34 inch tires - Polaris RZR Forum - RZR Forums.net
 12Likes
post #1 of 41 Old May 26th, 2018, 03:19 PM Thread Starter
duramaxdrew's Avatar
Member #195505
View duramaxdrew's Photo Gallery(0)
34 inch tires
Does anyone know if you can clear 34 inch tires on the turbo S without any rubbing? Was looking at the new sticky warrior RT warriors.
lcharlot65 likes this.
duramaxdrew is offline
post #2 of 41 Old May 26th, 2018, 05:14 PM
lcharlot65's Avatar
First Name: Larry
My RZR: 2018 RZR Turbo S
Member #180729
View lcharlot65's Photo Gallery(0)
Re: 34 inch tires
looks like the tires only come in 14". Turbo S is 15"
lcharlot65 is offline
post #3 of 41 Old May 27th, 2018, 08:20 AM
Mxsledder's Avatar
Member #241402
View Mxsledder's Photo Gallery(0)
I’ve been told by numerous dealers 14” wheels will work. I bought a set of paddles with 14’s but haven’t been able to use them yet.
duramaxdrew likes this.
Mxsledder is offline
post #4 of 41 Old May 27th, 2018, 02:09 PM Thread Starter
Member #195505
Re: 34 inch tires
Not worried about the wheel size. Questioning if the tires will rub or not?
post #5 of 41 Old May 27th, 2018, 02:17 PM
BAMAWHISTLER's Avatar
My RZR: 2016 900S
Member #226706
View BAMAWHISTLER's Photo Gallery(0)
Re: 34 inch tires
that rascal has room for 36" tarrs, bolt them up and send it!
2016 900 S White Lightening, 4500lb winch, ProBox top, front and rear windshields, spring brake thingy, full doors, Kemimoto door bags, brush guards, rock sliders, SuperATV rear cab frame bars, fire extinguisher, sway bar deleted, Bandit Springs, 30" Kahunas, 15" Quadboss Scovilles, AA S2 clutch kit, SS250 filter magnet
BAMAWHISTLER is offline
post #6 of 41 Old May 27th, 2018, 05:54 PM
Ron.S's Avatar
First Name: Ron
My RZR: 2019 XP 1000 Ride Command
Member #160905
View Ron.S's Photo Gallery(0)
Re: 34 inch tires
The issue with 14’s is the clearance with brakes will be very tight and a place for gravel/debris to stick and cause damage. I’d do more checking, there is some info available.
Ron.S is offline
post #7 of 41 Old May 27th, 2018, 06:00 PM
My RZR: 2016 900S
Member #226706
Re: 34 inch tires
You could run spacers. Or just get bigger wheels and some other kind of tarrs
post #8 of 41 Old May 27th, 2018, 10:11 PM Thread Starter
Member #195505
Re: 34 inch tires
Originally Posted by Ron.S View Post
The issue with 14s is the clearance with brakes will be very tight and a place for gravel/debris to stick and cause damage. Id do more checking, there is some info available.
I already took the new mud scrapers off the fronts to fit the keller ball joints. The rear mud scrapers I took off as well after seeing issues with them cracking wheels on canams. It seems without those installed the rest of the brakes etc are identical to a rzr turbo that runs 14s correct?
post #9 of 41 Old May 29th, 2018, 02:42 PM
Ron.S's Avatar
First Name: Ron
Member #160905
Re: 34 inch tires
Sorry, I was just passing on info Id read. Im waiting until the Dealer meeting to decide on 18 or 19. You are probably right about the mud scrapers.
Ron.S is offline
post #10 of 41 Old May 29th, 2018, 03:35 PM Thread Starter
Member #195505
Re: 34 inch tires
No worries brother! I appreciate the input! I ended up going with the 33 mrt Rockys
post #11 of 41 Old May 29th, 2018, 06:23 PM
Buckeye Fan's Avatar
First Name: Brad
My RZR: 18 TURBO S
Member #74302
View Buckeye Fan's Photo Gallery(0)
Re: 34 inch tires
Can you post pics when you get them on? What size wheel?
Buckeye Fan is offline
post #12 of 41 Old May 29th, 2018, 06:35 PM Thread Starter
Member #195505
Re: 34 inch tires
Will do. 16x7 inch custom sized beadlocks 5-2 offset. Should put me 1 inch or so wider than stock. The 33 MRT is 44 lbs just like the stock itp coyotes. Probably and extra 5lbs or so per corner due to the beadlocks being heavier than the stock wheels.
post #13 of 41 Old June 2nd, 2018, 08:16 AM Thread Starter
Member #195505
Re: 34 inch tires
So I had the guy I sold my stock wheels and tires to weigh them and they were 59.2 lbs a piece. The new mrt rocky 33x10x16s with beadlocks are 59.1 lbs. #winning
I ended up getting a hell of a deal on my opinion at $1500 for the new wheels and tires as well.
post #14 of 41 Old June 2nd, 2018, 08:20 AM Thread Starter
Member #195505
Re: 34 inch tires
post #15 of 41 Old June 6th, 2018, 04:48 PM Thread Starter
Member #195505
Re: 34 inch tires
33s mounted.
http://i1378.photobucket.com/albums/...ps5c5gowia.jpg
brtnshrdr and VooDuuChild like this.
What have you done to your 570 today . FJK RZR 570 Specific Discussion 1052 March 19th, 2019 07:07 PM
Truck Style Tires Made for UTVs CentralArk_RZRbacks Wheels and Tires 589 November 27th, 2018 06:06 AM
29.5 Inch Tires on S 900 Jake Benson General RZR Discussion 8 September 4th, 2017 04:39 PM
Best 32 inch tires for Moab? Sahuarita_XP4 RZR XP Turbo 24 March 7th, 2017 04:42 AM
25 inch tires. bigred78 RZR 170 Specific Disccusion 6 November 19th, 2016 08:08 PM
