Too much weight, bigger tires, looking for options - Polaris RZR Forum - RZR Forums.net
 50Likes
post #1 of 27 Old July 23rd, 2019, 09:09 AM Thread Starter
Michale's Avatar
My RZR: 17 XPT2
Member #218193
17 XPT2. AA tunes stage 1,2,and 3. AA adjustable clutch and springs. I have added 700 lbs plus with tires, cage, winch, bumpers. heavy duty axles, a arms, radius rods, tools, parts and so on. I just went from 30s to 32s so I had to take some weight out of the clutch arms and now my belt temps have gone way up. Just smoked my first belt this weekend. I love the way my car is setup so other then not carry my 60 lb spare occasionally I don't want to shave weight. I want to try and keep the 32s. Mostly run high mountain trails medium to fast pace and some high desert runs.
Other then the obvious, shed some weight for both me and my car or go back to 30s what are some options.
Thanks in advance.
Michale is offline
post #2 of 27 Old July 23rd, 2019, 09:17 AM
RZR_Joe's Avatar
Member #23438
Feedback Score: 6 reviews
Re: Too much weight, bigger tires, looking for options
The 17 XPT2 was the 1st of the higher geared XPTs. The 17 XPT4 kept the 16 model gearing but the 2 seater has the 18+ gear set. What about a trans gear reduction.
SuperATV, RWB713 and Madore128 like this.
RZR_Joe is online now
post #3 of 27 Old July 23rd, 2019, 09:53 AM
Aspiring Perfectionist
RWB713's Avatar
First Name: Richard
My RZR: 2018 XP4 Turbo
Member #70552
Have you eliminated any mechanical issues such as overshifting and improper belt alignment?
Iím in the same boat, just with a 4 seat, been working on a cure for over a year, might be getting close to making progress, but not certain yet.
Even with gear reduction, I still have WOT belt temp issues, it climbs in a hurry to 240, on a steady cruise or slow trails it will run 160, maybe up to 180 on a hot day.... start pushing in high throttle bursts... climbs slowly, still maintains 210 or less... make any sustained WOT runs and itís just a countdown to 240, which is where Iíve learned to lift at to prevent failure an maintain acceptable belt life.
similar riding, I just do a lot of crawling and slower trails ( zero issues at all there in regards to belt temp, or performance ) in addition to the high speed high desert sections.
I keep you posted with what I find, should have a chance to do some testing this weekend
SuperATV and BrokeTrapDad like this.
2018 XPT4 - Bailey
RWB713 is online now
post #4 of 27 Old July 23rd, 2019, 09:54 AM Thread Starter
Michale's Avatar
My RZR: 17 XPT2
Member #218193
Joe, that sounds like a great idea. What Gears would you recommend? Is there a certain models gears I should be looking at or something else.
Thank you Joe! I was hoping you would chime in on this one.
I thought about portals but I don't know how they will hold up to high speed and I might be loosing too much top end speed then too. I figured portals are more for rock crawling and I do very little of that.
Also, just got off the phone with a friend and he is running the same car with identical added weight and tires. He has 5000 miles on his clutch and getting 2k plus out of belts with a stock clutch. I may put my new stock clutch parts back in and see how it does.
SuperATV, RWB713 and BrokeTrapDad like this.
Michale is offline
post #5 of 27 Old July 23rd, 2019, 10:03 AM Thread Starter
Michale's Avatar
My RZR: 17 XPT2
Member #218193
Thanks RWB. I Checked alignment and its right on and with the marker test my belt is running exactly where it should. I didn't have a problem until I went to 32" tires and took 2 magnets out of the arms. I know by removing weights it doesn't grab the belt as tight and causes slip and heat. I know what caused it I am just hoping there is a fix without going back to 30s. As stated above I am going to put the stock clutch parts back in and see if that helps with heat.
RWB713 likes this.
Michale is offline
post #6 of 27 Old July 23rd, 2019, 10:13 AM
442raceRZR's Avatar
My RZR: 2009 RZR 800 S
Member #264074
Other than to look cool, why you need the 32" tires? Not being a d!ck, but in all honesty... My v8 trucks i've had didn't even run 32s.
