2017 xpt rev limiter issue - Polaris RZR Forum - RZR Forums.net
post #1 of 4 Old March 22nd, 2017, 07:06 PM Thread Starter
richiee23's Avatar
First Name: richie
My RZR: 2014 rzr 1000
Member #21832
View richiee23's Photo Gallery(0)
I took my 2017 xpt turbo for its first ride. I done slow technical trail riding and got on it for a lil bit. Everything was fine and no issues. On the way home I was on the black top and punched it, I hit the rev limiter, I left off and got back in it and it did the same thing. Is this normal? I thought it was weird that it ran fine on the dirt and on the black top hitting the rev limiter. Anyone else experience this ?
richiee23 is offline
post #2 of 4 Old March 22nd, 2017, 09:30 PM
Turbo2door's Avatar
Member #165521
View Turbo2door's Photo Gallery(0)
Re: 2017 xpt rev limiter issue
They dont have enuff clutch weight from the factory. Mine did this also. Get some adjustable weights.
Turbo2door is offline
post #3 of 4 Old March 23rd, 2017, 02:49 AM Thread Starter
richiee23's Avatar
First Name: richie
Member #21832
What clutch kit do you recommend? Did you change the primary and secondary springs
Or just the weights?
post #4 of 4 Old March 23rd, 2017, 04:07 AM
Clubin's Avatar
First Name: Clayton
My RZR: XPT
Member #61303
They are limited to 75 ish mph. Maybe the ecu shutting it down. Mine did that till I got a reflashed ecu.
2016 XPT
EVO stage 2
EVO captains choice exhaust
EVO charge tube
OSP clutch kit
Rockford Fosgate Stage 4
STI HD5's 31/10.50/15 Super Swamper IROC'S
Clubin is offline
2017 XPT 4 cutting out at WOT A-Scott RZR XP 4 Turbo 11 March 27th, 2017 07:13 PM
The 2017 xpt is going to be awesome Michigan man General RZR Discussion 14 July 6th, 2016 04:22 PM
XTP Rev Limiter camaro1968 RZR XP Turbo 2 May 27th, 2016 08:39 PM
Fixing the overheating issue on the XPT AlanRR RZR XP Turbo 8 May 24th, 2016 01:33 PM
XPT Starter/Starting Issue??? Misled RZR XP Turbo 2 March 30th, 2016 11:59 AM
