Hard To Shift - 2019 Turbo S4 - Polaris RZR Forum - RZR Forums.net
post #1 of 5 Old July 13th, 2019, 08:21 PM Thread Starter
Riverguy553's Avatar
First Name: Scott
My RZR: 2019 Turbo 4S
Member #34623
View Riverguy553's Photo Gallery(0)
Is anyone having issues shifting your 2019 turbo S? Mine is so bad I have to shut the car off to change it from reverse to high. Also I now have a squealing noise when I come to a stop in high, low or reverse. In fact when Iím in reverse the car will actually move unless I hold the brake down. My car has 900 miles so far and something is not right!
Riverguy553 is offline
post #2 of 5 Old July 13th, 2019, 08:37 PM
armyn's Avatar
My RZR: 2015 RZR-S 900
Member #65720
View armyn's Photo Gallery(0)
Re: Hard To Shift - 2019 Turbo S4
remove your primary.. check it then re install torque it down to 98 fl/lb (oem is 95) then the magic happens.. for some reason my 2019 turbo s was only 80ft lb when i removed it. its a 15 min job.
2019 RZR XP Turbo S Indy Red
2019 Can-Am XRC 72 with tons of upgrades (SOLD)
2014 RZR-S 800 w/ tons of upgrade (SOLD)
2015 RZR-S 900 Havasu Red Pearl w/ Polaris aluminum sport roof, Polaris half windshield, low profile front bumper black and a Polaris lower extension doors, 27 kanati mongrels, 30 inch led light, MOMO steering w/NRG quick release (SOLD)
armyn is offline
post #3 of 5 Old July 13th, 2019, 11:03 PM
LDT
LDT's Avatar
Member #270454
View LDT's Photo Gallery(0)
I had the same problem. Had to remove primary clean and torqued to spec no more problems
LDT is offline
post #4 of 5 Old July 14th, 2019, 02:43 PM
***ault team
tomcav's Avatar
First Name: tom
My RZR: ..XPT,. turbo s
Member #35015
View tomcav's Photo Gallery(0)
Mine had the same noise, found out the one way bearing in the primary was bad
tomcav is offline
post #5 of 5 Old July 15th, 2019, 10:11 AM
Big Rob's Avatar
First Name: Rob
My RZR: 2019 XP4 Turbo S
Member #266844
View Big Rob's Photo Gallery(0)
Mine had the same problem, took it in under warranty and they "realigned" the clutches, still had the same problem so I took it back and they replaced the primary due to one way bearing failure and replaced the secondary due to they broke off the belt removal tool/bolt in the clutch while working on it. No problems since.
Big Rob is offline
