HOW MUCH POWER CAN THE XPT MAKE WITH THE BIG MO TURBO MAKE AT 26 PSI ? see here! - Polaris RZR Forum - RZR Forums.net
 9Likes
post #1 of 21 Old April 8th, 2019, 10:48 AM Thread Starter
Joey Strub Bmp's Avatar
First Name: Joey
My RZR: All models
Member #208601
View Joey Strub Bmp's Photo Gallery(0)
Exclamation HOW MUCH POWER CAN THE XPT MAKE WITH THE BIG MO TURBO MAKE AT 26 PSI ? see here!
What would you do with this much power?
See the Polaris XP Turbo engine with Big Mo turbo get pushed up to 26 psi on Bikemans Superflow 902 Dyno! Watch as the boost gets turned up and we maximize the factory ECU to the ECU's psi limits.
-This is all done on bone stock 2018 XP Turbo 925cc engine with no internal mods! (2016 models we recommend polaris 4 layer head gasket part number 5814693 and new head bolts polaris number 7519123)
-Fuel used is straight 110 octane race fuel.
Name:	rzr headquarters.jpg
Niner1000RR likes this.
I welcome any comments or questions regarding Bikeman Performance Products. I am the guy behind the scenes at Bikeman that can answer just about any question you have. Please contact our sales department if you are looking to buy products. I am not online as much as I would like to be but I will try to be when I have time. You can also email me for support.
[email protected]
Joey Strub Bmp is offline
post #2 of 21 Old April 8th, 2019, 07:16 PM
Rickrock's Avatar
Member #175145
View Rickrock's Photo Gallery(0)
Re: HOW MUCH POWER CAN THE XPT MAKE WITH THE BIG MO TURBO MAKE AT 26 PSI ? see here!
Any actual real world running of this with stock head bolts. My buddy was running AAs big turbo with E85 ARP studs blew the head gasket twice and a intercooler he also has a 18
Rickrock is online now
post #3 of 21 Old April 8th, 2019, 07:32 PM
comp 670's Avatar
My RZR: 2019 XPT 4
Member #80460
View comp 670's Photo Gallery(0)
Who cares how much it makes on the dyno... How long will it live out in the real world? Do a 10 second full throttle/full boost pull on the dyno. That will tell much more then just making a pull to get a big number. It would be interesting to see how bad it falls off as it heats up.
olddog and Rickrock like this.
comp 670 is online now
post #4 of 21 Old April 8th, 2019, 09:10 PM
OKCMoparGuy's Avatar
My RZR: 2018 XP Turbo Ghost Grey
Member #261990
View OKCMoparGuy's Photo Gallery(0)
280hp / .925L = 302hp per liter.
2000F EGT's
olddog likes this.
OKCMoparGuy is offline
post #5 of 21 Old April 9th, 2019, 07:10 AM Thread Starter
First Name: Joey
My RZR: All models
Member #208601
We have a ton of these out there and with proper tuning it is a very stable package. I cannot attest to AA's setup since I have nothing to do with them. We have found that stock head gasket and stock bolts is the best option and it is what we run in all of our race cars. The Bikeman Polaris Race team consistently has the fastest RZR Turbos on the track and we do not blow head gaskets. I testing we were able to blow head gaskets by improper final Timing, Knock setup and AFR. Bottom line is head gaskets will blow from severe knock but the engine is stable when tuned properly.
If putting in a head gasket we recommend Pol part# 5814693 along with 6 new Pol Part# 7519123 head bolts. The Bolts are torque to yield bolts and should never be reused.
ID:	574658   Click image for larger version
ID:	574660   Click image for larger version
[email protected]
post #6 of 21 Old April 9th, 2019, 07:22 AM Thread Starter
First Name: Joey
My RZR: All models
Member #208601
2000F EGT's
This is nothing compared to our Bikeman outlaw snowmobiles they are built out of a similar engine the Arctic Cat 1100cc twin. We have set many world records with our turbo snowmobiles and held the title of quickest and fastest sled in the world more than a few times. My Personal Outlaw sled ran 65 psi boost at 10,800 RPM making over 700hp. We have been tuning highly modified turbo 4 stroke twins for many years. We understand small displacement turbo engines and 26 psi is easy to tune in comparison. Our Outlaw sleds run at 667hp/liter fun fact.
ID:	574664   Click image for larger version
dartersracing and Niner1000RR like this.
[email protected]
post #7 of 21 Old April 14th, 2019, 07:47 AM
y0manda's Avatar
Member #86761
View y0manda's Photo Gallery(0)
How tight were his studs?
y0manda is offline
post #8 of 21 Old April 14th, 2019, 09:47 AM
Rickrock's Avatar
Member #175145
The first time with ARP studs he went to 75. The second time he did 85 but the intercooler blew too so not sure if that also had something to do with the head gasket. He took the head to a machine shop and had it resurfaced it was 8 thousandths off.
post #9 of 21 Old April 14th, 2019, 02:57 PM
y0manda's Avatar
Member #86761
When I installed studs I stopped at 80ft lbs. Didn't feel right going to 85. Also I never re torqued them. Did your friend upgrade his intercooler or stay with OEM? What head gasket did he use after the first one let go.
y0manda is offline
post #10 of 21 Old April 14th, 2019, 07:14 PM
Rickrock's Avatar
Member #175145
He went with the 4 layer gasket. Yeah 85 is scary but thats what Mike at AA said to do. Dealer was able to warranty the intercooler so its stock for now. I heard a rumor that someone is close to releasing a heavy duty intercooler
post #11 of 21 Old April 14th, 2019, 07:19 PM
Dstew619's Avatar
My RZR: 2017 Turbo XP4
Member #174273
He went with the 4 layer gasket. Yeah 85 is scary but that’s what Mike at AA said to do. Dealer was able to warranty the intercooler so it’s stock for now. I heard a rumor that someone is close to releasing a heavy duty intercooler
K&T already has one, it’s been out a long time now.
Rickrock likes this.
Dstew619 is offline
post #12 of 21 Old April 14th, 2019, 09:18 PM
y0manda's Avatar
Member #86761
K&T already has one, its been out a long time now.
That's the one I've been eyeing for some time.
y0manda is offline
post #13 of 21 Old April 14th, 2019, 09:20 PM
Rickrock's Avatar
Member #175145
Mike with Aftermarket Assassins said hes working on one
post #14 of 21 Old April 15th, 2019, 06:45 AM Thread Starter
First Name: Joey
My RZR: All models
Member #208601
We have tried many different torque values and have found the factory bolts are very effective and less likely to blow head gaskets than the ARP studs are. We use the 2018 4 layer factory gasket.
[email protected]
post #15 of 21 Old April 15th, 2019, 08:21 AM
y0manda's Avatar
Member #86761
Well shit. Wish I would have known that a few months ago.
Dstew619 likes this.
y0manda is offline
How much power will the XPT make @26psi of boost? see it here! Joey Strub Bmp RZR XP Turbo S 10 April 10th, 2019 02:58 PM
Five Ways to Make Your RZR Turbo Faster VS_Goose Polaris RZR News 6 June 14th, 2017 03:46 PM
Please welcome the 2016 RZR XP Turbo EPS! Dascrow Polaris RZR News 52 September 1st, 2015 10:24 AM
2015 Polaris RZR Models Announced awd4life Polaris RZR News 109 September 21st, 2014 07:37 PM
