What Kind of Wheel Bearing Mileage.. - Polaris RZR Forum - RZR Forums.net
 1Likes
  • 1 Post By Vapornomics
post #1 of 9 Old June 19th, 2017, 09:32 PM Thread Starter
BeezRZR9's Avatar
First Name: Brian
My RZR: 2016 RZR XPT
Member #40649
View BeezRZR9's Photo Gallery(0)
How many miles are you all getting out of your wheel bearings? My XPT has 1400 miles on it and I think I need to replace my bearings? This is my most dreaded maintenance service Although, I'm actually impressed they have lasted this long, I had changed my 900XP's wheel bearings two maybe three times by the time i had this mileage.
Also, have any of you had better luck with aftermarket wheel bearings vs the stock Polaris bearings?
2016 RZR XPT Orange - Rebel Style Kustom's Build: Low Profile Cage, Doors, Roof, Glass Windshield/Lex R., Front Bull Bumper, Rear integrated Bumper, custom powder coating/decals, Pro Armor 3" Harnesses, Black Rhino 14" R.Mirror, Rokblokz ME Flares, ORB Hi-Clearance A-Arms, Pawltector, 15" HD5 wheels w/Blackwater 30X10X15 tires, 3p Clutch Shims, Hi-Lifter Radius Rods, '17 Intake/Clutch Beezles
SOLD 2012 RZR 900XP
BeezRZR9 is offline
post #2 of 9 Old June 19th, 2017, 10:08 PM
capitan828's Avatar
Member #125897
View capitan828's Photo Gallery(0)
Mine has just over 2k hard miles with stock tires. I grease them regularly now and they are still good. Buy the greasing tool and grease them every now and then.
capitan828 is offline
post #3 of 9 Old June 20th, 2017, 04:50 AM
timoloco's Avatar
My RZR: XPT
Member #71730
View timoloco's Photo Gallery(0)
Re: What Kind of Wheel Bearing Mileage..
What type of riding do you guys do that would cause your bearings to have failures?
2017 Polaris RZR XP4 Turbo- UTV inc. Destroyer cage, Polaris front and rear bumpers, Polaris lower door assemblies, Polaris 4500lbs winch, Polaris side mirrors, Rigid Industries midnight edition 12" light bar, Ricochet offroad skid plates, Rockford Fosgate Stage 5 system, Shock Therapy Stage 4 springs, PRP GT/SE seats, PRP 4-2 harnesses, PRP upper and lower door bags, MBRP Power Tech4 exhaust, NRP gated shifter, Super ATV rock sliders, Method 401 14" wheels, MOTO Race X-ROX-DD 32" tires, Walker Evans sway bar end links, EMP tinted half windshield
Past units- 2016 Orange Madness XP Turbo, 2014 XP 900 Orange Madness
timoloco is offline
post #4 of 9 Old June 20th, 2017, 05:21 AM
rynomx785's Avatar
First Name: Ryan
My RZR: 17 XP 4 Turbo
Member #61131
View rynomx785's Photo Gallery(0)
I had 5200 miles on my stock wheel bearings before they started getting sloppy. If you don't drive in mud and water they will last a long time. I bought the UTV Inc greasing tool and greased the new ones so I am hoping they last well over 6000 miles this go around.
I will also say, do you yourself a favor when you replace them and buy the factory bearings. I ordered cheap ones on Amazon from Iconic Racing and 3 of the 4 had play after the first ride. I got to change them twice in two hundred miles! lol
rynomx785 is offline
post #5 of 9 Old June 20th, 2017, 04:07 PM
tjZ06's Avatar
Member #65169
View tjZ06's Photo Gallery(0)
My '16 Turbo is around 2,200-2,300 miles and the front wheel bearing is getting sloppy and will be replaced soon. Probably 1,800+ miles of the total are in dunes on sand tires (28" STU - razors up front, #1 cut paddles rear), the rest are in dirt split between the stock tires and now 32x10-14" Mongrels.
-TJ
2018 XPT - Build Thread
tjZ06 is offline
post #6 of 9 Old June 20th, 2017, 04:53 PM
dajo's Avatar
First Name: Dave
Member #19884
View dajo's Photo Gallery(0)
How much slop do you guys have when you replace the bearings? Must be different for everyone since it is by feel or do you hear noise in the bearing also.
dajo is online now
post #7 of 9 Old June 20th, 2017, 06:46 PM Thread Starter
BeezRZR9's Avatar
First Name: Brian
Member #40649
I ride in WV only so mud/water is common and I'm not a mud seeker but in WV it's inevitable. Also, our terrain is very rugged where I ride so I'm sure that doesn't help. I measure the slop when RZR is jacked up w/wheels off the ground, grab top of tire with two hands and pull/push to feel how much play is in the wheel. When bearings are new there is no play at all. You can ride a long time with a certain amount of play but if your wheel bearings fail it could be a long walk out of the woods. My 900XP ate wheel bearings, I had 3300 miles when I sold it and I changed all four wheel bearing 4-5 times, it sucks! But other than wheel bearings and ball joints, I've not had any mechanical problems with my two RZRs!
BeezRZR9 is offline
post #8 of 9 Old June 21st, 2017, 09:04 AM
tjZ06's Avatar
Member #65169
Same here: jack up and check for play trying to push the top of the tire in 'n out. It's useful to be looking at the full suspension (a 2nd set of eyes helps) when you do it, to ensure any play that your find is not from sloppy bushings, balljoints or tie rods vs. wheel bearings. Obviously, tie rods shouldn't give you play if pushing/pulling at the top/bottom, but they will if you push/pull at the front/back.
I don't have a measurement I go for, but it's just a feel thing I guess. As mentioned, brand new they're good and tight: no play. They quickly loosen up to have a very, very, very tiny amount of play in them, barely perceptible. Once it becomes "obvious" play (like my right front on the Turbo now) it's time to order parts and get ready to replace. You can still ride on it with a little play (maybe 1/16" or less of movement at the top of the tire) and I just did that on my Idaho trip. It didn't honestly seem to loosen up any more, but I'm replacing them soon ASAP. If it's like really obvious, more than 1/16" or movement in the wheel I'd say it's now "necessary" to replace.
Of course, that's 100% just my $0.02, not based on any manual or data.
-TJ
tjZ06 is offline
post #9 of 9 Old June 21st, 2017, 10:54 AM
Vapornomics's Avatar
Member #84227
View Vapornomics's Photo Gallery(0)
I get probably about 700 miles average. i grease them when I install them, but don't re-grease like I should. Seems every ride I end up in about a foot of water creek crossings and what not.
Bearings are easy though - the most dreaded job for me so far has been taking out that damn front driveshaft for service lol That guard really is a pita
BeezRZR9 likes this.
Vapornomics is offline
[UPDATED 2019] UTV INC RZR Wheel Bearing Greasing Tool UTV Inc. UTV Inc 147 May 2nd, 2019 08:17 AM
What kind of grease for the wheel bearings PhilCod General RZR Discussion 6 June 2nd, 2017 01:28 PM
