Shock Therapy Turbo S - Polaris RZR Forum - RZR Forums.net
 3Likes
post #1 of 29 Unread September 24th, 2018, 01:47 AM Thread Starter
Buckeye Fan's Avatar
First Name: Brad
My RZR: 18 TURBO S
Member #74302
View Buckeye Fan's Photo Gallery(0)
Can anyone help me? I did Shock Therapy full spring kit on my Turbo S. I gained ride height back but it rides much stiffer now and not a smooth.
Buckeye Fan is offline
post #2 of 29 Unread September 24th, 2018, 06:44 AM
RickRou56's Avatar
My RZR: 2017 XPT Velocity Blue
Member #28887
View RickRou56's Photo Gallery(0)
Re: Shock Therapy Turbo S
Hey Brad, good to see you got the beast out. HMT?
Have you done the Tire pressure thing? Lower.
Looks like your crossover ring can go up quite a bit.
I have a XPT and mine are near the top on my fronts. These big Fox Shocks have some pretty stout springs.
For soft ride I’d try moving them way up and you can start bringing them down in 1/2” increments if you want to stiffen it up for cornering etc.
plus you have the Dynamix option to use on the fly to stiffen it.
So go a little soft on the crossovers and use Dynamix for immediate option to stiffen it up if needed.
Give it a try.
RickRou56 is offline
post #3 of 29 Unread September 24th, 2018, 07:33 AM
sandblster's Avatar
Member #46247
Do the shock settings show as 0 on the dash when sitting still and go up as you change the settings on dash? Something not right. Shock Therapy springs on my 18 Dynamix made a world of difference all for softer better ride. Did you get the correct springs for the weight you carry? Are all your shocks plugged back in? Did you have the dash off and pull the plug on ride command loose. No way should you be experience harder rides.
sandblster is offline
post #4 of 29 Unread September 24th, 2018, 10:08 AM Thread Starter
First Name: Brad
My RZR: 18 TURBO S
Member #74302
The dash is working just as it should. Shows 0 when in comfort and adjusts somewhat when the terrain changes.
post #5 of 29 Unread September 24th, 2018, 10:17 AM
sandblster's Avatar
Member #46247
Looking at your picture the limit strap is to short. See the bump stop you pushed up, it has not been pushed back down by shock action. Did you put the limit strap on at the same time? Take the limit straps loose and try it. For sure the front shock are not working as they should if this was taking after you have run it. How about a picture of the rear.
I do not see a jack under it so I assume this is setting as you would ride it. The limit strap is a difficult problem if so. It is limiting the front shock to maybe an inch of travel and hit hard on the strap. Would think that would indeed cause a harsh ride.
post #6 of 29 Unread September 24th, 2018, 11:13 AM Thread Starter
First Name: Brad
My RZR: 18 TURBO S
Member #74302
The jack is under the center of the machine you can kinda see in the pic. This is when I first installed and machine hadn’t been let down off the jack. There’s a lot of space in the limit strap now. I can jack it up to the wheels are almost off the ground before the limit strap hits.
post #7 of 29 Unread September 24th, 2018, 11:43 AM
sandblster's Avatar
Member #46247
OK. Something else is not right. How about pictures now of front and back shocks. You are not telling us a lot other then pour ride after new springs. Anything else done at the same time? Again, how much air pressure now and before. If nothing else give Shock Therapy a call. They are the experts. Are you riding in the same area both times.
We rode in wet sand last winter, got use to the ride. Come spring/summer sand dried out and the ruts got a lot deeper. Daughter thought something wrong with her suspension. The sand being dry and loose allowed deeper digging and more sand displacement making bigger bumps. There is a night and day difference before and after on my 18 Dynamix with Shock Therapy Springs. You should experience the same thing.
post #8 of 29 Unread September 24th, 2018, 11:57 AM Thread Starter
First Name: Brad
My RZR: 18 TURBO S
Member #74302
I’m going to give them a call. Everyone says night and day difference and even my fiancée said it rides rougher. Same riding area both trips. The only thing I did was the springs and limit straps. Tire pressure is the same and everything. I used to notice a drastic change going from firm to comfort and not I notice just a slight difference.
post #9 of 29 Unread September 24th, 2018, 12:09 PM
sandblster's Avatar
Member #46247
Double and triple check the plug in on top of each shock to be SURE they are all seated correct.
RickRou56 likes this.
post #10 of 29 Unread September 24th, 2018, 01:44 PM Thread Starter
First Name: Brad
My RZR: 18 TURBO S
Member #74302
Trust me they are. I forgot to plug one in when I reinstalled and I got an immediate error on my ride commend. I watch the shocks adjust as we go down the trail. The dynamix is working correctly.
post #11 of 29 Unread September 24th, 2018, 02:16 PM
sandblster's Avatar
Member #46247
OK, then my money is the wrong springs for what ever reason. Think they have ID numbers on them. Might get the numbers, be sure they are the same for both sides so you can compare with what they wanted to send you. Front and Rear different naturally. And are you sure the ride height is per Shock Therapy instructions?
post #12 of 29 Unread September 24th, 2018, 02:48 PM
auburnu008's Avatar
Member #102281
View auburnu008's Photo Gallery(0)
I have the ST spring kit and revalve on my S and it is noticeably better. I have other guys in our group with S's and we have swapped machines during rides and it is definitely an improvement. Something isn't right.
auburnu008 is offline
post #13 of 29 Unread September 24th, 2018, 04:01 PM Thread Starter
First Name: Brad
My RZR: 18 TURBO S
Member #74302
We ride the same places. I didn’t do the valve just the spring kit. Where are your crossovers set? Wonder if mine are too low and riding on the lower spring too much? Is 16”ground clearance what you have up front?
post #14 of 29 Unread September 24th, 2018, 04:03 PM Thread Starter
First Name: Brad
My RZR: 18 TURBO S
Member #74302
Yep I went off of their website. It actually said 16.5” front and 16” rear. I’m about .5” lower but I was tired of messing with it. There isn’t really instructions on setting up the crossovers. Their measurement has my crossover about .5” from the spring dividers so i moved them up a few inches.
post #15 of 29 Unread September 24th, 2018, 05:01 PM Thread Starter
First Name: Brad
My RZR: 18 TURBO S
Member #74302
When I go faster it rides smoother. If that helps?
Shock Therapy or ZBrozs DaveT1 Suspension 15 August 15th, 2017 03:51 PM
2016 xp turbo fox bypass shocks w/ shock therapy stage 4 ris kit Harts UTV Polaris RZR Parts For Sale 1 February 22nd, 2017 05:08 PM
Shock Therapy CEP 341 RZR XP Turbo 3 January 19th, 2017 03:36 PM
Long Travel or Shock Therapy SoonerNation RZR XP 4 Turbo 14 April 28th, 2016 06:29 AM
Shock Therapy Dual Rate Spring Kit (DRS) S 900 2015 MrThor Polaris RZR Parts For Sale 8 February 4th, 2016 07:25 PM
