2nd, 2019, 07:49 AM
Rockymtn5280's Avatar
My RZR: 2018 RZR 1000 TRE
Member #223457
Before I replaced a starter, I would do some volt drop testing. Battery cables (both), starter solenoid & starter wiring. Check ground wiring as well.
Should be less than .1 volt. If more, you have a poor connection somewhere.
Google volt drop testing. Its really easy to do.
I have personally repaired two RZR's that multiple parts where tossed at vehicles and the problem was the main ground connection. You have to pull the skid plates. Its a stud, in front of the engine in the frame cross member. Just to the drivers side of the prop shaft. You can see it from the drivers side below the sway bar from the drivers side rear wheel well.
Its a stud screwed into the crossmember with all the grounds stacked on top of the stud and a nut. Usually, the stud has come loose from the crossmember.
Mikeyboy_esq likes this.
Rockymtn5280 is offline
post #7 of 20 Old September 2nd, 2019, 07:55 AM Thread Starter
RZR newbie
Member #72965
Thanks, Rockymtn5280. I'll check the connections today.
2018 RZR Turbo
Happy trails...
post #8 of 20 Old September 2nd, 2019, 07:59 AM
sandblster's Avatar
My RZR: 2018 Dynamix
Member #46247
Sounds more of a solenoid problem then a starter problem. All your symptoms say an intermittent bad contact in the solenoid.
sandblster is online now
post #9 of 20 Old September 2nd, 2019, 08:11 AM Thread Starter
RZR newbie
Member #72965
Thank you for the feedback. I hope you are right as that would be much cheaper/easier to replace.
2018 RZR Turbo
Happy trails...
post #10 of 20 Old September 2nd, 2019, 08:21 AM
sandblster's Avatar
Member #46247
How a solenoid works. It has a flat plate that gets slammed against the battery post to power the starter. Each time there is a electric arc of high amps that can erode the plate. Most plates are round and rotate on its shaft. When the arc is enough high spots are built up. When bad enough it will keep the plate from contacting the battery contacts. Hit key again plate may rotate to a good spot and starter works. Next time it depends on how the plate rotates and makes contact if the starter works or not. Your starter spins and easily starts the motor when ti works. Solenoid is the most likely problem and as you say, easier and cheaper to change.
post #11 of 20 Old September 2nd, 2019, 04:14 PM Thread Starter
RZR newbie
Member #72965
Today, I cleaned the main ground connection and the terminals on the solenoid, but that made no difference. Still acts up sometimes when I try to start it.
Then I checked the voltage on my (brand new) battery when starting the motor... it seemed ok. Dropped about 1 volt (from 12.6 to 11.6 for just a quick second and then went up to 14.2 - 14.4 at idle).
Next, I removed the solenoid and ran an ohms test while adding 12V to it per the Service Manual instructions. The manual says 0 to 0.5 ohms is ok and above 0.5 is bad and needs to be replaced. It registered 0.5 for a split second on my meter. But the odd thing was my solenoid would sometimes click on and off while I consistently applied 12V to it. I thought it should only click once and stay that way til I remove the 12V. So I'm guessing it is a bad solenoid. Tomorrow morning, I plan to order a new solenoid and a new starter relay just to be safe from my local dealer. I normally order parts online, but I need these parts soon b/c I have a XC race this Sunday. I hope the dealership can get these parts by Friday so I can get it installed before my race. I'll report back if this solves my problem. Thx again to everyone for the info above.
2018 RZR Turbo
Happy trails...
post #12 of 20 Old September 2nd, 2019, 04:20 PM
sandblster's Avatar
Member #46247
There are two separate circuits in a starter solenoid. A pull in circuit and a hold in circuit. They do just as you would expect. One high draw to close the contacts and a lesser draw to hold the contacts together until the engine starts and power is turned off. Sounds like the hold in circuit is bad.
post #13 of 20 Old September 3rd, 2019, 10:09 AM
nbm
nbm's Avatar
Member #260308
View nbm's Photo Gallery(0)
brake switch? next time it doesn't start keep the key turned to the start position and let off the brake and apply it firmly a few times and see if it starts.
nbm is offline
post #14 of 20 Old September 3rd, 2019, 10:17 AM Thread Starter
RZR newbie
Member #72965
Thanks for the tip. I'll try that.
2018 RZR Turbo
Happy trails...
post #15 of 20 Old September 6th, 2019, 08:12 PM
ricepow's Avatar
My RZR: 2017 XP4 Turbo Titanium Matte
Member #45811
View ricepow's Photo Gallery(0)
Mine did the same thing. It was the key cylinder. New cylinder and keys from Rocky Mountain was about $28 and took about 10 minutes to replace. Try turning and holding the key when it doesn't crank. Then wiggle the key. Mine would crank if I pushed the key a certain way while turning it.
Max H and Mikeyboy_esq like this.
ricepow is offline
