35" Tires? - Polaris RZR Forum - RZR Forums.net
 27Likes
post #1 of 84 Old February 1st, 2019, 09:23 PM Thread Starter
lcharlot65's Avatar
First Name: Larry
My RZR: 2018 RZR Turbo S
Member #180729
View lcharlot65's Photo Gallery(0)
35" Tires?
I am pulling the trigger on the Coyote 35" tires. They ship end of February. weight is 51 lbs.
Thinking I will need a clutch kit as well, anybody running bigger heavier tires? how is it working out for you.
lcharlot65 is offline
post #2 of 84 Old February 2nd, 2019, 05:40 PM
DBRs1's Avatar
Member #257810
View DBRs1's Photo Gallery(0)
At 51 pounds if you are running the stock wheels you wI'll be around 65-66lbs wheel and tire combo. And substantially taller. I would say yes you will most likely need clutching and if it was me invest in some gear reduction to help the clutching and power loss. As well as some axle upgrades. 65-70 pounds of rotational mass is now into truck territory and requires some pretty heavy parts to hold up. 35s will definitely find your weak links quickly.
DBRs1 is offline
post #3 of 84 Old February 2nd, 2019, 09:40 PM
Heily300's Avatar
Member #255049
View Heily300's Photo Gallery(0)
Re: 35" Tires?
Belts belts & more belts
Heily300 is offline
post #4 of 84 Old February 2nd, 2019, 10:26 PM Thread Starter
lcharlot65's Avatar
First Name: Larry
Member #180729
Re: 35" Tires?
6lbs more per wheel is that big of a deal? They still weigh less than 32" rocktanes
post #5 of 84 Old February 2nd, 2019, 10:42 PM Thread Starter
lcharlot65's Avatar
First Name: Larry
Member #180729
Re: 35" Tires?
OK, changing mind and going with the 33", they weight less than half a pound more and are 33.8 tall and 10.7 wide. won't have to worry (as much). They don't come in till end of February and will be ordering Monday.
post #6 of 84 Old February 2nd, 2019, 10:44 PM
DBRs1's Avatar
Member #257810
50-60lbs per corner is a very common weight for a 32" wheel tire setup. Now add 5-10 pounds to that with a 35 and add 3 more inches of height to the equation and you have a recipe for broke parts. I used to run 35s on most of my 80s toyotas back in the day and i could break parts at any point if I wanted. And those had twice the size of parts as a rzr. And that's with a 4 cylinder that makes the same hp as a 1000xp. I do c that companies are now making 35" tires but I just don't c how these machines will handle it. Sure if you want to cruze around Moab or something they may work. But put them in the east coast and it's going bust things quickly. Everything is way way too small for a tire that size. Unless you do gear reduction, clutch kit, and axles I wouldn't run 35s. 32s will get you anywhere so I just don't c the need and the headache. But hey it's your money. Give it a shot and let us know how it works
JDenton929 likes this.
DBRs1 is offline
post #7 of 84 Old February 2nd, 2019, 10:46 PM
DBRs1's Avatar
Member #257810
33s would be way better. Are you east or west coast riding?
DBRs1 is offline
post #8 of 84 Old February 2nd, 2019, 10:55 PM Thread Starter
lcharlot65's Avatar
First Name: Larry
Member #180729
Re: 35" Tires?
West Coast. Eastern Washington mostly hardpack and snow, but do go to the wet west side once in a while.
Max H likes this.
post #9 of 84 Old February 2nd, 2019, 11:04 PM
DBRs1's Avatar
Member #257810
Was watching utv qualifying for Koh today and in the 30 mins I watch it 2 cars on 35s broke front diffs. Now these are fully build 50-80000 dollar rzrs and canams with the best parts money can buy. Just goes to show if you push one of these rigs on 35s it's going to bust stuff left and right. I would check out the 32" maxxis roxxzilla. Absolutely awesome tire in the rocks and hard pack. It's what I have ran on a few rigs the past year or so. I ride mainly Tennessee and west Virginia so our terrain is a little different. But I c a bunch of cars at Koh this year running the roxxzilla as well. If u are stuck on 33s go for it. Just really keep the weight of everything you put on your car in mind because in some way shape or form it will have a direct effect on something. Rotational and unsprung weight is a very over looked component and has drastic effects on suspension, steering and drivetrain.
lcharlot65 and Collom4 like this.
DBRs1 is offline
post #10 of 84 Old February 4th, 2019, 09:14 AM
RZR_Joe's Avatar
Member #23438
Feedback Score: 6 reviews
One of the problems is gearing, the 17s we're the last year of decent gearing. On 18+ models low gear was raised about 30%. As mentioned by DBR, rotational mass and unsprung weight because a huge issue with larger tires. When you get to a 35" tires stuff gets real, real fast. At that point basically everything needs to be upgraded to HD parts to handle the additional stress. Suspension components, steering, frame bracing, drivetrain, ball joints, shocks, etc...the list gets long and expensive. It can be done but understand you just don't slap on big tires and expect not to break stuff.
RZR_Joe is offline
post #11 of 84 Old February 4th, 2019, 09:11 PM
Riverguy553's Avatar
First Name: Scott
My RZR: 2019 Turbo 4S
Member #34623
View Riverguy553's Photo Gallery(0)
Re: 35" Tires?
I’m putting the BFG “10 car tire” on a vision beadlock wheel. I will weigh them and let everyone know the difference. I don’t think the weight is going to be much more. My friend has it on his 2016 and did a spring and shock valving change and all I can tell you is what a difference.
Riverguy553 is offline
post #12 of 84 Old February 4th, 2019, 09:53 PM
DBRs1's Avatar
Member #257810
The class 10 bfg looks interesting. It's definitely very skinny. I would hope that leads to less weight in the tire. Looks like a strictly desert tire and would b pretty bad on East coast. Most race teams say that once 33+" tires are put on they gear the transmission way down to compensate. I would be extremely concerned of a 35 on a stock transmission gear set. Pretty sure that even with a clutch kit you could not get your peak rpms without gear reduction. As stated B4 once you go 35s shit will get real extremely fast on what the weak link is.
DBRs1 is offline
post #13 of 84 Old February 4th, 2019, 10:10 PM Thread Starter
lcharlot65's Avatar
First Name: Larry
Member #180729
Re: 35" Tires?
I ended up getting the 33's, they way .3 lbs more than stock 32. Thanks for all the feedback.
post #14 of 84 Old February 4th, 2019, 10:16 PM
DBRs1's Avatar
Member #257810
Awesome. Let us know how they work out!
DBRs1 is offline
post #15 of 84 Old February 5th, 2019, 07:53 PM
Bboyter's Avatar
First Name: Brandon
My RZR: '16 XP1k
Member #24560
View Bboyter's Photo Gallery(0)
Re: 35" Tires?
What brand tire in 33’s and what size wheel you running?
Bboyter is offline
35" Tires with only Bracket Lift yamahafx4 RZR XP 1000 High Lifter Edition 9 August 20th, 2017 04:29 PM
Going to Baja on GMZ tires. NIKAL Wheels and Tires 23 September 21st, 2015 07:50 PM
My Sand Tire Experience VailAve General RZR Discussion 3 September 7th, 2013 11:36 AM
LT tires, or Trailer tires... Whats best ? allcool Tow Rigs, Trailers and Camping 19 April 17th, 2012 12:03 PM
Pit Bull Growler Tires Part 2 LouDiamond Wheels and Tires 41 October 18th, 2010 09:09 PM
