2018 xp turbo Polaris winch - Polaris RZR Forum - RZR Forums.net
 3Likes
post #1 of 17 Old October 29th, 2017, 11:53 AM Thread Starter
18turbo916's Avatar
Member #222121
View 18turbo916's Photo Gallery(0)
I'm trying to install the winch I got from the dealer when I purchased the rzr. It's the 3500# part number 2881671. On there website this is also what comes up for the 18 turbo. My questions has anyone with a 17 or 18 installed the Polaris winch, it seems the mounting plate does not fit in between the frame where it is supposed to. The front holes line up perfect but the rear holes are to high and the way the frame is it doesn't seem like it is the right part. My dealer is closed Sunday and Monday so just trying to figure it out before I can call them on Tuesday. Tried to get some pics, you can see the front holes line up, the backs holes are almost an inch off.
ID:	482057   Click image for larger version
ID:	482065   Click image for larger version
ID:	482073   Click image for larger version
18turbo916 is offline
post #2 of 17 Old October 29th, 2017, 12:03 PM
Clubin's Avatar
First Name: Clayton
My RZR: XPT
Member #61303
Re: 2018 xp turbo Polaris winch
I’d say install a winch bumper I installed one in there on my 16. What a stupid place to jamb a winch in. It is a tight fit!!
2016 XPT
EVO stage 2
EVO captains choice exhaust
EVO charge tube
OSP clutch kit
Rockford Fosgate Stage 4
STI HD5's 31/10.50/15 Super Swamper IROC'S
Clubin is offline
post #3 of 17 Old October 29th, 2017, 12:23 PM Thread Starter
18turbo916's Avatar
Member #222121
I put the winch in its not that tight, but the bracket I think is wrong. The 16 to 17/18 frames are different in the front from what I've read
post #4 of 17 Old October 29th, 2017, 12:33 PM
focker80's Avatar
First Name: Bryon
My RZR: 2016 Polaris Ace 900SP! 2016 XP1K
Member #54327
View focker80's Photo Gallery(0)
We just put a superatv winch on a buddies 18turbo is came with their bracket and it went in like a charm.
https://www.facebook.com/groups/710478085817035/
Join our New facebook Page!!
SxS Mayhem
focker80 is offline
post #5 of 17 Old October 29th, 2017, 06:10 PM
nfk
nfk's Avatar
First Name: Nick
My RZR: 2013 XP LE
Member #6930
View nfk's Photo Gallery(0)
I put a motoalliance winch mount in my '18 xpt4 and it fit great. But I was told by the dealer that the factory winch mounts are a very tight fit.
Sent from my XT1049 using Tapatalk
nfk is offline
post #6 of 17 Old October 29th, 2017, 06:25 PM Thread Starter
18turbo916's Avatar
Member #222121
Thanks for all the replys, very tight is fine but I do not see a way that this mount will fit. It says it fits 2016 xp1000, and xp turbo. Basically I'm thinking if the frames are different in the 18 I need a different mount maybe the dealer messed up.
post #7 of 17 Old October 31st, 2017, 11:14 AM Thread Starter
18turbo916's Avatar
Member #222121
Just so everyone knows I got an update from the dealer and there techs. They said its the right part but it never fits right and they told me to use a hammer and a pry bar possibly a vice and bend it a little bit. Not what I hoped for when you buy oem but if anyone else has the same problem or is looking for a winch id go with some of this other systems that everyone says just bolts right in. Thanks for the help guys!
post #8 of 17 Old October 31st, 2017, 01:40 PM
rzrrider's Avatar
Member #253
View rzrrider's Photo Gallery(0)
i would call polaris or return it, I'm not hammering shit.
bignoze, Jtarver and falcon241073 like this.
rzrrider is offline
post #9 of 17 Old November 2nd, 2017, 07:49 PM
bigbore's Avatar
First Name: Dave
My RZR: 17 RZR XP4 Turbo
Member #14010
View bigbore's Photo Gallery(0)
I picked up the Super ATV 4500 for my 17 XP4T. I found, the KPI winch mount gave me much more room than the Super ATV mount. For $50, it was a quick and easy fix.
bigbore is offline
post #10 of 17 Old November 3rd, 2017, 03:37 PM
greasemonkey3406's Avatar
My RZR: 2018 RZR XP Turbo
Member #54949
View greasemonkey3406's Photo Gallery(0)
I think Im going to go this route with mine as well.
greasemonkey3406 is online now
post #11 of 17 Old July 21st, 2019, 04:13 PM
motoxman495's Avatar
First Name: Jim
My RZR: 2019 XP1K Turbo
Member #28312
View motoxman495's Photo Gallery(0)
I have a 2019 and started an install today and ran into the same problem. I will be calling Rocky Mountain ATV tomorrow morning (that is where I got mine)
motoxman495 is offline
post #12 of 17 Old July 21st, 2019, 07:36 PM
Rockwerx's Avatar
My RZR: 2015 900S 2016 1000S 2018 XP Turbo
Member #85936
View Rockwerx's Photo Gallery(0)
I had the same problem with the winch plate for each of our RZRs. The plates were close to fitting but would not quite fit. I used a small lever to make the first plate fit. The second and third install I had to use a small hammer and a block of wood to get them into place.
Getting the winch into the XPT was tricky but it did fit after quite a bit of wrangling. I recall jacking the front end up and removing a lower shock bolt to gain enough room to fit the winch.
2016 1000S 2018 XPT
Rockwerx is offline
post #13 of 17 Old July 21st, 2019, 08:58 PM
First Name: Jim
Member #28312
I said screw it just ordered
https://www.hmfracing.com/equipment/...zr-xp-turbo-19
See how this goes. I not beating or prying on shit that should fit... I expect better from OEM Polaris parts. What a joke.
Let you know how this goes.
post #14 of 17 Old July 31st, 2019, 10:45 PM
White Lightning 19's Avatar
Member #271322
View White Lightning 19's Photo Gallery(0)
On our 19 XPT I had to put the winch up in there before bolting the plate in. It's not real fun but doable. Slide it to the opposite side you are bolting. Don't forget the loctite, it's not a sport you want to play twice.
White Lightning 19 is offline
post #15 of 17 Old August 1st, 2019, 09:44 AM
JRHOWE's Avatar
My RZR: 2018 Dynamix
Member #245314
View JRHOWE's Photo Gallery(0)
Pissed Re: 2018 xp turbo Polaris winch
[QUOTE=White Lightning 19;5921672]On our 19 XPT I had to put the winch up in there before bolting the plate in. It's not real fun but doable. Slide it to the opposite side you are bolting. Don't forget the loctite, it's not a sport you want to play twice"
I used a high speed rotary grinder to open up the rear holes a little, Then it was doable, but not easy..
JRHOWE is offline
2018 Polaris Dynamix Turbo With Shock therapy springs FJK Shock Therapy 1 September 3rd, 2017 08:23 PM
2018 Polaris RZR XP Turbo EPS Dynamix Edition Preview VS_Goose Polaris RZR News 0 July 26th, 2017 09:11 AM
Polaris Announces New Off-Road Vehicles Expands RIDE COMMAND to Polaris GENERAL Line FJK Polaris General 1000 4 January 4th, 2017 06:51 PM
UTV INC eBay LISTINGS - NEW & USED Inventory! UTV Inc. UTV Inc 32 September 10th, 2016 10:26 AM
Polaris Defense Unveils Turbo Diesel MRZR FJK Polaris RZR News 2 May 25th, 2016 10:02 PM
