Walker Evans Shock Links - Polaris RZR Forum - RZR Forums.net
 10Likes
post #1 of 24 Old June 10th, 2018, 07:50 PM Thread Starter
auburnu008's Avatar
Member #102281
View auburnu008's Photo Gallery(0)
Anyone put these on a S yet? I know you have to remove the shock guards for them to fit but just wondering which ones are needed and make sure I order the correct version. I assume the spacing is the same for the regular turbo?
True K30 likes this.
auburnu008 is online now
post #2 of 24 Old June 11th, 2018, 12:06 PM
duramaxdrew's Avatar
Member #195505
View duramaxdrew's Photo Gallery(0)
Re: Walker Evans Shock Links
Following for updates.
I wish the ORO electric disconnect could work on the turbo S. Expensive but in my opinion worth every penny.
duramaxdrew is online now
post #3 of 24 Old June 12th, 2018, 06:37 AM
GimpyRZR's Avatar
Member #208177
View GimpyRZR's Photo Gallery(0)
If they become available, I would guess the boss FJK would be the first? He gets all the good stuff. The S has more suspension travel, so my guess is they don't have anything available yet or he would have them by now?
GimpyRZR is offline
post #4 of 24 Old June 12th, 2018, 07:22 AM
FJK's Avatar
First Name: Frank
Member #8689
Feedback Score: 18 reviews
View FJK's Photo Gallery(279)
Hi guys ,on my way home from HAWAII, I will check mine when I get in tomorrow, I donít think the sets of Walker Evans links I have will be long enough to work on my S but I will check and get back to you all .
UtahMarv, GimpyRZR and Collom4 like this.
FJK is offline
post #5 of 24 Old June 12th, 2018, 08:09 AM
RickRou56's Avatar
My RZR: 2017 XPT Velocity Blue
Member #28887
View RickRou56's Photo Gallery(0)
Call Reid Nordin @ Walker Evans Racing.
Or email him. He was instrumental in developing these in the first place.
Itís likely heís working on a S set already.
He got back to me the same day when I emailed him regarding the ones for my XPT.
[email protected]
auburnu008 likes this.
RickRou56 is online now
post #6 of 24 Old June 12th, 2018, 11:14 AM
Denver, CO - 303-400-0205
American Rock Rods's Avatar
First Name: Chris @ ARR
Member #25882
View American Rock Rods's Photo Gallery(0)
The lengths between the standard XP1000/XPT rear link and the Turbo S rear link are close enough that the walker links would work, however the bolts have been upgraded to 12mm from 10mm, so new spacers are needed.
auburnu008 and Collom4 like this.
Chris @ ARR
303-400-0205-shop #
We are Colorado's Premier UTV Parts/Accessory shop!
American Rock Rods is offline
post #7 of 24 Old June 12th, 2018, 11:19 AM Thread Starter
auburnu008's Avatar
Member #102281
I called Walker Evans and they have them for the S but are having to change the mounting on them. I got the order placed and they are shipping out. You just have to call since they are not on the website yet.
duramaxdrew likes this.
post #8 of 24 Old June 12th, 2018, 08:54 PM
lcharlot65's Avatar
First Name: Larry
My RZR: 2018 RZR Turbo S
Member #180729
View lcharlot65's Photo Gallery(0)
for front and rear?
lcharlot65 is offline
post #9 of 24 Old June 12th, 2018, 08:56 PM Thread Starter
auburnu008's Avatar
Member #102281
Originally Posted by lcharlot65 View Post
for front and rear?
They only make them for the rear.
lcharlot65 likes this.
post #10 of 24 Old June 13th, 2018, 08:09 AM
craigstumph
craigstumph's Avatar
My RZR: RZR 1000
Member #59177
I have the Walker links if you want them that fit the RZR S. PM for info.
Call or Text 801 367 1395
www.proutvparts.com
craigstumph is offline
post #11 of 24 Old June 14th, 2018, 10:11 AM
Member #25882
for front and rear?
They make them for the front of the standard XP1K/XPT, I have a set on my car.
The OEM front links are 157mm long for both XPT and XPTS, but just like the rear of the XPTS, the bolts are 12mm instead of 10mm. You just need to order front links with the correct spacers.
Chris @ ARR
303-400-0205-shop #
post #12 of 24 Old February 10th, 2019, 07:46 AM
lcharlot65's Avatar
First Name: Larry
Member #180729
I ordered a set last night from your website, then heard back from Walker Evans. They said they recommend one front one rear and that the fronts are shorter. Hopefully you can send one of each or cancel the order. Thanks
post #13 of 24 Old February 10th, 2019, 07:58 AM
RickRou56's Avatar
Member #28887
Regarding only using one.
I have done that and it does work but the overall ride improvement and articulation is not the same. About 75%.
When I Emailed with Reid Nordin from WER he said his race teams use one. Which in that environment is perfect.
He was instrumental in developing this product.
But for ride quality etc. that using two its another step better in comfort and articulation.
Unless my communication with him over a year ago has changed.
I would recommend 2 and 2 if youíre a recreational rider and wanting ride quality along with articulation benefits.
Just a thought.
post #14 of 24 Old February 10th, 2019, 08:02 AM
lcharlot65's Avatar
First Name: Larry
Member #180729
This was per Reid Nordin last night.
Just a thought.
post #15 of 24 Old February 10th, 2019, 08:10 AM
RickRou56's Avatar
Member #28887
I understand.
In my case when I played with one versus two there was another level of usefulness/comfort with two. Since Iíve had 2 and 2 all along Iíve played with them initially with one installed front and one rear.
Perhaps they....WER have taken another approach on how they valve them or do the benefits add up for the extra expense.
I do agree 1 is much better than none.
No debate there.
Rear Sway Bar Shock by Walker Evans craigstumph Pro UTV Parts 320 June 29th, 2018 03:41 PM
Walker Evans sway bar shock links moneypit RZR XP Suspension 69 January 3rd, 2017 01:30 PM
Racertech Dual Rate springs for 2.5" shock (XP900 walker evans) M1AHD Polaris RZR Parts For Sale 9 May 17th, 2016 12:40 PM
