Ride Command 2017 XPT - Polaris RZR Forum - RZR Forums.net
post #1 of 8 Old January 30th, 2018, 11:35 AM Thread Starter
specrp's Avatar
First Name: Ricky
My RZR: 2017 XP Turbo EPS
Member #230177
View specrp's Photo Gallery(0)
Usa Ride Command 2017 XPT
Guys...i am seeing tons of pictures and videos of ride command being installed in 2016 and earlier. Has anyone installed ride command in a 2017 XPT with the digital instrument cluster? Is it plug and play or will i still need to fiddle with the factory wire harness? Thanks in advance, i have searched until exhaustion on this.
specrp is offline
post #2 of 8 Old January 30th, 2018, 11:57 AM
Dbow32sl's Avatar
Member #228425
View Dbow32sl's Photo Gallery(0)
Re: Ride Command 2017 XPT
search YouTube, there are video's that show what you have to do. I think the hardest part is you have to switch the current plug for one that has more pins since there is more going on with the ride command.
Dbow32sl is offline
post #3 of 8 Old January 30th, 2018, 12:37 PM Thread Starter
specrp's Avatar
First Name: Ricky
Member #230177
i have seen a number of the videos, but all on 2016 or other vehicles without the digital display.
specrp is offline
post #4 of 8 Old January 30th, 2018, 12:40 PM
Dbow32sl's Avatar
Member #228425
Hu I don't know, the one I'm thinking about showed them switching out the plug but I can't remember if it had the digital display or the older analog one. I can't imagine that it would be much different. But I don't know for sure.
Dbow32sl is offline
post #5 of 8 Old January 30th, 2018, 04:07 PM
bigbore's Avatar
First Name: Dave
My RZR: 17 RZR XP4 Turbo
Member #14010
View bigbore's Photo Gallery(0)
Yes, there is still some fiddling with the factory harness. I'm not very electrical savvy. Took about an hour and half, instructions were easy to follow.
bigbore is offline
post #6 of 8 Old January 31st, 2018, 06:11 AM
greasemonkey3406's Avatar
My RZR: 2018 RZR XP Turbo
Member #54949
View greasemonkey3406's Photo Gallery(0)
You need to buy the install kit as well. It comes with everything needed - dash, wiring, cameras, antenna, brackets. I installed it in my 2018 XPT and it was pretty straight forward. The connector for the older round gauge is the same for the new digital one so everything in the instructions for the pin modifications is the same.
greasemonkey3406 is offline
post #7 of 8 Old February 2nd, 2018, 02:40 AM Thread Starter
specrp's Avatar
First Name: Ricky
Member #230177
Thank you, that is what I was expecting. I was just hoping for plug and play!
specrp is offline
post #8 of 8 Old February 2nd, 2018, 08:48 AM
Member #54949
It is pretty much plug and play. You just need the install kit. There is no physical way for the ride command display to fit in the dash for the older gauge.
Tags
install , ride command
Still need help: 2018 XPT or XP 1000?? NKR RZR XP 1000 18 December 31st, 2017 08:26 AM
1000 S vs General Ride Command Sortie71 RZR S 1000 2 March 30th, 2017 08:45 AM
2017 XPT test ride? motosquirt RZR XP Turbo 3 September 29th, 2016 07:37 AM
Trade dune ride for trails ride. Asaszn General RZR Discussion 1 April 7th, 2016 05:55 PM
North Glamis RZR Forum Ride Schedule of Events FJK Glamis North Hot Springs Resort Ride 6 March 17th, 2016 08:04 AM
