Enclosed Trailer Shopping for my Turbo S - Polaris RZR Forum - RZR Forums.net
post #1 of 7 Old June 9th, 2019, 08:30 PM Thread Starter
SunnyFun's Avatar
Member #264298
View SunnyFun's Photo Gallery(0)
I want a trailer to haul the turbo and keep it secure. I have an open trailer I have used, but its only 77 inches wide between the rails and with paddles, it's not wide enough. I plan to get a 8'6" wide unit 16ft long. Also going tall with at least a 78" tall door. Current front runner is a Interstate LoadRunner. Size is perfect. Not a lot of 8.5 by 16-18 with the taller door available near me. Not much used either so shopping new. I could order a Wells Cargo but 6-8 weeks for delivery. What are you using and any advice?
SunnyFun is offline
post #2 of 7 Old June 9th, 2019, 08:59 PM
Kofa2's Avatar
Member #268308
View Kofa2's Photo Gallery(0)
Re: Enclosed Trailer Shopping for my Turbo S
If you can go bigger do it. Itís like a garage/shop. Youíll want bigger. I ended up getting 20í plus the ďVĒ, 8.5í wide and also increased my height to 7.5í. The height was overkill but I didnít want to worry about anything once I add interior lights to the trailer and to the RZR. The axles I upgraded to 5200lbs. It was again overkill but I plan on doing home moves with this thing loaded down. If nothing else it will help the hubs last longer due to less stress. Had an additional roof vent put in to help with ventilation and get more natural light.
As for where to buy...South GA has a LOT of enclosed trailer manufacturers. I drove a long way to them. I got a completely custom trailer built the way I wanted it in 10 days. They have great prices due to all the competition and it being straight to public pricing, no dealer middle man.
More details than what you asked for but wanted you to know what could be had if you are in a position to road trip to GA.
Kofa2 is offline
post #3 of 7 Old June 9th, 2019, 10:03 PM Thread Starter
SunnyFun's Avatar
Member #264298
Thanks, I am trying to keep the trailer length to a minimum. I will be pulling it behind a truck camper. I will take a look at that area. Who did you end up buying yours from?
SunnyFun is offline
post #4 of 7 Old June 10th, 2019, 06:15 AM
Kofa2's Avatar
Member #268308
I ended up going with WOW Trailers. There are others though. Not sure what your expectations are though. Iíd consider my quality/finishes a work trailer. It has plywood walls with just one light that works with power from the truck. Some of the seams donít match up perfect. I was ok with this due to me finishing it out myself. If you are expecting race trailer quality with higher end finishes, smooth skinned interior, lots of lights, power package then make sure you compare and look around. Donít get me wrong they have those also. They had a race trailer there that was nice and the price was within reach but it didnít have the extra height that I wanted.
The different manufacturers use different structural components. Some use hat channel or Zbar others use tube steel. There was another company that I was going to use but when I called (three different times) each of the sales people had an attitude that I just couldnít stand. They used a little bit better floor and roof structure but not enough to deal with their attitudes.
Kofa2 is offline
post #5 of 7 Old June 12th, 2019, 05:51 PM
Bronco302's Avatar
My RZR: 2018 RZR XP Turbo S
Member #251818
View Bronco302's Photo Gallery(0)
I'd go taller, mine sits at 75-76" and my toyhauler door is 78", just clears. If I ever go with bigger tires might be screwed. Also I tie down with tire bonnets so the suspension works inside, ceiling is 82" I think, so never had any issues with it hitting.
Bronco302 is offline
post #6 of 7 Old June 15th, 2019, 08:55 PM
stuartaldridge's Avatar
Member #260596
View stuartaldridge's Photo Gallery(0)
I bought an amerilite, but the best thing I did was have the entire bottom half of the interior sprayed with Linex. Wasn't cheap but I can just hose this thing down from the inside and all is good.
stuartaldridge is offline
post #7 of 7 Old June 16th, 2019, 10:15 AM
superjunior's Avatar
First Name: Dan
My RZR: 2015 900S
Member #74479
I used a do it yourself rhino liner from ace hardware. Think I may have 150 bucks in materials and a weekend of my time but came out awesome. Cleaning is a breeze with a preasure washer
superjunior is offline
