3236047 K-Seal Repair - Polaris RZR Forum - RZR Forums.net
RZR XP Turbo EPS Dynamix Edition Discuss the Polaris RZR XP Turbo EPS Dynamix Edition
post #1 of 12 Old April 30th, 2019, 06:26 PM Thread Starter
sandblster's Avatar
Member #46247
Having to replace the right front axle due to something hitting the guard and destroying the boot. Filling full of sand is not really recommenced. In process find the front diff seal has been leaking. By the Polaris parts list it take a 3236047 K-Seal Repair for $84.99. Say again, $85 for two seals???!!! Any one have a better price for front diff seals. 2018 Dynamix with 28 spline axle.
sandblster is online now
post #2 of 12 Old April 30th, 2019, 07:07 PM
dartersracing's Avatar
First Name: DONNY
My RZR: 2014 PACE Z1 1000
Member #19554
Feedback Score: 15 reviews
Re: 3236047 K-Seal Repair
partszilla 62.93
209-373-5336 DONNY DARTER
dartersracing is offline
post #3 of 12 Old April 30th, 2019, 08:27 PM
SNWMBL's Avatar
First Name: Caleb
Member #207521
Pull the seal and match it at your local bearing shop or google the size and order one. None of them are proprietary sizes and you can probably get them for $5-10 each. I order seals online all the time if the bearing shop doesnít have them.
2017 RZR XP4 1000
Alaska UTV Fab LLC
Instagram: alaska_utv_fab
FOR SALE
- Hunterworks secondary rollers, set of 2, $35 shipped
- Sinister Fabrication A pillar bungs, set of 2, $45 shipped
SNWMBL is offline
post #4 of 12 Old May 21st, 2019, 10:15 AM
Bullitt427's Avatar
Member #133409
Sure it's the seal and not the freeze plug in the hub?
2018 RZR XPT Walker Evans
2017 RZR S1K Black Stealth
2013 RZR 800 LE
Bullitt427 is offline
post #5 of 12 Old May 21st, 2019, 11:06 AM Thread Starter
sandblster's Avatar
Member #46247
Are you referring to the hub the axle spines slip into at the diff, and it has a freeze plug in the diff side?
If so. Not positive. Did not know there was a way for oil to get out other than the seal. Replaced seal. Will keep and eye on it and if it still leaks will have to dig deeper.
By the way. The seal kit is a kit with all the seals, o rings etc to rebuild the diff.
post #6 of 12 Old May 21st, 2019, 02:27 PM
Bullitt427's Avatar
Member #133409
Yes the splined area. It isn’t a solid piece but has a plug on the back that tends to leak.
2013 RZR 800 LE
post #7 of 12 Old May 27th, 2019, 01:20 PM Thread Starter
sandblster's Avatar
Member #46247
Yes the splined area. It isnít a solid piece but has a plug on the back that tends to leak.
Thanks for heads up on this. Will be watching it very close. Appreciate your time to point this out.
post #9 of 12 Old July 30th, 2019, 10:19 AM Thread Starter
sandblster's Avatar
Member #46247
Now the other side is leaking. If it is the freeze plugs leaking what is the fix?
post #10 of 12 Old July 30th, 2019, 10:26 AM
PaulK's Avatar
First Name: Paul
My RZR: 17 XP Turbo
Member #34432
View PaulK's Photo Gallery(2)
the correct way is to replace the drive hubs,, they have been upgraded to fix this issue
The new updated hub now has a brass plug with rubber seal.
PaulK is offline
post #11 of 12 Old July 30th, 2019, 10:31 AM Thread Starter
sandblster's Avatar
Member #46247
Thanks. Sounds expensive. This is when warranty should kick in and cover what is obvious a factory defect. Yes I know. Dreaming. But still they should.
post #12 of 12 Old July 30th, 2019, 01:46 PM
PaulK's Avatar
First Name: Paul
My RZR: 17 XP Turbo
Member #34432
got my leaks covered under warranty,,
here is a post with the NEW part # drive hub
https://www.rzrforums.net/general-rz...tput-hubs.html
PaulK is offline
Leaking Crankshaft Seal -- Repaired w/o Pulling Engine & Prevention MotionGranted General RZR Discussion 27 March 2nd, 2018 07:35 AM
Rear axle seal hellrazor General RZR Discussion 27 September 23rd, 2016 06:35 PM
water pump seal - design flaw!! coker6303 RZR 900 Engine 24 August 8th, 2012 10:15 AM
Seal install? medik418 Engine and Drivetrain 5 May 24th, 2012 10:51 AM
Water Pump Seal? Demoman Engine and Drivetrain 17 September 1st, 2011 11:27 PM
