Need some help - Polaris RZR Forum - RZR Forums.net
post #1 of 3 Old September 30th, 2018, 10:12 PM Thread Starter
roughrider's Avatar
Member #7633
View roughrider's Photo Gallery(0)
Need some help
I bent a tie rod on my 16 turbo so I had to replace them I bought the super ATV heavy duty tie rods. I installed them and tried adjusting to 0 toe but it's pulling to the right not real bad but a nuff to be annoying. My question is should I toe the right side in a little or toe the left side out a little the steering wheel is pretty much straight any and all help is appreciated.
roughrider is offline
post #2 of 3 Old October 1st, 2018, 06:28 PM
btmsranger's Avatar
Member #185513
View btmsranger's Photo Gallery(0)
Toe wont cause a pull. bent control arm, caliper sticking, tire pressure control arm out of adjustment (if there adjustable) camber/caster are some other things to check
btmsranger is offline
post #3 of 3 Old October 1st, 2018, 10:36 PM Thread Starter
roughrider's Avatar
Member #7633
So your saying I possibly bent the a arms