AMA D38 - Sportsman UTV
Windansea Coffee / Mass Depot / MassFX / Frank Motors / Blud Lubricants / GL Performance Coatings / M&M Offroad / Big Gun Exhaust / TireJect / RynoPower / SuperATV.com / AG Sandcars / Filterwears / Austin Hose
2009 Polaris RZR 800S
442raceRZR is offline
post #7 of 27 Old July 23rd, 2019, 10:14 AM
RWB713's Avatar
First Name: Richard
Member #70552
Keep me posted with your results, I have pondered that as well.
You could also try putting those weights back in, and see what it does to your temps without regards to the peak rpm drop as well, just to see if your riding that fine line with the belt slipping, or if you need more than just that.
I think weíre on the verge of the limits of the stock clutches with all things considered, but hopefully thereís still a solution... if not... Airdam is the only consistent cure Iíve heard of, and that is primarily from the switch to a roller secondary and much better airflow
2018 XPT4 - Bailey
post #8 of 27 Old July 23rd, 2019, 10:25 AM
RZR_Joe's Avatar
Member #23438
I'm defo not clutch guy but typically you want to add weight for larger tires to make it engage quicker.
Gears - The ACE 325 set would give you a 13% reduction across all gears. (#3235450 48T Stage 2 Gear #3235451 25T Reverse Gear Shaft). The 17 XPT2 has a multi-piece input shaft so those two gears are all you need. There are multiple combinations available but if you're not going larger than 32s there is no real need to reduce any further. That would put you ~3% lower than stock gearing.
Edited to add this because I forgot you asked about portals.
Portals, portals, portals - been there done that and if I rode strictly west coast rocks I'd run them again. However, they add a LOT of unsprung weight, add width, and we have these pesky things on the east coast called trees where being too wide become an issue. They will also increase the turning radius because of the width. If the width does not bother you there are numerous upsides. SATV offers a 15% kit works well for smaller tires. It also gives you ground clearance right where it's needed and the added width makes the machine more stable. But, plan on upgrading the entire front suspension - HD ball joint, Tie-rods, HD rack, etc because of the additional weight & stress.
Personally, the type of riding you describe I'd go with a reduction in the trans over portals.
SuperATV, RWB713 and Michale like this.
post #9 of 27 Old July 23rd, 2019, 10:27 AM
RZR_Joe's Avatar
Member #23438
Nothing to do with looking cool, the ride is much better, increased sidewall for flex, and larger tires roll over obstacles easier. That's why I run 35s
post #10 of 27 Old July 23rd, 2019, 10:49 AM
442raceRZR's Avatar
Member #264074
Going back to 30s sounds a lot cheaper than this gearing and misc upgrades to add portals... more money for beer.
post #11 of 27 Old July 23rd, 2019, 10:54 AM
RWB713's Avatar
First Name: Richard
Member #70552
Lol... did any of us really NEED a rzr to begin with?
But as Joe pointed out, thereís many reasons, looking cool isnít anywhere near the top of the list for those of use that take on larger rocks and other obstacles
Rockwerx likes this.
2018 XPT4 - Bailey
post #12 of 27 Old July 23rd, 2019, 11:34 AM Thread Starter
Michale's Avatar
My RZR: 17 XPT2
Member #218193
Once you run 32s you will not want to go back, kind of like DD's.
Oh wait. That's the other forum.
Michale is offline
post #13 of 27 Old July 23rd, 2019, 11:40 AM
RZR_Joe's Avatar
Member #23438
ROFLMAO
RWB713 likes this.
post #14 of 27 Old July 23rd, 2019, 12:13 PM Thread Starter
Michale's Avatar
My RZR: 17 XPT2
Member #218193
Something like this.
SuperATV, RZR_Joe, RWB713 and 4 others like this.
Michale is offline
post #15 of 27 Old July 23rd, 2019, 01:02 PM
RZR_Joe's Avatar
Member #23438
I've used that picture as reference a few times
SuperATV and RWB713 like this.
