Bolts behind primary stripped - Polaris RZR Forum - RZR Forums.net
post #1 of 11 Old June 12th, 2017, 05:55 PM Thread Starter
claas's Avatar
Member #85471
View claas's Photo Gallery(0)
So I checked the 3 bolts behind my primary and to my surprise all were over hand tight. I loosened all with ratchet and took them out. One was really hard to get loose. After examining the threads were stripped out but bolt was fine. The other 2 I put red loctite and torqued to 10ft lb. I retapped the hole hoping I would get lucky and tried with the original bolt, it would slide in and out of threads and then you could turn it about 1 turn and it would get hand tight, but as soon as you spun with ratchet you could see it was stripped so I cleaned threads again and put a little longer of a bolt and got it torqued to 8ft lb and tried to turn little more and it went down to about 7ft lb so I just stopped. And I put a healthy amount of red loctite on this last one. My question is has anyone had this problem. These threads are in the case so kind of limited options. Don't know if it should be good to run this way or if I should drill out and put helicoil in. Sorry for the long post just wanted to be thorough.
claas is offline
post #2 of 11 Old June 13th, 2017, 03:39 AM
Clubin's Avatar
First Name: Clayton
My RZR: XPT
Member #61303
Re: Bolts behind primary stripped
Yep. Very common. Not the stripped out one though. Usually the bolts get out and munch the clutches.
2016 XPT
EVO stage 2
EVO captains choice exhaust
EVO charge tube
OSP clutch kit
Rockford Fosgate Stage 4
STI HD5's 31/10.50/15 Super Swamper IROC'S
Clubin is offline
post #3 of 11 Old June 13th, 2017, 04:00 AM
triton5150's Avatar
First Name: Adam
My RZR: 2015 RZR 1000XP4(sold). 2017 XPT4
Member #73248
View triton5150's Photo Gallery(0)
You could helicoil it or tap a bit larger bolt.
triton5150 is offline
post #4 of 11 Old June 13th, 2017, 08:01 AM Thread Starter
claas's Avatar
Member #85471
That's what my thought was exactly but with the other bolt I got in it's already at 7ftlb so I was thinking of just leaving it and call it good. Maybe check it out after a ride or two to be sure
claas is offline
post #5 of 11 Old June 13th, 2017, 10:36 AM
triton5150's Avatar
First Name: Adam
Member #73248
Hard to say if it will stay or not. If it does come out though it could be pricey.
post #6 of 11 Old June 13th, 2017, 11:05 AM
rush2252's Avatar
First Name: Kolby
My RZR: 2013 Rzr 800
Member #135881
View rush2252's Photo Gallery(0)
Tap it and use a heli coil. You shouldnt have any problems. A buddy used an electric impact on my 800 and actually broke the casting. I had to JB weld it, my belt box kept leaking water. I wasnt very happy but shit happens. Its worked great so far.
rush2252 is offline
post #7 of 11 Old June 13th, 2017, 11:54 AM
Emo
Emo's Avatar
Member #202665
View Emo's Photo Gallery(0)
What year are you working on? Or does this affect all years?
Emo is offline
post #8 of 11 Old June 13th, 2017, 10:48 PM Thread Starter
claas's Avatar
Member #85471
This is on a 2016 xpt
claas is offline
post #9 of 11 Old June 14th, 2017, 12:33 AM
Fimea's Avatar
First Name: Rick
My RZR: 2015 XP1000, 2014 XP4K, 2011 XP900
Member #29192
View Fimea's Photo Gallery(0)
Fimea is offline
post #10 of 11 Old June 14th, 2017, 10:21 AM
mjlkwolfe's Avatar
My RZR: 2016 RZR Turbo XP
Member #69338
View mjlkwolfe's Photo Gallery(0)
Usa Re: Bolts behind primary stripped
Effects both 2016 & 2017 XPT's
Here is a link to one of several threads on this forum covering this issue
Like the link to thread repair inserts
Looks to be better than Helicoil
mjlkwolfe is offline
post #11 of 11 Old June 14th, 2017, 11:32 AM
olddog's Avatar
First Name: billy
My RZR: sold 2013 900 xp sold.......2017 turbo
Member #53180
View olddog's Photo Gallery(0)
be careful on depth....
olddog is offline
The Bolts Behind The Primary CRAWLR RZR XP Turbo 103 May 15th, 2018 04:45 AM
Check the bolts behind primary clutch!! Turbo2door RZR XP Turbo 8 April 18th, 2017 06:27 AM
New Owner....oil, primary bolts, skids, roof Glen1978 RZR XP Turbo 5 July 4th, 2016 08:38 AM
09 800s Primary Spider Stripped Hachibroku RZR-S Specific Discussion 3 February 25th, 2016 06:50 AM
Torque spec for primary and secondary clutch bolts? DustyXPT RZR XP Turbo 0 November 19th, 2015 08:59 PM
