Primary Clutch Bushing on 19 Turbo S (2 Seat) - Polaris RZR Forum - RZR Forums.net
 2Likes
post #1 of 23 Old April 20th, 2019, 11:01 AM Thread Starter
MattyB27's Avatar
First Name: Matthew
Member #69402
View MattyB27's Photo Gallery(0)
45 miles on machine and my primary Clutch Bushing (located around the center clutch nut) came off, ruined clutch cover, mangled the belt.
Anyone else experience this?
Here we go again with warranty!!
MattyB27 is online now
post #2 of 23 Old June 19th, 2019, 01:10 PM
MattZ96's Avatar
Member #270478
View MattZ96's Photo Gallery(0)
Re: Primary Clutch Bushing on 19 Turbo S (2 Seat)
Just purchased a 2019 Turbo S velocity on 6/15/2019 and had the same issues within 3 miles of the very first ride. Dealer has had the machine for the last 3 days and still haven't heard from them on what they are going to be doing about it.
What did your dealer and Polaris do to resolve the issue?
MattZ96 is offline
post #3 of 23 Old June 19th, 2019, 01:59 PM
True K30's Avatar
First Name: Michael
My RZR: 2018 Rzr Turbo S
Member #24498
View True K30's Photo Gallery(0)
Primary Clutch Bushing (located around the center clutch nut)
Is this a piece of the One Way Bearing? The roller bearing on the primary shaft between the clutch sheaves?
Or is this a piece of the bushing that goes in the primary clutch spider cover?
True K30 is offline
post #4 of 23 Old June 19th, 2019, 02:12 PM
MattZ96's Avatar
Member #270478
I finally got ahold of the dealer and Polaris knows about the issue and is just fixing the issue as it arises. Polaris is replacing both clutches, cover, seal, and the belt. I'm going to try to work them out of an extended warranty in case this happens again.
MattZ96 is offline
post #5 of 23 Old June 19th, 2019, 02:14 PM
True K30's Avatar
First Name: Michael
Member #24498
This bushing correct?
True K30 is offline
post #6 of 23 Old June 19th, 2019, 02:19 PM
MattZ96's Avatar
Member #270478
I am not 100% sure as I am a rookie in the Rzr world.
MattZ96 is offline
post #7 of 23 Old June 19th, 2019, 02:53 PM
Paulywood's Avatar
Member #1359
View Paulywood's Photo Gallery(0)
Happen to me, Caught it just in time before it let go. Still had to buy a whole new Primary...
Paul.
Paulywood is online now
post #8 of 23 Old June 19th, 2019, 03:00 PM
True K30's Avatar
First Name: Michael
Member #24498
Option to a whole new primary. If the primary itself was not damaged.
https://bikemanperformance.com/xp-tu...tch-cover.html
mikeham1 likes this.
True K30 is offline
post #9 of 23 Old June 20th, 2019, 12:23 PM
Max H's Avatar
First Name: Max
My RZR: 2018 XPT 2 seat
Member #16311
View Max H's Photo Gallery(0)
I have a 2018 XPT and when it only had a few hundred miles on it I installed the AA clutch kit. When I did this I noticed that the bushing / race inside the primary clutch cover was starting to work its way out about 1/3rd of the way .. towards the clutch cover. I carefully pressed it back in
The next time I opened and inspected it was coming out again. This time with the cover removed ...I heated the clutch cover evenly and carefully with a small torch and pressed it out about 75% of the way. I then added some green wicking grade bearing retainer like Loctite .. and while it was still warm pressed it back in carefully . ....make sure you dont go to far you dont want it to protrude out the back at all. When it is seated correctly it will protrude a little out the front flush or slightly recessed in the back. Since then I have about 800 miles on it and it has stayed in place it has not moved at all.
Max H is online now
post #10 of 23 Old June 20th, 2019, 06:29 PM
Highrider's Avatar
Member #54711
What about primary balance now that the parameters of the assembly have been changed?
2019 XP 1000 Trails and Rocks
Highrider is offline
post #11 of 23 Old June 20th, 2019, 07:02 PM
Max H's Avatar
First Name: Max
Member #16311
I maybe wrong but I always understood that the sheaves could be balanced together as a assembly ... but not the rest of the bolt on parts of the primary ....if they were then where do they remove weight ?
I don't think the primary balance from the factory ...if any ....would be that good ...that is more custom like Adam at Airdam or others ..Pol wouldn't spend that kind of time or money in production ...IMO
Max H is online now
post #12 of 23 Old June 24th, 2019, 07:32 PM
Ein
Ein's Avatar
First Name: Brian
My RZR: 2011 rzr xp900
Member #63079
View Ein's Photo Gallery(0)
I’m running the cyclone primary cover and it works great!
Ein is offline
post #13 of 23 Old June 28th, 2019, 09:11 AM Thread Starter
MattyB27's Avatar
First Name: Matthew
Member #69402
Sorry, just seeing this.....I called in a case # to Polaris, worked my way up the chain and got very persistent with them. Polaris sent (overnight) a brand new clutch assembly (to include cover, belt, and hardware) to my dealership. I believe I could have kept driving it since the purpose of the bushing is to balance the clutch as it gyrates in and out but due to the fact I opened a case # at Polaris they said I had to stop riding it and I didn't want to lose the warranty.
In the end it cost me time and aggravation but calling in a case # and being aggressive helped move it along. No issues on the 400+ miles since the fix.
Bad batch of bushings is my guess so it will be hit or miss for anyone else. I am curious why a recall/service bulletin hasn't come out on this issue.
Saga continues........
post #14 of 23 Old July 2nd, 2019, 08:13 AM
True K30's Avatar
First Name: Michael
Member #24498
I found the same thing on my 2018 XPT/S. I also still have very low miles on mine and the bushing was starting to work it's way out.
Before
After
True K30 is offline
post #15 of 23 Old July 2nd, 2019, 08:17 AM
Max H's Avatar
First Name: Max
Member #16311
Yep ....thats what they do ...good thing you checked it ...keep an eye on it ...shit design
Max H is online now
eBay: NEW STM Polaris RZR XP Turbo Rage 4 Primary Drive Clutch UTV Inc. UTV Inc 0 October 23rd, 2018 12:38 PM
Dalton clutch kit, my take Katnapper RZR 570 Specific Discussion 71 September 29th, 2018 07:07 AM
Primary clutch cover bushing longtravel05 RZR XP Turbo 3 October 2nd, 2017 12:05 AM
rzr 1000 seats charlie78 RZR 570 Specific Discussion 7 September 16th, 2016 06:11 AM
Twisted Stitch RZR Seats In Stock - 03/15 UTV Inc. UTV Inc 10 March 31st, 2016 09:15 AM
