Ticking sound from front end (see video) - Polaris RZR Forum - RZR Forums.net
 2Likes
  • 1 Post By RWB713
  • 1 Post By Sbels
post #1 of 13 Old September 16th, 2019, 07:20 PM Thread Starter
Sbels's Avatar
Member #265022
View Sbels's Photo Gallery(0)
I know there are several posts on this already but I was hoping with an audio file someone would immediately have an idea what the problem is. Iíve already tried the grab bar and brakes.
The sound appears to be coming from the general area of the front differential.
This is a 2019 Turbo S 4 with 120 hours. Thoughts?
https://youtu.be/dE1vTXuhQM0
Sbels is offline
post #2 of 13 Old September 16th, 2019, 07:34 PM
Aspiring Perfectionist
RWB713's Avatar
First Name: Richard
My RZR: 2018 XP4 Turbo
Member #70552
Re: Ticking sound from front end (see video)
Does it do it only on decel? or when its sitting idling as well?
2018 XPT4 - Bailey
RWB713 is online now
post #3 of 13 Old September 16th, 2019, 07:35 PM Thread Starter
Sbels's Avatar
Member #265022
It happens at around 20 mph... itís easier to reproduce at deceleration but a light foot around that speed with have a similar result.
Sbels is offline
post #4 of 13 Old September 16th, 2019, 07:44 PM
RWB713's Avatar
First Name: Richard
Member #70552
Can you feel any vibration or anything?
Rickrock likes this.
2018 XPT4 - Bailey
post #5 of 13 Old September 16th, 2019, 07:47 PM Thread Starter
Sbels's Avatar
Member #265022
My guess is itís something resonating at a certain vibration frequency but I donít notice any vibrations that Iíd consider unusual.
Sbels is offline
post #6 of 13 Old September 16th, 2019, 07:50 PM
RWB713's Avatar
First Name: Richard
Member #70552
2WD/4WD make any difference? Sounds like a rock bouncing around in something really
Could be the pinion bearing, might take a look at the prop shaft and make sure it's not rubbing against something
2018 XPT4 - Bailey
post #7 of 13 Old September 16th, 2019, 07:53 PM Thread Starter
Sbels's Avatar
Member #265022
2WD/4WD doesnít make a difference (nor does low vs high gear.
Sbels is offline
post #8 of 13 Old September 16th, 2019, 07:55 PM
RWB713's Avatar
First Name: Richard
Member #70552
Really sounds like something rattling around on top of the skidplate maybe, or hung up in a wheel or centercap... that's a tough one
2018 XPT4 - Bailey
post #9 of 13 Old September 16th, 2019, 07:56 PM Thread Starter
Sbels's Avatar
Member #265022
I removed the entire skid plate before making that clip. There actually was a rock sitting there and I was initially excited... it wasnít it tho!
Sbels is offline
post #10 of 13 Old September 17th, 2019, 06:34 AM
XMARGH's Avatar
My RZR: 2019 RZR Turbo S Velocity
Member #241850
Pull the center console and check to see if the noise is originating from the hanger bearing.
Shawn
XMARGH YouTube Channel
XMARGH is offline
post #11 of 13 Old September 17th, 2019, 09:21 AM Thread Starter
Sbels's Avatar
Member #265022
Will try that, thanks!
Sbels is offline
post #12 of 13 Old September 17th, 2019, 10:51 PM Thread Starter
Sbels's Avatar
Member #265022
I found it... turned out to be super simple. Tab below the cup holder was resting against one of the metal tubes. Pulled the tube slightly out of the way and no more ticking sound. Thankful it wasnít drive train related!
RWB713 likes this.
Sbels is offline
post #13 of 13 Old September 19th, 2019, 03:06 AM
XMARGH's Avatar
Member #241850
Right on, glad you found it.
Shawn
XMARGH is offline
