This is why you should run a catch can. - Polaris RZR Forum - RZR Forums.net
 36Likes
post #1 of 91 Old July 31st, 2017, 07:02 PM Thread Starter
Tmaddox4x4's Avatar
Member #121049
View Tmaddox4x4's Photo Gallery(0)
Without a catch can you are pumping this through your motor. When I pulled my intercooler out it was covered in oil residue.
b_beder and talon4u2nv like this.
Tmaddox4x4 is offline
post #2 of 91 Old July 31st, 2017, 11:52 PM
Rickrock's Avatar
Member #175145
View Rickrock's Photo Gallery(0)
Re: This is why you should run a catch can.
What hoses do you hook the catch can up to?
Rickrock is offline
post #3 of 91 Old August 1st, 2017, 06:45 AM Thread Starter
Tmaddox4x4's Avatar
Member #121049
The breather hose off the engine that runs into the intake tube before the turbo.
Rickrock likes this.
post #4 of 91 Old August 4th, 2017, 01:43 PM
Raptor62l's Avatar
Member #197401
View Raptor62l's Photo Gallery(0)
Who makes a catch can kit?
Raptor62l is offline
post #5 of 91 Old August 4th, 2017, 02:16 PM Thread Starter
Tmaddox4x4's Avatar
Member #121049
I had one laying around from my ultra four days. I just used the stock hose and clamped the can to the frame. It took less than 10 minutes.
Rockwerx likes this.
post #6 of 91 Old August 4th, 2017, 03:18 PM
dajo's Avatar
First Name: Dave
Member #19884
View dajo's Photo Gallery(0)
So what are we looking at in the picture that tells us we need a catch can?
dajo is offline
post #7 of 91 Old August 4th, 2017, 03:23 PM
Riddler6.7's Avatar
First Name: Trevor
My RZR: 14 XP1K
Member #5103
View Riddler6.7's Photo Gallery(1)
The disgusting oily/watery stuff draining out of the catch can....
Sent from my SAMSUNG-SM-G890A using Tapatalk
Dbow32sl likes this.
2014 XP 1000 Black pearl
Sparks 1065cc, Silber Turbo kit, ARP head studs, Carrillo Rods, 9.0:1 CP Pistons, AEM infinity, Alba STM supertip clutch kit, Crow 5pt Harnesses, 30" CREE dual row light bar, OTRATTW switches, mod quad switch panel, 4' Quicklight, Pawltector parking brake, UTVgiant center seat, KFI stealth 4500 winch, UTVgiant roof, ISOTA lower doors, xp4 tender swap
Riddler6.7 is online now
post #8 of 91 Old August 4th, 2017, 06:25 PM
Rickrock's Avatar
Member #175145
My neighbors company make them for cars he gave me one to try on my RZR. Once it's installed I'll post some pictures. Here's a link to his very well made.
http://www.radiumauto.com/Universal-...-Can-P178.aspx
Rickrock is offline
post #9 of 91 Old August 4th, 2017, 06:41 PM
Robin Hood's Avatar
First Name: Charles
My RZR: XPT4
Member #91193
View Robin Hood's Photo Gallery(0)
And why do you have water in your oil?
Robin Hood is offline
post #10 of 91 Old August 4th, 2017, 06:50 PM
glamisfan's Avatar
First Name: Steve
My RZR: XP Turbo
Member #21731
View glamisfan's Photo Gallery(0)
And why do you have water in your oil?[/QUOTE]
That's what I was thinking! I have a catch can on my wife's twin turbo car, and it comes out really black. That looks like it has water in it. Intercooler leaking? Or maybe snow country does that?
glamisfan is offline
post #11 of 91 Old August 4th, 2017, 07:28 PM
Riddler6.7's Avatar
First Name: Trevor
My RZR: 14 XP1K
Member #5103
Not my picture. But every RZR that I have seen has a lot of moisture/condensation coming out of the crank case vent. The dry sump XP900s were notorious for creating a "milky" layer on top of the oil reservoir. Milky or not, even if what comes out of the catch can is mostly just oil residue, it's still bad especially for the turbo models as it coats the inside of the charge tubes and the intercooler and gums up.
