Heated seats - Polaris RZR Forum - RZR Forums.net
 3Likes
  • 1 Post By KY-Rider
  • 1 Post By RMR Man
  • 1 Post By Clothier
post #1 of 11 Old November 18th, 2018, 07:09 AM Thread Starter
jeremysj71's Avatar
Member #261310
View jeremysj71's Photo Gallery(0)
Heated seats
Has anyone heated there factory seats? If so what kit did you use? Thanks in advance for the replys
jeremysj71 is offline
post #2 of 11 Old November 18th, 2018, 02:11 PM
Dstew619's Avatar
My RZR: 2017 Turbo XP4
Member #174273
Re: Heated seats
Rocky Mountain has a very simplistic and good set for a great price. Check on there.
Dstew619 is offline
post #3 of 11 Old November 18th, 2018, 05:08 PM
RMR Man's Avatar
First Name: Steve
Member #11566
Re: Heated seats
Yes, 2 RZRs with factory seats. Amazon. Anything that is no larger than your seat dimensions. One of mine has a high-off-low setting, the other has a 9 position thumb wheel switch. Both were under $75, for 2 seat bases, seat backs, relay, switch and wiring harness. Both work fantastic!
RMR Man is offline
post #4 of 11 Old November 18th, 2018, 06:27 PM
KY-Rider's Avatar
My RZR: 2018 1000XP High Lifter
Member #255129
View KY-Rider's Photo Gallery(0)
Re: Heated seats
https://www.amazon.com/dp/B01M635R9A...3920290_dpLink
Installed these in my Factory XP1K HL edition. Easy install , I
actually broke the " do not bend or fold" rule for the uppers with no problems so far
mwcwood likes this.
KY-Rider is offline
post #5 of 11 Old November 18th, 2018, 07:07 PM
RMR Man's Avatar
First Name: Steve
Member #11566
Re: Heated seats
I forgot to say, that I bought a pneumatic stapler gun to reattach the upholstery to the hard plastic seat innards. You may be able to get by with a T-50 Swingline, but I was doing 4 seats, and it wound up being like 200 staples. That was a very wise purchase! Something in the neighborhood of $90, and I have used it on other projects since then.
RMR Man is offline
post #6 of 11 Old November 18th, 2018, 08:03 PM
Medi0gre's Avatar
Member #256750
View Medi0gre's Photo Gallery(0)
Re: Heated seats
Do you think there would be any issues getting them wet?
Sent from my SM-G930W8 using Tapatalk
Medi0gre is offline
post #7 of 11 Old November 19th, 2018, 06:07 AM
Hvlrgr's Avatar
Member #85491
View Hvlrgr's Photo Gallery(0)
Re: Heated seats
I did the kits from rocky mountain atv on our four seater...two rides , two washes so far so good. Everybody loves the kits! Hi/Lo/Off rocker gets very toasty.
I'd second the pneumatic stapler...well worth it to put stuff back together. gets some dielectric grease for the fittings should help with H20 too...
Hvlrgr is offline
post #8 of 11 Old November 19th, 2018, 06:30 AM
RMR Man's Avatar
First Name: Steve
Member #11566
Re: Heated seats
Never sunk my machines, but I'm pretty thorough with the pressure washer after a ride. The newer Polaris machines have a waterproof membrane between the upholstery and the foam padding. The heaters go under the membrane, so they don't get wet. I don't see any issues with failure from water, unless you leave your ride out in the rain all the time.
Medi0gre likes this.
RMR Man is offline
post #9 of 11 Old November 19th, 2018, 07:14 AM
Rocky_Top's Avatar
First Name: Bradley
My RZR: 2018 Polaris RZR 1000 XP
Member #80320
View Rocky_Top's Photo Gallery(0)
Re: Heated seats
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
I just installed these last week in my 2018 RZR. They seem to heat up nicely have not been out on the trails yet. my only concern is the switch and how it we hold up to water.
Rocky_Top is offline
post #10 of 11 Old November 19th, 2018, 07:37 AM
Clothier's Avatar
First Name: Brian
Member #65577
Re: Heated seats
I have the carbon fiber kit with the round 3 position hi/off/low switches. They were installed by the previous owner. Have worked great for 5+ years now. I pressure wash machine after every ride. I do let the connections dry or blast them with an air hose after washing before turning them back on. But I'm sure there may have been a time or 2 that I didn't. I also pressure wash the seats, but I take care not to hit the underside on the cushion, again I'm sure they have gotten damp at some point, like when my wife and I crossed a creek that was a bit deeper than expected! Lets just say our butts were under water! And the heaters were in use at the time! The switches and the bottom of the seats were under water briefly, but to my surprise the seat heaters never stopped working. That was over a year ago. I did however replace the quick disconnects on the heating pads just a few weeks ago. After 5+ years of hooking/unhooking and taking the seats in and out of the machine, the wires were fraying and breaking where they went into the connectors. Which caused a short circuit and a blown inline fuse. I also have had the switches get sticky and not want to make contact, I use compressed air to blow them out and that seems to fix the problem for a while. Other than those couple of things they have worked great and have made the cold weather riding possible!
And I 3rd the pneumatic stapler! A great investment even if you only use it once. I purchased 1 back when I rode mx bikes, a total pain to try to staple seat covers to the plastic seat pan! The air stapler made it super easy. Can't count how many friends and friends of friends have borrowed it!
Rocky_Top likes this.
Clothier is online now
post #11 of 11 Old November 19th, 2018, 09:05 AM
WB800BLASTER's Avatar
My RZR: 2016 XPT
Member #161889
View WB800BLASTER's Photo Gallery(0)
Re: Heated seats
i went to local audio installer that does them. $ 150 installed in the seats, quick releases add to the seats so i take them right out. I wired them to XPT as i wanted to do that part. Low High and bottom and top of seats.
Love it and recommend it. nothing like a night ride in snow with heated seats. No issues so far
WB800BLASTER is offline
Twisted Stitch & PRP Seats In Stock ! UTV Inc. UTV Inc 33 August 8th, 2017 11:35 AM
Heated seats for 2014 RZR1K mtnmauler Ask Vendors 3 December 5th, 2014 09:05 AM
Heated seats madmedic22 General RZR Discussion 16 December 20th, 2013 06:13 AM
Anyone do heated seats on xp1k?? st222 RZR XP 1000 5 November 20th, 2013 07:15 PM
Heated seats ventracing General RZR Discussion 17 January 10th, 2012 10:43 AM
