Crossover Ring Removal? - Polaris RZR Forum - RZR Forums.net
 1Likes
  • 1 Post By dmcmark
post #1 of 11 Old March 21st, 2019, 09:10 AM Thread Starter
Scotts RZR's Avatar
Member #158545
View Scotts RZR's Photo Gallery(0)
Question Crossover Ring Removal?
I have a '16 2 seat turbo with the Shock Therapy stage 4 work done to the shocks. I do not have their sway bars.
I get so much rattling from the springs banging on the crossover rings I am thinking of removing them. I would like to know if anyone has done this and what the downside would be.
I ride mostly dunes and am not a racer/jumper but do some spirited duning.
Thoughts?
Scott
Scotts RZR is offline
post #2 of 11 Old March 21st, 2019, 09:24 AM
Standard Vendor
dmcmark's Avatar
Member #36968
View dmcmark's Photo Gallery(0)
Re: Crossover Ring Removal?
Before you do that, try adjusting the crossover rings up higher on the body. This should allow the top softer spring to work through the short chop better before engaging the crossover. You may feel a bit more body roll while cornering, but banging should go away. A lot of old desert racers with quality spring will back the rings way off and let the spring do all the work.
Regards,
Mark
Feel free to contact us at 760-955-1409 if you have any questions about any of our products.
Visit our website at Desertcraft
Like us on Facebook
dmcmark is online now
post #3 of 11 Old March 21st, 2019, 09:41 AM
AZ_TR0Y's Avatar
First Name: Troy
My RZR: 14 RZR1000 2 seater
Member #47129
View AZ_TR0Y's Photo Gallery(0)
The effect would be removing the true dual rate tunable spring system.
The upper spring lower rate spring would have to bind before the lower higher rate spring would come into play for less % of full shock stroke.The crossover gets the lower springs higher rate involved sooner. Without the ring you may find the car bottoming out or needing more compression added for having less higher spring rate in the shock stroke.
Maybe someone will know if binding the spring will aid in it being worn out sooner or failure.
2014 rzr1000 2 seater.
AZ_TR0Y is offline
post #4 of 11 Old March 21st, 2019, 10:00 AM
Standard Vendor
dmcmark's Avatar
Member #36968
Your right, It would not be adjustable, but would still be considered dual rate, as long as the upper spring is not a collapsed keeper/fluffer like they use stock.
Regards,
Mark
Like us on Facebook
post #5 of 11 Old March 21st, 2019, 10:08 AM
GimpyRZR's Avatar
Member #208177
View GimpyRZR's Photo Gallery(0)
clock your springs so they don't hit as much. If they rub the crossover ring that much, they would probably rub the shock body if you removed them
GimpyRZR is offline
post #6 of 11 Old March 21st, 2019, 10:27 AM
shilo020's Avatar
First Name: Rick
My RZR: Wreck it Rick: 2015 XP1000 Voodoo Blue / You Know...For the Kids: 2015 XP1000 Havasu Red
Member #59828
View shilo020's Photo Gallery(0)
Regards,
You mean lower on the body? Allowing the softer upper spring to have more stroke before being blocked by the crossover ring and making the noise.
shilo020 is offline
post #7 of 11 Old March 21st, 2019, 11:08 AM
Metki's Avatar
Member #164697
View Metki's Photo Gallery(0)
The lower you put it the more main spring it will use
Metki is offline
post #8 of 11 Old March 21st, 2019, 11:38 AM
Standard Vendor
dmcmark's Avatar
Member #36968
The lower, or closer to the spring separator at ride height will engage the stiffer lower spring quicker. If you have the crossover 1" from the separator at ride height loaded, the softer spring will only travel that far before crossing over into the stiffer spring.
Regards,
Rickrock likes this.
Mark
Like us on Facebook
post #9 of 11 Old March 22nd, 2019, 08:58 AM
reckless_racing's Avatar
Member #69806
View reckless_racing's Photo Gallery(0)
You could also try different crossovers from zbroz. They are a lot smaller than shock therapy so they wont hit the spring near as much.
reckless_racing is offline
post #10 of 11 Old March 22nd, 2019, 02:12 PM
AZ_TR0Y's Avatar
First Name: Troy
Member #47129
ST has two style rings.
The 3 bolt rings are larger with the 2 bolt close to the same size as Zbros or even smaller.
AZ_TR0Y is offline
post #11 of 11 Old April 3rd, 2019, 08:56 AM Thread Starter
Scotts RZR's Avatar
Member #158545
Thank you for all of the replies!
I have been a bit off the grid so I was not able to read them til this morning.
I have talked with ST about the irritating noise a few times. They had me check spring clocking and I have messed with that a bit to no avail. This is why I thought I would ask the collective about removing them.
I don't want the spring to bang on the shock body either. There is a good possibility of this given how loud the shock rattle noise is. Would be nice if there was a polyurethane sleeve or bumper to help.
I will try adjusting the crossover rings up higher on the body. Any idea how much might be effective?
Thanks again for the input everyone.
Scott
Shock Therapy Crossover O-Ring Lime Squeeze RZR XP 1000 Rock & Trail L.E. Forum 5 December 13th, 2018 04:36 AM
Shock Therapyst crossover ring measurement? motoracerx RZR XP Turbo 55 March 8th, 2018 10:42 PM
ST crossover ring question SNWMBL RZR XP 4 1000 4 August 7th, 2017 07:48 AM
Alba Racing +2 big bore kit install GenDis Engine and Drivetrain 9 April 8th, 2014 01:01 PM
Need help on my rebuild for front differential chipster314 RZR 800 Specific Discussion 4 March 29th, 2014 07:46 PM
