hard to shift after new spider - Polaris RZR Forum - RZR Forums.net
post #1 of 2 Old May 27th, 2017, 04:57 PM Thread Starter
littleboss's Avatar
First Name: Donald
My RZR: 2016 XP Turbo Spectra Orange
Member #47857
View littleboss's Photo Gallery(1)
I took mine in a few months ago for the recall/TSB. They installed the new spider. I brought it home and it wouldn't shift at all because the transmission was spinning ( I had to kill it so I could shift). I took it back and they replaced a couple of bearings. It no longer has to be shut off to shift but still very hard to shift compared to my Ranger and General. Anybody else had this issue?
littleboss is offline
post #2 of 2 Old June 1st, 2017, 07:31 AM
UncleJerm76's Avatar
My RZR: 2015 900XC
Member #80603
View UncleJerm76's Photo Gallery(0)
Re: hard to shift after new spider
Sounds like your stock primary spring has sagged a little bit over time and has the belt under too much tension. When I replaced primary and secondary clutches I had this same exact issue until I got the primary spring weight right. Couldn't shift unless I shut it off. If you can't get it fixed at the dealer they make spring shims in 1/16" increments.
Very inexpensive and 1/16" is all it took to make all the difference in my case. Good to go now
UncleJerm76 is offline
200 mile belt life 2016 XPT - what to expect / what can I do about it? SandyEggo RZR XP Turbo 56 February 3rd, 2018 12:43 PM
Deeper Explanation of Shift RPM Hunterworks Hunterworks 18 June 13th, 2017 06:55 AM
2017 clutch noise / hard to shift BigMackXp1k RZR XP Turbo 15 May 31st, 2017 08:06 AM
Hard to shift and creeps when in gear Narf_44 Engine and Drivetrain 8 April 7th, 2017 09:02 PM
Hard to shift jodyfj40 Polaris General 1000 4 April 6th, 2016 03:56 PM
