OSP big tire secondary spring rate - Polaris RZR Forum - RZR Forums.net
post #1 of 12 Old March 24th, 2017, 11:39 AM Thread Starter
Tmaddox4x4's Avatar
Member #121049
View Tmaddox4x4's Photo Gallery(0)
Anyone know what spring rate is for the OSP big tire Teal spring? I called them and Jim didn't know.
Tmaddox4x4 is offline
post #2 of 12 Old March 24th, 2017, 11:46 AM
Turbo2door's Avatar
Member #165521
View Turbo2door's Photo Gallery(0)
Re: OSP big tire secondary spring rate
Wow didn't know? haha. Epi has some nice springs and rates are listed. stock is 140 200. I have a 160 220 coming from holtz. and epi has a 168-240 and a 182-260
Turbo2door is offline
post #3 of 12 Old March 30th, 2017, 03:58 PM
dj41c's Avatar
My RZR: 12xp rzr 900
Member #40739
View dj41c's Photo Gallery(0)
So if I called your work or what ever you do and ask for something that could take money out of your pay check you would respond?? Dude you on crack ? This could feed his family!!! And he could have tons of hours getting us the best set up what for you to save 20 or 10 bucks fu buddy !!!! I don't know osp. AT ALL BUT I DO KNOW KNOWLEDGE AND TIME ARE NOT FREE
Rzr xp 900 spray painted springs paper air filter custom plugs in tires pep boys muffler tips with a compass for navagation
dj41c is offline
post #4 of 12 Old March 30th, 2017, 04:59 PM Thread Starter
Tmaddox4x4's Avatar
Member #121049
I understand that, but when I have multiple people blowing belts with his kit and OSP has been no help it would be nice to know the rates. Almost every manufacturer of springs list their rates. Valve springs, coil springs, pretty much any high performance spring. I'm supposed to buy a product and when it doesn't work be told I'm doing something wrong and have no way to fix it? I don't like clutch kit's for this exact reason. I just wanted to know the rate so we could adjust from there. I could see if it was a custom helix, or custom tune, but a spring rate? I'm not trying to save money, actually I bought every secondary spring on the market and I'm loaning them out for people to try. I have nothing to gain from this, I'm just a gear head that loves the sport. It was really a simple question no need for the hostility. And for any one that wants some clutching tips I'll share what I got, except with you. Lol No just kidding I'll help you too.
post #5 of 12 Old March 30th, 2017, 05:00 PM
dj41c's Avatar
Member #40739
dj41c is offline
post #6 of 12 Old March 30th, 2017, 05:08 PM
dj41c's Avatar
Member #40739
I called em the other day and they asked me what's wrong. I told em I was blowing belts they were getting way too hot. So I was told to add weight to the primary I did it helped a bunch Tim . He told me to check the temp of the primary and the secondary after a run the secondary was way hotter !! I told him he said call in a couple weeks we just might have a helix to help. So now I am thinking engine braking is causing it to heat up ?? We're on the same side I I I sorry
dj41c is offline
post #7 of 12 Old March 30th, 2017, 05:39 PM Thread Starter
Tmaddox4x4's Avatar
Member #121049
Are you getting full shift out? I turned the secondary limiter down to almost coil bind. Next time you have your clutch apart drop the limiter and helix in and study what's going on. I think it's hitting the limiter and it heating up the belt. Secondary can't open any more and the primary with all the weight pulls the belt apart. I've only broke one belt and I was being hateful to it. I had lost 4wd and was trying to climb straight up rock face.
post #8 of 12 Old March 30th, 2017, 05:40 PM
triton5150's Avatar
First Name: Adam
My RZR: 2015 RZR 1000XP4(sold). 2017 XPT4
Member #73248
View triton5150's Photo Gallery(0)
A helix would be nice on the turbo's for sure.
triton5150 is offline
post #9 of 12 Old March 30th, 2017, 07:00 PM
triton5150's Avatar
First Name: Adam
Member #73248
post #10 of 12 Old March 31st, 2017, 03:36 PM
dj41c's Avatar
Member #40739
Bd-Xtreme has em or maybe use a 17 on a 16?? Less engine braking
dj41c is offline
post #11 of 12 Old March 31st, 2017, 03:40 PM
dj41c's Avatar
Member #40739
I also think most clutch kits all use similar springs depending on what you are doing is the only factor.. but the weighted arms are a lot different in there ramp levels
dj41c is offline
post #12 of 12 Old April 5th, 2017, 11:37 AM
dj41c's Avatar
Member #40739
Teal 182 2" 1" 216 approx
dj41c is offline
Wheel offset vs Suspension performance Shock Therapist Shock Therapy 216 June 14th, 2019 04:45 PM
Big thank you to OSP! Clubin RZR XP Turbo 17 March 9th, 2017 06:43 PM
Dalton Adjustable Clutch Kit with Big Tire Spring xp4tofloor Polaris RZR Parts For Sale 2 April 2nd, 2016 05:09 AM
? On correcting body roll on xp1k st222 RZR XP 1000 37 December 25th, 2015 03:05 PM
Sand Paddle Shootout Tire Test vs Maxxis Big Horn craigstumph General RZR Discussion 31 June 8th, 2015 10:10 AM
