Anyone running a pre-filter? - Polaris RZR Forum - RZR Forums.net
 4Likes
post #1 of 25 Old March 17th, 2019, 10:06 AM Thread Starter
lgimmer's Avatar
First Name: Lee
My RZR: 2019 XP Turbo Titanium Metallic
Member #51763
View lgimmer's Photo Gallery(0)
Was wondering if anyone had removed the stock frogskinz intake cover and replaced it with a washable filter to help keep main filter cleaner longer?
I've seen where guys have done it to XP 1000s but I can't find where anyone has done it to a Turbo and posted the results, was also wondering if it could cause any negative effects.
lgimmer is offline
post #2 of 25 Old March 17th, 2019, 10:23 AM
Jado's Avatar
Member #48589
View Jado's Photo Gallery(0)
Re: Anyone running a pre-filter?
I'd also like to hear on this. I know some guys use S&B particle separator, but I wouldn't mind hearing about different options.
Sent from my SM-G960U using Tapatalk
Jado is offline
post #3 of 25 Old March 17th, 2019, 10:55 AM
rzrmuddawg's Avatar
First Name: Steve
My RZR: 2017 1000 xp 4 turbo
Member #192881
View rzrmuddawg's Photo Gallery(0)
sub, interested also
SHOCK THERAPY
rzrmuddawg is offline
post #4 of 25 Old March 17th, 2019, 11:10 AM
Wolfsnout Racing's Avatar
First Name: Tim
My RZR: 2017 1000xp
Member #26446
View Wolfsnout Racing's Photo Gallery(2)
Usa Re: Anyone running a pre-filter?
I have been running this in mine. Seems to be just fine. They are used with the frog skin.
We sell them for the CVT and they will fit in the engine side. Someone a while back used one specifically for an XP and says he lost boost. He may or may not have had the strut in it though. They work just fine on the XP. The cvt filter for the Turbo can handle the airflow from the turbo engine, only the intake boot is week and (may not) hold up. I have not experienced this in my 2018 Turbo at all and have not noticed any reduction in power. I will note that Polaris does not put a seal on that side for some reason. It still pulls a lot of air around the bottom of the cover and our filter would only catch some of that dust.
https://wolfsnout.net/utv-accessories/ Some dust will make it through.
WOLFSNOUT
High Performance ATV/UTV Dust Mask
Amazon-https://tinyurl.com/yb6n5oou
http://www.wolfsnout.com
Wolfsnout Racing is offline
post #5 of 25 Old March 17th, 2019, 11:37 AM Thread Starter
lgimmer's Avatar
First Name: Lee
Member #51763
Seems like this might be all the more reason to buy a K&N type filter (dry)with 3" flange and 3" pipe into intake boot with outer wears to put on top to help main filter.
lgimmer is offline
post #6 of 25 Old March 17th, 2019, 11:42 AM
First Name: Tim
My RZR: 2017 1000xp
Member #26446
Might work
WOLFSNOUT
post #7 of 25 Old March 17th, 2019, 12:39 PM
The Lone Rzr
185EZ's Avatar
My RZR: 2017 1KXP4
Member #89257
View 185EZ's Photo Gallery(0)
I did it on my 1k.
I'm sure you could do it on your turbo
The sheet of a/c filter isn't very dense and I don't think it impedes the air flow too much until it gets dirty.
I spray it with KN oil.
This was after 50 miles
My main filter has some shop vac foam around it.
I do this only if I know it's going to be super dusty
20180925_081028 by 185 EZ, on Flickr
20180925_081439 by 185 EZ, on Flickr
185EZ is offline
post #8 of 25 Old March 17th, 2019, 04:25 PM
First Name: Tim
My RZR: 2017 1000xp
Member #26446
Originally Posted by 185EZ View Post
I did it on my 1k.
Good Job! I would be scared a little bit of oily dirt gets to the belt though. I suppose you could put oil on our filters, but never have for that reason.
WOLFSNOUT
post #9 of 25 Old March 19th, 2019, 04:54 PM
AzRzrWhlr's Avatar
My RZR: '16 XP 1000
Member #144049
View AzRzrWhlr's Photo Gallery(0)
I make a filter housing replacement that eliminates the frogskin housing all together. It uses a K&N style filter. I use them on both the CVT and the engine side. I haven't needed to clean the uni air filter on my '16 xp1k in a thousand miles. I used to dump the fine dirt out of my CVT housing after every ride. Now I wipe it out once every other oil change. They will fit any xp1000 from '14-'19. Turbo or not. The pic is of them on my 2019 xp4 turbo S. I have almost 300 miles on it with the filters on. No loss of boost. They go on in a matter of minutes.
mannysouza and clk004 like this.
AzRzrWhlr is offline
post #10 of 25 Old March 19th, 2019, 07:01 PM
mannysouza's Avatar
Member #48340
View mannysouza's Photo Gallery(0)
Are these oiled?
mannysouza is offline
post #11 of 25 Old March 19th, 2019, 07:02 PM
AzRzrWhlr's Avatar
My RZR: '16 XP 1000
Member #144049
Yes they are.
post #12 of 25 Old March 19th, 2019, 07:51 PM
Mjclark's Avatar
Member #178561
View Mjclark's Photo Gallery(0)
Put a Donaldson Blue filter in the RZR and you are good.
Mjclark is offline
post #13 of 25 Old March 20th, 2019, 05:45 AM
Magnum1's Avatar
My RZR: matching 2018 XPT's
Member #30101
View Magnum1's Photo Gallery(0)
What' the part #? I'm finding a couple different ones on line.
Magnum1 is offline
post #14 of 25 Old March 20th, 2019, 06:33 AM
Ride_The_Rockies's Avatar
First Name: Scott
My RZR: 2017 RZR XP 1000
Member #17893
View Ride_The_Rockies's Photo Gallery(0)
What' the part #? I'm finding a couple of different ones on line.
It depends on what machine you have but for a 2017 and 2018 the Part# 1522280001
https://www.rockymountainatvmc.com/p...-upgrade-kit-p
Ride_The_Rockies is offline
post #15 of 25 Old March 20th, 2019, 11:35 AM
Jado's Avatar
Member #48589
What about 2019?
Jado is offline
Pre filter questions Happynthehollar RZR XP 900 3 April 16th, 2016 07:58 PM
empty oil filter hp1here RZR 1000 Engine 8 January 13th, 2015 05:24 PM
a little K&N filter defense totalhavek Engine and Drivetrain 26 September 1st, 2010 09:33 PM
Factory pre filter? Hayden General RZR Discussion 1 July 8th, 2009 05:50 AM
