EIBACH springs for turbo s - Polaris RZR Forum - RZR Forums.net
 1Likes
  • 1 Post By bill c
post #1 of 11 Old July 22nd, 2019, 06:28 PM Thread Starter
bill c's Avatar
First Name: Bill
Member #265948
View bill c's Photo Gallery(0)
so its time for new springs for my 19 turbo s. 2 seat.. it is stock just a cage works cage, no other add-ons. looking at running eibach stage 2... how dose yours ride with eibach, I want to stay with a stock-ish ride. any input will help... let me know..Thx..Bill
bill c is offline
post #2 of 11 Old July 23rd, 2019, 03:30 PM
martybmw's Avatar
Member #15629
View martybmw's Photo Gallery(0)
Re: EIBACH springs for turbo s
I have these stage II and happy with them as I had lost so much ride height with he weight I added to my 2018 Turbo S. then stock springs were significantly bound up. Overall I would say their is a small improvement with the Stage II and I now have the car at stock height.
martybmw is offline
post #3 of 11 Old July 23rd, 2019, 04:09 PM
Sanman's Avatar
First Name: Kent
My RZR: 18 Turbo S
Member #85855
View Sanman's Photo Gallery(0)
I went with Shock Therapy Dual Rate Spring kit (DRS) 2018 Polaris XP Turbo S 2 seat. That was a huge improvement over stock. I do mostly duning, when I made the change I left it comfort mode the whole ride. Before I would HAVE to put it into sport mode. Just my 2 cents.
Sanman is offline
post #4 of 11 Old July 23rd, 2019, 05:01 PM Thread Starter
bill c's Avatar
First Name: Bill
Member #265948
thanks for the response's I ordered the Eibach kit so we will see how it works out soon...
bill c is offline
post #5 of 11 Old July 23rd, 2019, 08:50 PM
jeepentj's Avatar
Member #269870
View jeepentj's Photo Gallery(0)
Please do report back on how you like the kit. I have a 2019 XP S and am leaning towards the kit when my springs start to sag (which sounds lIke ito won't take long). I have run lots of Eibach springs only dirt bikes over the years and am hopeful they make a great RZR spring as well.
Sent from my Pixel Slate using Tapatalk
jeepentj is offline
post #6 of 11 Old July 24th, 2019, 06:21 AM
turboedsupe's Avatar
Member #22257
View turboedsupe's Photo Gallery(0)
Thatís what worries me. I like that in stock form that comfort mode is nice and soft. When I did the shock therapy spring package it basically took comfort mode away. Ride was very stiff over the slow stuff and I just hated the ride. How much preload was required to get the suggested ride height?
turboedsupe is offline
post #7 of 11 Old July 24th, 2019, 08:59 AM
Sanman's Avatar
First Name: Kent
My RZR: 18 Turbo S
Member #85855
I first installed the springs but, was not enough for ride height. I toke it out trail riding to work the springs in. I then set the per load to stock ride height. You can add a little more per load which will put you into the upper spring longer but, do not adjust the inter double rings. These double rings will put you into the lower spring to soon if not adjusted right. You might need to readjust these rings as they might be to low.
Sanman is offline
post #8 of 11 Old August 5th, 2019, 09:10 PM Thread Starter
bill c's Avatar
First Name: Bill
Member #265948
so I got the eibach stage 2 installed, we took it to the rubicon this weekend.. its a whole new animal.. all 3 modes work perfectly. with the new springs the shocks can now work as they were designed to. comfort mode is way better then before, it just eats up the trail. we are going to hit some trails this weekend, then some high speed desert running in a few weekends. I will let you know it goes with that.. but I am very impressed with this set up...
KB Motorsports likes this.
bill c is offline
post #9 of 11 Old August 6th, 2019, 07:39 AM
KB Motorsports's Avatar
First Name: KB Motorsports
My RZR: XP1000
Member #19990
View KB Motorsports's Photo Gallery(0)
Newspaper2 Re: EIBACH springs for turbo s
I anticipated reading a great review as Eibach is on point with their stage 2 setups! Nothing but great feedback across all RZR models.
KB Motorsports is offline
post #10 of 11 Old August 6th, 2019, 11:48 AM
Member #22257
4 or 2 seater? How much preload did it take to get to the 16-16.5 ground clearance?
post #11 of 11 Old Today, 04:53 PM Thread Starter
bill c's Avatar
First Name: Bill
Member #265948
I have a 2 seater, preload is set at 3 1/2'' im at 16.5'' this is the settings eibach sets as a starting point. it is spot on...
ID:	581832   Click image for larger version
bill c is offline
