Chirping noise - Polaris RZR Forum - RZR Forums.net
 2Likes
  • 1 Post By FBT
  • 1 Post By Megabite
post #1 of 12 Old September 16th, 2019, 06:01 PM Thread Starter
bsully's Avatar
First Name: Bill
My RZR: 2019 Turbo S 4 Seater
Member #271454
View bsully's Photo Gallery(0)
Chirping noise
I recently upgraded my exhaust to an SLP slip on. After about 25 miles with it I started hearing a chirping noise similar to the bearing going out on the primary clutch. After further investigation I learned that the exhaust itself was responsible for the chirp. I took it off and put the stock exhaust back on and I couldn’t hear the chirping anymore. I can’t tell if it’s the exhaust itself or if it’s vibrating something. Has anybody had similar experience with aftermarket exhaust? Any ideas where the potential chirping may be coming from?
bsully is offline
post #2 of 12 Old September 16th, 2019, 06:49 PM
FBT
Can't 'Member.
FBT's Avatar
My RZR: 2019 Indy Red Turbo S
Member #617
View FBT's Photo Gallery(0)
Re: Chirping noise
May have the answer for you. My car was doing the same thing with the stock exhaust.
Start it up and let it idle with the noise working, then push down on the plastic above the left rear tail light....if the noise changes look at the heat shield under the left side..it is rubbing on a bracket that supports the rear plastic...this is what I found on mine anyway.
FBT is offline
post #3 of 12 Old September 16th, 2019, 07:11 PM Thread Starter
bsully's Avatar
First Name: Bill
Member #271454
That’s what I suspected initially. I put pressure on the heat shield and many other locations where the plastic meets the frame. I can’t get the noise to stop. I’ll keep searching, and report the solution if I find it. I’m still open to any other experiences. I understand that rzr’s are prone to unpleasant noises, but it still drives me nuts.
bsully is offline
post #4 of 12 Old September 16th, 2019, 07:31 PM
graniteguy16's Avatar
Member #230193
View graniteguy16's Photo Gallery(0)
Re: Chirping noise
Mine started doin this after i backed into a tree,i just figured it was my fault,but i need to investigate i guess.......i didnt hit tree hard at all but that noise started rite after
graniteguy16 is offline
post #5 of 12 Old September 16th, 2019, 07:44 PM
FBT
Can't 'Member.
FBT's Avatar
Member #617
Re: Chirping noise
Well this sound was like fingernails on a chalkboard to me, it was unbearable.
If you bend down behind the left rear tire, and look above the muffler you will see the stack of various heat shields. One of them runs parallel to the ground, and it ends in a curve up. It appears to be aluminum, and unpainted.
Directly above this is a black metal brace that comes down from above angled to the rear, that locates the rear bodywork, this is in the area under the tail light. Once everything gets up to operating temps and expands, the curved portion of the heat shield contacts that bracket...the noise literally sounds like it is coming from everywhere, I think the harmonic translates through a lot of the tin work.
IF you guys can't find it with that description get someone else to push down on the bodywork while you look in the described location, you will find it. Worse case scenario I will snap a pic of it for ya. About 30 seconds with a pair of pliers and the nose is gone...forever...
GeneralD likes this.
FBT is offline
post #6 of 12 Old September 16th, 2019, 07:58 PM
Member #230193
Re: Chirping noise
Good description! I should be able to find that,like u said,a lil fabricating and should solve the problem,thanks!
post #7 of 12 Old September 16th, 2019, 10:39 PM
FBT
Can't 'Member.
FBT's Avatar
Member #617
Re: Chirping noise
I will check in tomorrow at some point and see if you guys need a pic. It is a wonderful thing to get rid of LOL.
FBT is offline
post #8 of 12 Old September 16th, 2019, 11:45 PM
Megabite's Avatar
First Name: Orly
My RZR: 2019 RZR Turbo S
Member #90641
View Megabite's Photo Gallery(0)
Re: Chirping noise
Fixed mine Sunday actually. Perfect description.
2017 XP1K
2015 900 XC (sold)
Megabite is offline
post #9 of 12 Old September 17th, 2019, 04:11 PM Thread Starter
bsully's Avatar
First Name: Bill
Member #271454
I checked the heat shield and all the contacts points in the general area of exhaust the body and the frame I can’t get the chirping to stop. I can’t see any spots that are in contact with each other especially metal on metal. It sounds like it’s actually coming from the exhaust. There are two ports on the muffler, if I plug one of the ports the chirping stops. It’s got me dumbfounded. I’m considering buying another exhaust to see if it solves the issue. Like I said yesterday when I put a new exhaust on the chirping stopped. It sounds like the chirping you get when a bearing is going out on the primary clutch, or similar to that of a swamp Cooler with its bearings going out. Anybody ever experience something similar?
bsully is offline
post #10 of 12 Old September 17th, 2019, 04:18 PM
Megabite's Avatar
First Name: Orly
Member #90641
Re: Chirping noise
If you PM me your phone number, I will take a picture of it now and send it to you. It was driving me crazy too. Hopefully it's the same thing.
2017 XP1K
2015 900 XC (sold)
Megabite is offline
post #11 of 12 Old September 17th, 2019, 04:46 PM
Megabite's Avatar
First Name: Orly
Member #90641
Re: Chirping noise
Just sent the pictures and that wasn't it. But for anyone else having a similar issue, here's the common problem mentioned above. For me it was the heat shield touching the bracket supporting the rear plastics.
2017 XP1K
2015 900 XC (sold)
Megabite is offline
post #12 of 12 Old September 17th, 2019, 05:51 PM
FBT
Can't 'Member.
FBT's Avatar
Member #617
Re: Chirping noise
Great pic Megabite, that is the culprit. I just bent the area pointing up the other way...it now points down.
FBT is offline
