Fault Codes / Reset - Polaris RZR Forum - RZR Forums.net
 2Likes
  • 2 Post By RZR_Joe
post #1 of 13 Old June 10th, 2019, 04:39 PM Thread Starter
JJRZRguy's Avatar
Member #95801
View JJRZRguy's Photo Gallery(0)
Fault Codes / Reset
I recently did a 600+ mile ride in my Turbo S in So. California and Arizona. The machine performed flawlessly (although the gas mileage was horrific!).
Upon returning to my home in Utah (6,500 feet MSL) I acquired a check engine light. Going to the diagnostics page I found a "SPN 1127 and FMI 31 = Boost Pressure Sensor". Further research shows a "DTC P1234 = Condition Exists"
So far, I've replaced my BOV (Diverter Valve) with an Aftermarket Assassins BOV. Cleaned and blew out all connectors I could find. Cleaned sensor in the intake down stream of the air filter.
After reassembly, I drove the machine for about 10 to 15 minutes, getting it to operating temp and the check engine light still illuminates. I have tried disconnecting the batter for, oh, almost an hour. No joy.
My question: 1. Is this a hard fault that must be reset with an ECU reader?
2. Is there a chance that the fault still exists?
3. I'm open to suggestions.
Thanks!
JJRZRguy is offline
post #2 of 13 Old June 10th, 2019, 04:51 PM
Aspiring Perfectionist
RWB713's Avatar
First Name: Richard
My RZR: 2018 XP4 Turbo
Member #70552
Re: Fault Codes / Reset
I'm not sure the answer to this, but a "boost pressure sensor" would be between the turbo and the throttle body, most likely in the intake manifold, which is right in front of the exhaust on the back of the engine, there's no boost pressure between the air filter and the turbo.... probably called a MAP or TMAP sensor in a parts description.
Is it running bad or odd at all since the it threw the code?
2018 XPT4 - Bailey
RWB713 is offline
post #3 of 13 Old June 10th, 2019, 04:57 PM
RWB713's Avatar
First Name: Richard
Member #70552
I pulled up the parts diagram, there are 3 TMAP sensors, one in the air intake duct (that's probably the one you checked) one in the charge tube ( The tube with you BOV on it ), and one in the intake manifold. The charge tube or the intake would be the culprit if it were a failed sensor
2018 XPT4 - Bailey
RWB713 is offline
post #4 of 13 Old June 10th, 2019, 04:58 PM Thread Starter
JJRZRguy's Avatar
Member #95801
It wasn't running bad on the trip. After I got it back home and it threw the fault, I took it out and the turbo didn't seem to be operating properly. It was sluggish, but never went into limp mode. I did clean the boost pressure sensor as well. (Forgot to mention.)
JJRZRguy is offline
post #5 of 13 Old June 10th, 2019, 04:59 PM Thread Starter
JJRZRguy's Avatar
Member #95801
I didn't mess with the sensor in the charge tube. Is cleaning it worth the effort? Or should I just replace it?
Also, thanks for mentioning the parts diagram. I always forget to check that! It's a good way to see 'the lay of the land'.
JJRZRguy is offline
post #6 of 13 Old June 10th, 2019, 07:51 PM
RWB713's Avatar
First Name: Richard
Member #70552
Honestly, Iím not sure if itís worth cleaning or not, Iíve never had an issues so Iíve never messed with them, but it is pretty cheap to try and clean it
Possibility it could be a wastegate issue, or a turbo issue too, you can pull the intake off the turbo and see inside fairly easily, and check the wastegate adjustment rod for anything abnormal
You donít have a PVCX by chance do you?
2018 XPT4 - Bailey
RWB713 is offline
post #7 of 13 Old June 10th, 2019, 07:58 PM
RZR_Joe's Avatar
Member #23438
Feedback Score: 6 reviews
Check to make sure the boost controller vent tube is not clogged.
True K30 and RWB713 like this.
RZR_Joe is online now
post #8 of 13 Old June 10th, 2019, 08:14 PM
RWB713's Avatar
First Name: Richard
Member #70552
Good Call, forgot about that
2018 XPT4 - Bailey
RWB713 is offline
post #9 of 13 Old June 11th, 2019, 07:01 AM
True K30's Avatar
First Name: Michael
My RZR: 2018 Rzr Turbo S
Member #24498
View True K30's Photo Gallery(0)
I agree with Joe. Here is a pic of the vent he is speaking of.
True K30 is offline
post #10 of 13 Old June 11th, 2019, 07:06 AM
True K30's Avatar
First Name: Michael
Member #24498
If it is clogged and causing the issue, I suggest tapping it into the side of your airbox to avoid future clogs. There is additional pics of how I did mine in my build thread below.
True K30 is offline
post #11 of 13 Old June 11th, 2019, 08:25 AM
Vallone1990's Avatar
First Name: Anthony
My RZR: RZR XP Turbo S
Member #263456
View Vallone1990's Photo Gallery(0)
Can we get a link to this mod? Can't seem to find it.
Vallone1990 is offline
post #12 of 13 Old June 11th, 2019, 12:10 PM
True K30's Avatar
First Name: Michael
Member #24498
https://www.rzrforums.net/rzr-xp-tur...-texas-10.html
Page 10 of my build thread. Scroll down to the post on March 10th, 2019, 08:24 PM
True K30 is offline
post #13 of 13 Old June 19th, 2019, 12:06 PM Thread Starter
JJRZRguy's Avatar
Member #95801
I will absolutely check that! I replaced the BOV with a much more robust one. I'll let you know what I find. Thanks.
JJRZRguy is offline
Tags
boost dtc p1234 , fmi 31 , p1234 , pressure sensor , spn 1124
