new machine primary problems!? - Polaris RZR Forum - RZR Forums.net
post #1 of 12 Old May 29th, 2019, 05:14 PM Thread Starter
drifit86's Avatar
Member #265666
View drifit86's Photo Gallery(0)
just picked up a brand new turbo s a week ago. put 24.5 hrs on it so far just babying and breaking it in properly. change the oil today and went over the whole machine and noticed my primary has groves wore into it. is this normal or should i drop er off to the dealer!? the grove feel pretty deep and have a pattern like the belt ribs.
drifit86 is offline
post #2 of 12 Old May 29th, 2019, 05:27 PM Thread Starter
drifit86's Avatar
Member #265666
Re: new machine primary problems!?
Ill also add that the belt slipped and and through a miss fire code.... had to change the belt because it kept slipping and throwing a codes. changed the belt and not having any problems but i feel that there shouldnt be and wear this early ??
drifit86 is offline
post #3 of 12 Old May 29th, 2019, 07:22 PM
armyn's Avatar
My RZR: 2015 RZR-S 900
Member #65720
View armyn's Photo Gallery(0)
definitely a warranty!! i would show the dealer ASAP
2019 RZR XP Turbo S Indy Red
2019 Can-Am XRC 72 with tons of upgrades (SOLD)
2014 RZR-S 800 w/ tons of upgrade (SOLD)
2015 RZR-S 900 Havasu Red Pearl w/ Polaris aluminum sport roof, Polaris half windshield, low profile front bumper black and a Polaris lower extension doors, 27 kanati mongrels, 30 inch led light, MOMO steering w/NRG quick release (SOLD)
armyn is offline
post #4 of 12 Old May 30th, 2019, 05:48 AM
Steamfitters38's Avatar
Member #225146
It’s hard to tell how extreme the grooving is with that angle in the pic, but at about the same hours my xpt had the same groves in the bottom. It will happen from a lot of idling, which I do when I warm up and especially when I cool the Turbo down after a ride. Unless it’s pretty deep I wouldn’t worry about it...of course, that’s a fairly subjective term.
Steamfitters38 is offline
post #5 of 12 Old May 30th, 2019, 11:28 AM Thread Starter
drifit86's Avatar
Member #265666
Originally Posted by Steamfitters38 View Post
Itís hard to tell how extreme the grooving is with that angle in the pic, but at about the same hours my xpt had the same groves in the bottom. It will happen from a lot of idling, which I do when I warm up and especially when I cool the Turbo down after a ride. Unless itís pretty deep I wouldnít worry about it...of course, thatís a fairly subjective term.
its feels pretty bad.. i can feel the belt ribs in the grooves. the frog skin assembly was loose and not sealed so tons of dirt and mud was getting. so i think that may be the main reason why.
drifit86 is offline
post #6 of 12 Old May 30th, 2019, 11:31 AM Thread Starter
drifit86's Avatar
Member #265666
cover wasnt tight and I could rock it. it wasnt sealed, now the seals are messed up. and the fender bolts were loose and one bolt was missing.... very disappointed in polaris and the dealer on sending something out like this
ID:	577822   Click image for larger version
ID:	577824   Click image for larger version
ID:	577826   Click image for larger version
drifit86 is offline
post #7 of 12 Old May 30th, 2019, 11:44 AM
Smilfen's Avatar
My RZR: 2019 XP Turbo S
Member #185441
View Smilfen's Photo Gallery(0)
When you submerge your belt box with water and mud, be prepared for the cost it takes to fix it. From the looks of your pictures, you did some heavy mud riding. IMO, a Turbo S is not designed for that style of riding.
Smilfen is offline
post #8 of 12 Old May 30th, 2019, 11:59 AM Thread Starter
drifit86's Avatar
Member #265666
well thats the thing I didnt swap or submerge my belt box. In western pa the trails we ride have mud, alot of it isnt avoidable but nothing super deep, ive tried to ride the sides and stay out of it the best i could have. nothing has been more than half tire. so im pretty sure it my filter was was tighten properly it would have never been like that.
drifit86 is offline
post #9 of 12 Old May 30th, 2019, 12:18 PM
Standard Vendor
dmcmark's Avatar
Member #36968
View dmcmark's Photo Gallery(0)
The covers just don't seal that well anyway. Could it be possible the mud under the cover is from simply washing it? The new turbo gearing is higher and seems to be abusive on the drives running low and slow. Many are doing a gear reduction (low range minimum) to help out. We do offer a prefilter kit which eliminates the covers. We use dry element high flow filters and nylon wraps to repel water. Also check out our CVT "Blaster" to help with excess belt temps....
Regards,
Mark
Feel free to contact us at 760-955-1409 if you have any questions about any of our products.
Visit our website at Desertcraft
Like us on Facebook
dmcmark is offline
post #10 of 12 Old May 30th, 2019, 12:50 PM
turboedsupe's Avatar
Member #22257
View turboedsupe's Photo Gallery(0)
Quit working on it and just take it to the dealer. Grooves in the primary is normal. Shouldn’t be too deep or be able to see where the ribs of the belt are hitting. Your clutches might not be aligned or torqued properly
turboedsupe is offline
post #11 of 12 Old May 30th, 2019, 01:13 PM Thread Starter
drifit86's Avatar
Member #265666
Originally Posted by turboedsupe View Post
Quit working on it and just take it to the dealer. Grooves in the primary is normal. Shouldnít be too deep or be able to see where the ribs of the belt are hitting. Your clutches might not be aligned or torqued properly
Thats all from yesterday... right now im fighting with the dealer trying to get it in theyre saying 3 weeks out but honestly it should be priority since its only week old. should have got a can am LMAO JK
drifit86 is offline
post #12 of 12 Old May 31st, 2019, 07:54 PM
DBRs1's Avatar
Member #257810
View DBRs1's Photo Gallery(0)
Primary issues are a real issue with the 19 model xpt and turbo s. I have first hand seen 2 in the past month from some friends units. One a 19 turbo s velocity with 13 miles and the other a 19 xpt2 with 30 miles. Both did the same thing. Primary clutch cover spider bearing failed. It the broke the plastic sliders in the primary on both machines. It also tossed that bearing around the case and beat up about everything. Both slipped the belt from day one. Both machines got taken care of under warranty and everything was replaced I will add. My advice is push your dealership to replace everything because it seems they updated something with the primary
ID:	577890   Click image for larger version
DBRs1 is offline