post #12 of 91 Old August 4th, 2017, 07:33 PM Thread Starter
Tmaddox4x4's Avatar
Member #121049
I noticed it's less now that I run a good oil cooler.
post #13 of 91 Old August 4th, 2017, 10:33 PM
newrzrs's Avatar
Member #196809
View newrzrs's Photo Gallery(0)
My last couple of turbo charged cars all ran oil catch cans. Most of the forums for turbo charged cars have tons of threads on this topic. I figured it would be a matter of time before they started up here. You can run a catch can on pretty much any type of car but it is even more important on turbo-ed cars. The amount of blow by when running a turbo is increased because of the added intake pressures. Like stated above the gases are vented from the crankcase normally through the PCV valve and routed back to the intake. In theory these gases are to be burnt in the combustion. What happens overtime is the intake valve starts to build up with carbon which cause the valves not to seat correctly. Also overtime the gas/oil/moisture (sludge) will build up in the inter-cooler and intake plumbing. This will cause the inter-cooler to become less effective at cooling the intake air.
There are two types of catch cans available. Vented and non-vented. The vented like picture by the op will filter the heavy liquids out and discharge any remaining air/fine gases through the vent. The non-filtered type will filter the heavy liquids out and discharge the air/fine gases back to the intake. There are pro's and con's of each. Catch cans tend to be more effective when mounted lower on the machine (Below the PCV valve)
There are tons of different catch cans available. I would avoid some of the ebay junk. Some cans have integrated filters and others require the use of filter media. Normally filter media is like a very course stainless scrub pad. (Don't use steel wool) The filter media will help stop the airborne particles and force them to fall in the can. The link above for the radium can is one of the best cans in my opinion available. It comes at a price. Mishimoto and Addw1 are a couple others that pop in my head.
And finally......Cold climates can also play a factor in the amount of blow by gases that are exhausted by the crankcase. Living in Wisconsin we have warm summers and cold winters. During the summer I would empty the can once per month and maybe empty 2 or 3 ounces from the can. During the winter I would have to empty the can once per week. It is amazing how much more moisture there is when it gets colder. There have been cases where these cans have froze solid and blocked the path of crankcase gases. If the crankcase gases get trapped the pressure will find another way to escape the crankcase. Its usually the crankshaft seal which is a costly repair. Moral of the story......Make sure you EMPTY the can OFTEN. It's hard to believe a mixture of gas/oil/water can freeze but it will.
Just my 2 cents from what I've learned over the years. Hell I haven't even looked at my new RZR to see how the PCV hoses are ran so don't yell at me if I stated something wrong.
newrzrs is offline
post #14 of 91 Old August 5th, 2017, 03:52 AM
Cobra_Gt's Avatar
First Name: Paul
My RZR: 2019 XP Turbo
Member #77130
View Cobra_Gt's Photo Gallery(0)
This is a topic for many forums and discussed many times. My supercharged fox is simply vented through the valve cover with a small breather, old school. I used a air compressor type on my Lightning. Since it was clear, you could see when to clean it out. One issue with it the filer media would clog up and needed to be cleaned with carburetor cleaner. Before doing this, I took off the inter cooler and spent many hours cleaning out all of the oil residue. I dumped it out every other fuel stop.
I haven't thought about the XPT. Surprised it isn't discussed more.
Sent from my SM-T567V using Tapatalk
2019 Titanium XP Turbo
2016 General
Cobra_Gt is offline
post #15 of 91 Old February 7th, 2018, 07:29 AM
Dbow32sl's Avatar
Member #228425
View Dbow32sl's Photo Gallery(0)
do you know what "Inlet" & "Outlet" fitting size is required for a 2017 turbo?
Dbow32sl is offline
Texas SXS Run treypal Midwest / Texas 26 December 17th, 2017 09:56 AM
2016 Baja 1000 Shock Therapy Pre Run Report Shock Therapist General RZR Discussion 4 January 15th, 2017 07:26 PM
2016 Baja 1000 Shock Therapy Pre Run Report Shock Therapist Shock Therapy 1 January 9th, 2017 03:31 PM
2016 RZRback Off Road Spring Charity Poker Run CentralArk_RZRbacks Local Rides and Events 6 April 14th, 2016 05:53 PM
