One piece driveshaft - Page 6 - Polaris RZR Forum - RZR Forums.net
 32Likes
post #76 of 83 Old August 13th, 2018, 06:03 AM
Living the Dream :-)
Greybeard's Avatar
First Name: Robert
My RZR: 2017 1000 XP EPS LE Gold
Member #71860
View Greybeard's Photo Gallery(0)
Texas Re: One piece driveshaft
Originally Posted by Wheel View Post
All this talk of boots, mine didnít come with boots. Am I missing something?
Also, mention of their 4130 shaft being two-pieces with three CVs now, does anyone know WHY they made this change?
I do not know why they made the change.
The boots are "inside" the bells on either end of the driveshaft. Actually I think they are molded in the bell itself and then strapped to the shaft.
Wheel likes this.
Greybeard: One of your friends in Texas
2017 RZR 1000 XP LE Gold
Greybeard is offline
post #77 of 83 Old August 13th, 2018, 07:27 AM
craigstumph
craigstumph's Avatar
My RZR: RZR 1000
Member #59177
To the best of my knowledge the change was made from 1 piece to the 2 piece design because of issues with the single shaft vibrating at about 55-60 mph. Once they are out of that harmonic resonance speed the vibration goes away. Most of these shafts run good and are still in service. However, please send me a PM if anyone has a problem with their shafts. RCV is a reputable company will stand behind any problems. Thank you for your patience and I regret any problems anyone has with their RCV shafts. I am here to help.
06yfz and Wheel like this.
Call or Text 801 367 1395
www.proutvparts.com
craigstumph is online now
post #78 of 83 Old August 13th, 2018, 01:10 PM
06yfz's Avatar
First Name: Jordan
Member #38660
View 06yfz's Photo Gallery(0)
Sent you a pm on this. I finally had a chance to take my machine out a few weeks ago and it vibrates horribly starting at 50mph. Way worse than the factory unit did. I definitely would not recommend going with the one piece shaft if you dune or do anything else where your constantly at high speeds! Hopefully Rcv can do something to fix this!
2008 Raptor SE dune/drag bike
2016 Graphite Crystal XPT - it's stock
06yfz is offline
post #79 of 83 Old August 13th, 2018, 01:18 PM
craigstumph
My RZR: RZR 1000
Member #59177
Sent you info on the back channel.
06yfz and btpars0ns like this.
www.proutvparts.com
post #80 of 83 Old August 13th, 2018, 02:42 PM
Wheel's Avatar
Member #64360
View Wheel's Photo Gallery(0)
Well shucky darn. I have only had the XP out once since installing the shaft, and I didnít get much high speed in at all. Hopefully it will cool down here shortly so I can test.
Wheel is offline
post #81 of 83 Old August 13th, 2018, 06:39 PM
Dstew619's Avatar
My RZR: 2017 Turbo XP4
Member #174273
When you rebuild the cvs, do you have to remove the driveshaft to do it or can you service them while mounted? Iíve been debating between rcv and Sandcraft for a little now and been leaning towards rcv as I love the idea of plunging cvs to help eliminate vibration and shock on the diff. But if I have to remove the entire shaft evertime it needs to be serviced, that will drive me nuts as these arenít an easy install especially on the 4 seater like mine.
Iím looking to install and hopefully never remove again, so if the above is true with rcv, Iím buying Sandcraft.
Dstew619 is offline
post #82 of 83 Old August 13th, 2018, 07:24 PM
Greybeard's Avatar
First Name: Robert
Member #71860
In theory there is no need to ever remove the RCV shaft. As a practical matter, I suppose you would wear out the CV joints after some long time, but they are sealed and should last a very long time. But, if you need to work on the shaft, it would be much more difficult to try to do it on the machine. I removed mine and worked on it on the bench.
post #83 of 83 Old August 16th, 2018, 01:30 PM
06yfz's Avatar
First Name: Jordan
Member #38660
sending my one piece back to rcv soon, they're going to take a look at it and possibly swap it out for a 2 piece. I'll update once I find out! Thanks to Craig for the help on this!
Wheel likes this.
06yfz is offline
Two piece Carrier Bearing ? HELP! dfacer RZR 4 Specific Discussion 4 September 19th, 2017 04:13 AM
Driveshaft Play SimmsJeremy RZR 800 Specific Discussion 3 July 2nd, 2017 07:26 AM
Two piece winch mount ? Jason S RZR 570 Specific Discussion 2 September 23rd, 2016 03:07 PM
Driveshaft alignment 2015 900s 900s Engine and Drivetrain 2 May 10th, 2016 04:26 AM
