Washer/ shim behind primary clutch - Polaris RZR Forum - RZR Forums.net
 1Likes
  • 1 Post By Highrider
post #1 of 13 Old July 17th, 2019, 04:33 PM Thread Starter
Jtizzle's Avatar
First Name: Jt
My RZR: 16 Polaris Rzr XPT 1000
Member #73367
View Jtizzle's Photo Gallery(0)
I'm trying to figure out where I can get the shim/ washer that goes behind the primary at the case. I let my dad put it on a customer's RZR figuring he could just replace it, but it doesn't even show on a parts fisch. Any ideas? It goes right behind primary on shaft before the case.
Jtizzle is offline
post #2 of 13 Old July 17th, 2019, 05:15 PM
AZ_TR0Y's Avatar
First Name: Troy
My RZR: 14 RZR1000 2 seater
Member #47129
View AZ_TR0Y's Photo Gallery(0)
Re: Washer/ shim behind primary clutch
Call hunterworks as they have a few options on shim thicknesses.
Mark the center of the primary doing the sharpie test and do test runs as it should not bottom out the belt.
The shim can be added or removed without removing the primary of the car, But you do have to remove the cover that will slide over the bolt.
2014 rzr1000 2 seater.
AZ_TR0Y is offline
post #3 of 13 Old July 17th, 2019, 05:52 PM Thread Starter
Jtizzle's Avatar
First Name: Jt
Member #73367
No it is actually behind the drive clutch. It's not the shims for the drive clutch, I'm not sure if it just spaces the primary away from the case or it is for alignment. Thanks though.
Jtizzle is offline
post #4 of 13 Old July 17th, 2019, 07:28 PM
Max H's Avatar
First Name: Max
My RZR: 2018 XPT 2 seat
Member #16311
View Max H's Photo Gallery(0)
I maybe wrong ...but I really dont think there could be a shim needed behind the primary . It is on a tapered shaft and a shim would have no function ..I would confirm with Tod at Hunterworks as mentioned in a earlier post...
Max H is offline
post #5 of 13 Old July 17th, 2019, 07:54 PM
Highrider's Avatar
Member #54711
The male taper on the crank end is mated to your female part of your primary-
It makes zero sense that someone would want that bottoming out before the taper was fully seated.
There are spacers for the secondary ( after the secondary is removed)- but that is for alignment to match the center of the primary,but.. your should use the offset tool for correct alignment. CTC
Your belt should show signs of witness marks of how far off a person is- inward or outward alignment is.. hence the spacer washers behind the secondary.
glamisfan likes this.
2019 XP 1000 Trails and Rocks
Highrider is online now
post #6 of 13 Old July 18th, 2019, 03:51 AM
Morris Racing #711
Stairway2Kevin's Avatar
First Name: Kevin
My RZR: 17 XPT
Member #199785
View Stairway2Kevin's Photo Gallery(0)
there are no shims or washers behind the primary it seats on the taper of the crankshaft
17 XPT - Titanium Matte Metallic
Stairway2Kevin is offline
post #7 of 13 Old July 18th, 2019, 04:49 AM
bbyers's Avatar
First Name: Brian
My RZR: 2017 XPT4
Member #175225
View bbyers's Photo Gallery(0)
only shim is behind the secondary
-2017 XPT4-Polaris roof, sliders, trailing arm guards, half windshield, front winch bumper & rear mesh screen, Warn 4500 winch, Ride Command w/rear camara, Razorback 3.0, Evo charge tube, intake tube & Bov, Dyno jet JUNK power vison((ITS HAD BLUE SCREEN OF DEATH FOR OVER A YEAR. ZERO HELP FROM DYNOJET!))w/AA stage 3 tune, Empire exhaust w/quite cores, NRP gated shifter, NRP radius rods, 32" curved led light bar, lower door inserts, PRP door bags, R2C filter. AIRDAM CLUTCHES Best purchase so far!
bbyers is online now
post #8 of 13 Old July 18th, 2019, 07:55 AM Thread Starter
Jtizzle's Avatar
First Name: Jt
Member #73367
You are correct I thought he said he pulled it from primary, but just looked at it and the secondary was pulled. Sorry so where should we order it from. Sorry my bad.
Jtizzle is offline
post #9 of 13 Old July 18th, 2019, 08:14 AM
Morris Racing #711
First Name: Kevin
My RZR: 17 XPT
Member #199785
Maybe I'm missing something but I don't have any shims behind my secondary. I think you only need to shim it if the alignment is off, so I would check that first.
post #10 of 13 Old July 18th, 2019, 09:36 AM
///AIRDAM Clutches
AIRDAM's Avatar
First Name: adam
Member #36901
View AIRDAM's Photo Gallery(0)
you wont see them on a parts fische. the dealer has to look deep into his fische to find them. there is a part number for them but unfortunately i dont know it off hand.
there are two thicknesses of splined shims i believe a .040" and a .060" these are used to correct belt alignment from the factory at assembly. these come on the machine if it needed it at assembly. some come with them, some do not. there is not a certain year or model that did get them, its case by case basis as each machines engine and trans is assembled and clutches are installed. if you got one on yours, you are likely going to continue to need it. dont give it away!
AIRDAM is offline
post #11 of 13 Old July 18th, 2019, 02:41 PM
cbryant_2's Avatar
My RZR: '17 XP4 Turbo
Member #8053
View cbryant_2's Photo Gallery(0)
Search for a 2016 turbo and you'll see it in the fiche. I ordered from a '16 fiche for my 17 XPT4.
cbryant_2 is offline
post #12 of 13 Old July 18th, 2019, 02:49 PM
///AIRDAM Clutches
AIRDAM's Avatar
First Name: adam
Member #36901
WASHER-DRIVEN SPLINE
7556942
AIRDAM is offline
post #13 of 13 Old July 18th, 2019, 04:05 PM Thread Starter
Jtizzle's Avatar
First Name: Jt
Member #73367
Got it today and mics out to the same as the other. Thanks for the help. Polaris needs to change the diagram cause it looks like it's a spider bolt washer.
Jtizzle is offline
