Front Flag Mount - Polaris RZR Forum - RZR Forums.net
post #1 of 17 Old August 20th, 2019, 05:07 PM Thread Starter
pearsth's Avatar
First Name: Tom
My RZR: 2019 XP4 Turbo S Velocity
Member #59126
View pearsth's Photo Gallery(0)
Front Flag Mount
I ride at Silver Lake Sand Dunes in Michigan and it requires a front flag mount. I don't have a front bumper and likely won't buy one for a while, so any thoughts on how/where to mount a front flag?
Thanks,
Tom
pearsth is offline
post #2 of 17 Old August 20th, 2019, 05:58 PM
Jay1000's Avatar
First Name: Jay
Member #110505
View Jay1000's Photo Gallery(0)
Go into duneland they have front mounts rather inexpensive two bolts and it’s on and your on the sand.
Jay1000 is offline
post #3 of 17 Old August 22nd, 2019, 05:09 PM Thread Starter
pearsth's Avatar
First Name: Tom
Member #59126
Re: Front Flag Mount
I have those on my truck that connect to the tow hook. The front tow hook on the RZR is puny...do you have experience with that working?
pearsth is offline
post #4 of 17 Old August 22nd, 2019, 05:21 PM
Jay1000's Avatar
First Name: Jay
Member #110505
There is a bracket that bolts into the grill. 1,700 miles in the sand with it no prob. If you want pm me your number I can text you a pic of it.
Jay1000 is offline
post #5 of 17 Old August 22nd, 2019, 05:41 PM
Loose Bolts's Avatar
Member #250882
View Loose Bolts's Photo Gallery(0)
I’m also a Silver Lake fan, Click image for larger version
ID:	582754Click image for larger version
ID:	582756Click image for larger version
ID:	582752 I put in a front receiver so I could be towed into the parking lot. Once in I remove that and add my flag holder in the same spot.
Loose Bolts is online now
post #6 of 17 Old August 22nd, 2019, 05:47 PM
Member #250882
ID:	582762Click image for larger version
ID:	582760Click image for larger version
post #7 of 17 Old August 22nd, 2019, 06:42 PM
THD's Avatar
First Name: Tim
My RZR: '19 Turbo 4 S
Member #27408
View THD's Photo Gallery(1)
Watched a SXS Blog video last night from Silver Lake and all the UTV's have their flags mounted on the front. Looks odd to me. Out west we put them on the roof or the back.
What's the reasoning with requiring it on the front?
THD is offline
post #8 of 17 Old August 23rd, 2019, 05:41 AM
Member #250882
Ha ha nobody knows, the DNR works in mysterious ways. The best was when I had a Polaris Ace and I still had to mount the flag to the front “because it has a steering wheel” so it blocks your vision and that’s ok. Silver Lake is rules galore, some make sense but many do not.
post #9 of 17 Old August 23rd, 2019, 07:28 AM
THD's Avatar
First Name: Tim
Member #27408
So to summarize your answer, Bureaucrats with no practical knowledge or experience make the rules? Same out west.
THD is offline
post #10 of 17 Old August 23rd, 2019, 09:02 AM Thread Starter
pearsth's Avatar
First Name: Tom
Member #59126
Attachment 582762Attachment 582760Attachment 582758
That is a sweet setup. I am going to add a winch, so I need to go a different route for my tow bar.
pearsth is offline
post #11 of 17 Old August 23rd, 2019, 09:06 AM Thread Starter
pearsth's Avatar
First Name: Tom
Member #59126
I think the front flags make sense. I have, on more than one occasion, been coming up one side of a hill while the another truck is on the other side and the flag out front gets it over the hill crest and visible that much sooner. I don't mind the front flags at all once a mounting approach is established.
I will end up with a front bumper at some point, then it is very easy to do. Just not happy with the options of bumpers and winch mounts available right now for the Turbo S models. I can't find the right combo of winch mount and bumper that isn't some puny little thing that goes up a foot that will support the winch I already have (Superwinch Terra 45) from my old RZR.
Tom
pearsth is offline
post #12 of 17 Old August 23rd, 2019, 10:23 AM
JoshDomo's Avatar
First Name: Josh
My RZR: Turbo S Velocity
Member #271528
View JoshDomo's Photo Gallery(0)
I think the rear looks better, but front gives you an extra second or so, or even feet from a possible impact. Rather then the flag being in the rear lower then normal since the vehicle is going uphill to a crest, front mounted would be even higher, and the first thing to appear rather then a bumper in your face.
JoshDomo is offline
post #13 of 17 Old August 24th, 2019, 03:45 PM
Member #250882
My winch fits in the socket too, it is removable as well so I can put in in the back also.
post #14 of 17 Old August 24th, 2019, 05:36 PM Thread Starter
pearsth's Avatar
First Name: Tom
Member #59126
I put together a solution. One bolt, one washer, one nut, one duneland flat mount without the U-bolt, and...........a skateboard wheel!
Mounted up to the cross brace in front of the radiator. Skateboard wheel gave the perfect amount of spacing and acts as a urethane bushing to absorb up and down torque from the flag.
I had the bend mount a bit as it was angled down just a little.
pearsth is offline
post #15 of 17 Old August 24th, 2019, 05:39 PM Thread Starter
pearsth's Avatar
First Name: Tom
Member #59126
How do you do the wiring - some sort of quick disconnect? I think I like that idea, but have you ever been a position where it would be really hard to put the winch on when stuck in mud or in other precarious positions?
pearsth is offline
