What"s going break next - Polaris RZR Forum - RZR Forums.net
 2Likes
  • 1 Post By Poorboy1957
  • 1 Post By XMARGH
post #1 of 10 Old August 21st, 2019, 08:42 PM Thread Starter
Poorboy1957's Avatar
Member #262908
View Poorboy1957's Photo Gallery(0)
Turbo S 2019 less than 600 mile 90 hrs, replaced tender springs, both bottom ball joints bad, right front bearing shot pulled left front to find bearing not pressed in correct. Very disappointed to spend this much money for a toy then have to replace with aftermarket parts.
RZR_Scott likes this.
Poorboy1957 is offline
post #2 of 10 Old August 22nd, 2019, 03:24 AM
XMARGH's Avatar
Member #241850
Re: What"s going break next
Bearings from the factory come with very little grease in them. Common practice for me is straight off the showroom floor is to grease all 4 wheel bearings with a wheel bearing greaser such as the tiger tool 44mm model. Now the bearing pressed in wrong and bottom ball joints is pretty unfortunate at 600 miles. I'm curious as to why you had the tender springs replaced?
Shawn
XMARGH YouTube Channel
XMARGH is online now
post #3 of 10 Old August 22nd, 2019, 08:02 AM
FBT
Can't 'Member.
FBT's Avatar
My RZR: 2019 Indy Red Turbo S
Member #617
View FBT's Photo Gallery(0)
XMARGH I watched your video on the tiger tool,seems like something I need to grab. Can you confirm the Turbo S has the same 44 mm bearings as the regular XP machines?
FBT is offline
post #4 of 10 Old August 22nd, 2019, 08:28 AM
XMARGH's Avatar
Member #241850
Yes I can confirm they are still using the same bearing size. 44mm will fit. One of the few items I was able to carry over from the XP1K chassis.
FBT likes this.
Shawn
post #5 of 10 Old August 22nd, 2019, 08:55 AM Thread Starter
Member #262908
Lost ground clearance after the tenders were coil binding and rode bad. Replace with st tenders
post #6 of 10 Old August 22nd, 2019, 07:44 PM Thread Starter
Member #262908
Looks like carrier bearing replace next
post #7 of 10 Old August 26th, 2019, 08:39 AM
a-rod76's Avatar
Member #144513
View a-rod76's Photo Gallery(0)
My 2019 has 1700 miles and I haven't touched a thing.
a-rod76 is offline
post #8 of 10 Old August 26th, 2019, 08:54 AM
The Lone Rzr
185EZ's Avatar
My RZR: 2017 1KXP4
Member #89257
View 185EZ's Photo Gallery(0)
I assume it's not under warranty anymore although I still would have taken a picture of the bearing not pressed in correctly and sent it to Polaris. They might have done a goodwill warranty.
What kind of terrain do you ride in and how do you drive?
600 miles and 90 hours?
I have 1700 miles and 87 hours. Haven't done a thing to it but it's not a turbo.
I don't see why having a turbo would make them install different bearings.
Do you ride through water a lot?
185EZ is online now
post #9 of 10 Old September 1st, 2019, 10:21 PM Thread Starter
Member #262908
We were in lot of mud holes back in the winter and there were 2 turbo 1000 with us every trip and not had any problems with them. I did tear into my S and had one ball joint going south, I went ahead and replaced lower ball joints, bearings and put Sandcraft carrier bearing in just like I did on my brothers bike, We did send picture of hub to dealer and he is going take care of us. Sure helps when you got good dealer.
post #10 of 10 Old Today, 06:39 AM
XMARGH's Avatar
Member #241850
This is starting to make sense now. Factory bearings will not survive in the mud if they are not consistently greased. Same goes for the carrier bearing, if you do mud your going to need to find a greasable option. I used to own a Highlifter, and carrier bearing did not last long but that's the price you pay to stick them in mud.
Shawn
