2019 Turbo S excess heat in cab - Polaris RZR Forum - RZR Forums.net
 6Likes
post #1 of 24 Old June 14th, 2019, 09:24 AM Thread Starter
AZTRAILBOSS's Avatar
Member #270338
View AZTRAILBOSS's Photo Gallery(0)
Usa 2019 Turbo S excess heat in cab
I don't know if anyone else has noticed that while riding my Turbo S there seems to be a lot of heat in the cab. the ride command screen, the floor board and just about everywhere on the front wall of the cab. for the cost of the thing and previous heat issues in older models this should have been addressed.
AZTRAILBOSS is offline
post #2 of 24 Old June 16th, 2019, 09:05 PM
graniteguy16's Avatar
Member #230193
View graniteguy16's Photo Gallery(0)
Re: 2019 Turbo S excess heat in cab
Mine got qite hot this weekend,all of my past rzrs have been hot from the tunnel,but yes,my dash and ride command screen were also hot
graniteguy16 is offline
post #3 of 24 Old June 16th, 2019, 09:25 PM
Mr. & Mrs. PewPewPew
KC Desert's Avatar
First Name: Kat & Chris
My RZR: 2019 RZR Turbo 4 Dynamix
Member #79033
View KC Desert's Photo Gallery(0)
Gotta get the Wolfsnout kit for the RZR to knock out that heat. It is a series of shaped pieces of special insulating foam that you insert in key locations throughout the cab and it does a tremendous job of helping cut down the heat! I did it and whew it helped a ton.
graniteguy16 likes this.
KC Desert is online now
post #4 of 24 Old June 17th, 2019, 06:12 AM
FatBuoy's Avatar
First Name: Dave
My RZR: XP4 Turbo S
Member #156801
View FatBuoy's Photo Gallery(0)
Got mine over the weekend and have begun the installation. The price is certainly right. Only $59. Would hate to try to figure all of that out myself! Well thought out.
FatBuoy is offline
post #5 of 24 Old June 17th, 2019, 08:32 AM
Member #230193
Nice,you dont happen to have a link for this kit do ya?
post #6 of 24 Old June 17th, 2019, 08:34 AM
FatBuoy's Avatar
First Name: Dave
My RZR: XP4 Turbo S
Member #156801
www.wolfsnout.net
Just navigate to the UTV kit. They have a couple of options, but I just got the front kit for the 2-seater even though I have the 4. The only difference between the two are the 4-seater one has insulated cup holder inserts for the rears as well as fronts.
FatBuoy is offline
post #7 of 24 Old June 17th, 2019, 08:38 AM
Member #230193
Originally Posted by FatBuoy View Post
www.wolfsnout.net
Ok,thanks!
post #8 of 24 Old June 17th, 2019, 08:42 AM
True K30's Avatar
First Name: Michael
My RZR: 2018 Rzr Turbo S
Member #24498
View True K30's Photo Gallery(0)
A stainless steel Yeti cup left in the cup holder for a while = very unpleasant to hold.
I am going to order the Wolfsnout kit to cut my cab heat down.
True K30 is online now
post #9 of 24 Old June 17th, 2019, 08:44 AM
FatBuoy's Avatar
First Name: Dave
My RZR: XP4 Turbo S
Member #156801
Agreed, but it is a testament to the power of a Yeti, as the "innards" stay icy cold. : )
FatBuoy is offline
post #10 of 24 Old June 17th, 2019, 08:48 AM
True K30's Avatar
First Name: Michael
Member #24498
Yes. I was very surprised that the liquid never gets the least bit hot.
Maybe I should cover my firewall in Yeti cups.
FatBuoy and graniteguy16 like this.
post #11 of 24 Old June 17th, 2019, 08:28 PM
Dstew619's Avatar
My RZR: 2017 Turbo XP4
Member #174273
The true fix is relocation the radiators to your bed. You have 4 aluminum radiator lines running through that tunnel carrying very hot coolant. Any insulation only works to an extent.
ocrzrs likes this.
Dstew619 is offline
post #12 of 24 Old June 18th, 2019, 07:47 AM
KC Desert's Avatar
Member #79033
No longer a problem.
post #13 of 24 Old June 18th, 2019, 07:58 AM
Member #230193
Does it work that good?
post #14 of 24 Old June 18th, 2019, 01:30 PM
EdgeXXL's Avatar
First Name: Rick
My RZR: 2019 Blue Turbo S
Member #85928
I have had the complete wolfsnout cab cooler kit in my last two machines. The one I have in the Turbo S has the back firewall piece and it helps a ton with heat and noise in the cab from the engine. The tunnel is where 90% of the heat comes in the cab. Once you install the wolfsnout pieces your cup holders won't even get hot. The cab cooler kit makes a huge difference in how much heat you feel in the cab.
EdgeXXL is offline
post #15 of 24 Old June 18th, 2019, 02:18 PM
Member #230193
Perfect,well problem solved then lol im ordering the wolfsnout kit,thanks!
Tags
heat in cab , wolfsnout cool cab kit
