Suspension sag - Polaris RZR Forum - RZR Forums.net
 10Likes
post #1 of 48 Old January 22nd, 2019, 06:14 PM Thread Starter
Jerdawg1's Avatar
Member #254433
View Jerdawg1's Photo Gallery(0)
Suspension sag
Over the weekend I measured my ride height and found that the vehicle had sagged from its 16” ride height to 11”. I adjusted the spring collars front and rear to bring the ride height back up to 16” (from the ground to the skid plate). I looked at the springs today and noticed that the smaller top springs have now collapsed to near bind. Has this happened to anyone else. Besides Shock Therapy where else should I turn?
ID:	569574   Click image for larger version
Jerdawg1 is offline
post #2 of 48 Old January 22nd, 2019, 06:26 PM
RZR_Joe's Avatar
Member #23438
Feedback Score: 6 reviews
Re: Suspension sag
Search function
RZR_Joe is offline
post #3 of 48 Old January 22nd, 2019, 06:28 PM
quadfather171's Avatar
First Name: mark
My RZR: 2018 rzr xp turbo
Member #222482
View quadfather171's Photo Gallery(0)
Re: Suspension sag
yes it has happened to everyone. there are many kits out there, but shock therapy is the most popular,
quadfather171 is offline
post #4 of 48 Old January 22nd, 2019, 07:00 PM Thread Starter
Jerdawg1's Avatar
Member #254433
When I go out in 2weeks will the ride be ok or rough?
Jerdawg1 is offline
post #5 of 48 Old January 23rd, 2019, 05:04 PM
martybmw's Avatar
Member #15629
View martybmw's Photo Gallery(0)
Re: Suspension sag
My rear is also low at 14" with all the weight I have added. I can't tell from the picture how you can tell that you are near collapse with the springs. How do you judge that?
thanks
martybmw is offline
post #6 of 48 Old January 23rd, 2019, 07:26 PM
craigstumph
craigstumph's Avatar
My RZR: RZR 1000
Member #59177
Re: Suspension sag
Originally Posted by Jerdawg1 View Post
Over the weekend I measured my ride height and found that the vehicle had sagged from its 16 ride height to 11. I adjusted the spring collars front and rear to bring the ride height back up to 16 (from the ground to the skid plate). I looked at the springs today and noticed that the smaller top springs have now collapsed to near bind. Has this happened to anyone else. Besides Shock Therapy where else should I turn?
I have Eibach springs. True dual rate with stop nuts. Please send me a PM if interested.
Call or Text 801 367 1395
www.proutvparts.com
craigstumph is offline
post #7 of 48 Old January 24th, 2019, 07:15 AM Thread Starter
Jerdawg1's Avatar
Member #254433
There is no air gap between the upper aping coils. They are in a state of bond. All they are currently doing is acting as a spacer at this point.
Jerdawg1 is offline
post #8 of 48 Old January 24th, 2019, 09:27 AM
sand shark's Avatar
First Name: Noel
My RZR: XP1000
Member #23358
View sand shark's Photo Gallery(0)
Re: Suspension sag
That top spring is just a helper spring. It really is not doing much as the stock set up is not a true dual rate set up. A dual rate spring kit with the right spring rates and crossover rings would do wonders for the Turbo S. The suspension in stock form is pretty damn good, but a really good spring kit will help out.
sand shark is online now
post #9 of 48 Old January 24th, 2019, 09:35 AM
craigstumph
My RZR: RZR 1000
Member #59177
Re: Suspension sag
Turbo S Eibach Dual Rate springs with stop nuts for cross overs is due out next week (1-30-19). Let me know if you want them. Eibach is made in USA and build top notch springs. Eibach are better springs than comes from Polaris on their machines. Improved ride and bottoming resistance without sagging after time.
www.proutvparts.com
post #10 of 48 Old January 27th, 2019, 06:18 PM
jRZRj's Avatar
Member #260116
View jRZRj's Photo Gallery(0)
Re: Suspension sag
What setting do you set ride height ?
Sent from my Pixel 2 using Tapatalk
jRZRj is offline
post #11 of 48 Old January 27th, 2019, 06:32 PM Thread Starter
Jerdawg1's Avatar
Member #254433
Measure from the ground to the bottom of the skid plate front and rear. Front 16.5”. Rear 16”
RzrDan13 likes this.
Jerdawg1 is offline
post #12 of 48 Old January 28th, 2019, 07:23 AM
jRZRj's Avatar
Member #260116
Re: Suspension sag
I was wondering what suspension setting you use
jRZRj is offline
post #13 of 48 Old January 29th, 2019, 07:01 AM
mp350's Avatar
My RZR: 2015 XP1K VooDoo Blue
Member #36883
View mp350's Photo Gallery(0)
Re: Suspension sag
Measure from the ground to the bottom of the skid plate front and rear. Front 16.5. Rear 16
Where is that measurement coming from? Is it from Polaris/manual?
2015 XP1000 VooDoo Blue
Twisted Stitch Vortex with heaters, Crow 2" harnesses, 2' Alba wheel spacers, Fineline Suspension revalved rear shocks and re-sprung fronts, 30" Radius LED light bar and lots more to come. As soon as the checkbook recovers
SOLD;2012 Orange Madness XP-LE
29x10x14 Mongrels, 14x7 Method's, Twisted Stitch Heated/Suede Revolvers, SuperATV Arched 1.5 forward a-arms, Walker Evans Needle converted shocks, BMP Hot Rod Exhaust with header, Double Down Intake, PC5 and a bunch more
mp350 is offline
post #14 of 48 Old January 29th, 2019, 11:06 AM Thread Starter
Jerdawg1's Avatar
Member #254433
Re: Suspension sag
SXSBLOG stated the ride hieght. They got their info from SHOCK THERAPYST.
mp350 likes this.
Jerdawg1 is offline
post #15 of 48 Old June 9th, 2019, 06:21 PM
Soupys Performance's Avatar
Member #267728
View Soupys Performance's Photo Gallery(0)
What is everyone using for stock suspension settings? Ground clearance is a few inches low on my machine. Obviously I can spend $2-5G on upgrades but I'm wondering what's the best setup with stock parts? Just crank up the preload? That's really the only option, right? Is coil bind a concern with enough added preload? 2019 TS4 with about 100lbs added. I'd prefer to set it up for duning/trail riding.
AZNorseman likes this.
Soupys Performance is offline
5 Ways To Improve Your Polaris RZR Suspension VS_Goose Polaris RZR News 24 October 20th, 2017 12:59 PM
Racer Tech Partners with Elka Suspension for 2015 RT PRO RT PRO UTV 1 April 19th, 2015 05:39 PM
Shock Absorber Edjumacation. rpfeiff General RZR Discussion 19 April 26th, 2012 10:48 AM
Adjusting S Suspension for desert FastEddie760 Suspension 3 April 27th, 2010 11:31 AM
