Clutch/Belt Help needed - Polaris RZR Forum - RZR Forums.net
 1Likes
post #1 of 20 Old May 19th, 2017, 09:15 PM Thread Starter
cr0we12's Avatar
Member #84192
View cr0we12's Photo Gallery(0)
16 Turbo 2 Seat, 3,000 miles, stock with 30" crawlers.
Ordered a BMP stage 2 clutchkit and tried multiple magnet settings and could not seem to get a good running setup. Belt slipped constantly trying to pull out easy in high, and if I run it hard it would really slip. If machine was in low and in a bind it would slip. Now I have put everything back to complete stock and it still slips in the same manner. We was thinking the belt was wore out so i got a brand new OEM belt today and it still does the same. Suggestions/input? Thanks guys!
cr0we12 is offline
post #2 of 20 Old May 19th, 2017, 09:51 PM
2qk4u's Avatar
Member #160937
View 2qk4u's Photo Gallery(0)
Very interesting. I'm not going to be much help but like to see what others have to say. I'm about to install this setup in mine as well. Whatbweight configs have your tried? You swap the primary and secondary springs as well?
2qk4u is offline
post #3 of 20 Old May 19th, 2017, 09:57 PM Thread Starter
cr0we12's Avatar
Member #84192
Yes, swapped both springs, tried 4-2-0, 4-1-0, 4-1-1, 4-2-1, 3-2-0, 3-1-1. Mine didnt have this slipping problem till I tried these weights. And on the initial 4-2-0 setup it didnt slip pulling out the first time, hit limiter at 55mph and has slipped ever since.
cr0we12 is offline
post #4 of 20 Old May 19th, 2017, 11:34 PM
Fimea's Avatar
First Name: Rick
My RZR: 2015 XP1000, 2014 XP4K, 2011 XP900
Member #29192
View Fimea's Photo Gallery(0)
Re: Clutch/Belt Help needed
Did you accidentally put your weights in backwards?
Fimea is offline
post #5 of 20 Old May 20th, 2017, 02:39 AM Thread Starter
cr0we12's Avatar
Member #84192
No, that was 1 thing I did double check. 1 more thing I just thought of for anybody wondering. I replaced both springs and all 3 set of sliders at 2500 miles with factory replacements and it has the 3p shims.
cr0we12 is offline
post #6 of 20 Old May 20th, 2017, 04:43 AM
Michigan man's Avatar
First Name: Dan
My RZR: 2016 matte red xpt
Member #130625
is your snap ring installed correctly on secondary? How bout the big black washer in the primary? With my clutch kit you take it out. And when you go back to stock it needs to go back.
evo stage2 tune, evo bov, osp clutch kit, Polaris half windshield, Polaris roof, siezmik mirrors, prp door bags, trinity stage5 exhaust, 3p shims, a little rubber bendy pink panther dude hanging on the roll cage for dear life! and I'm sure I'm missing some stuff.
Michigan man is offline
post #7 of 20 Old May 20th, 2017, 04:56 AM Thread Starter
cr0we12's Avatar
Member #84192
Plastic washer is in primary, put a new snap ring in, but my secondary goes Bolt,washer,snap ring, washer, washer. I just watched aftermarket assassins youtube video and they have the 2 washers on the bolt head side of the snap ring. Epis clutch video matches my machines layout
cr0we12 is offline
post #8 of 20 Old May 20th, 2017, 05:57 AM
joekamkod's Avatar
First Name: Joe
My RZR: 2017 xpt4
Member #27276
View joekamkod's Photo Gallery(0)
I'm having the same problem low is fine but high slips bad unless I ease into the throttle then it tops out at 55 mph . I'm running 33" BFG tires haven't really had time to mess with it I'm about to just take it out .
joekamkod is offline
post #9 of 20 Old May 20th, 2017, 11:05 AM Thread Starter
cr0we12's Avatar
Member #84192
you got a turbo now joe? Need your # again
cr0we12 is offline
post #10 of 20 Old May 20th, 2017, 02:36 PM
joekamkod's Avatar
First Name: Joe
My RZR: 2017 xpt4
Member #27276
What's up buddy I have a 16 2 seat turbo and a 17 4 seat turbo . You need to come out to the ranch and ride with us .
post #11 of 20 Old May 20th, 2017, 03:47 PM Thread Starter
cr0we12's Avatar
Member #84192
Im gonna make it out there sometime. Keep up with Matt and Cody on the regular
cr0we12 is offline
post #12 of 20 Old May 30th, 2017, 11:50 AM Thread Starter
cr0we12's Avatar
Member #84192
Anybody?? Surely somebody has an idea
cr0we12 is offline
post #13 of 20 Old May 30th, 2017, 12:30 PM
norsepeak's Avatar
Member #146153
View norsepeak's Photo Gallery(0)
Are you prepping your belts and breaking them in properly? Have you cleaned your clutch sheaves? I'd start there.
norsepeak is offline
post #14 of 20 Old May 30th, 2017, 01:27 PM Thread Starter
cr0we12's Avatar
Member #84192
I believe so, put around 20-25 easy varied rpm miles on this new one around my yard, cleaned clutches, scotch pad on the sheaves. Took to dealer friday for service bulletins and he had no answer but said my clutches looked better than some he had seen with 500miles on them. I did remove the flat washer closest to secondary and it doesnt slip at all but the machine just dont feel right at higher speeds with that setup.
cr0we12 is offline
post #15 of 20 Old May 30th, 2017, 03:35 PM
glamisfan's Avatar
First Name: Steve
My RZR: XP Turbo
Member #21731
View glamisfan's Photo Gallery(0)
It sounds to me like you know what you're doing and it should be working right. Since it's not, there has to be one thing wrong in there somewhere?
In neutral and with the clutch cover removed, rev the motor and watch it shift out to make sure it at least looks like it's working right. Should be fully shifted out at about 6000 rpm.
glamisfan is online now
Accessories help needed Jphillips1963 General RZR Discussion 19 October 13th, 2016 07:04 AM
Clutch kit needed or not needed? That is the question... DGM1995 RZR S 900 16 August 28th, 2016 07:22 PM
Black XP 1000 & Turbo Lug Nuts - NO KEY NEEDED UTV Inc. UTV Inc 9 April 27th, 2016 08:47 AM
Possible purchase advice needed crooklyn RZR-S Specific Discussion 18 March 26th, 2016 06:25 PM
Heater size needed for rzr 4 800 sandy180185 RZR 4 Specific Discussion 0 February 5th, 2016 11:31 AM
