Hard shift - Polaris RZR Forum - RZR Forums.net
RZR XP Turbo EPS Dynamix Edition Discuss the Polaris RZR XP Turbo EPS Dynamix Edition
 1Likes
post #1 of 16 Old November 18th, 2018, 04:04 PM Thread Starter
turbojoe's Avatar
Member #229913
View turbojoe's Photo Gallery(0)
Hard shift
All of a sudden I am having shift noise, Makes a loud pop when I first go from reverse to low or high. Like coming out of reverse or park.\
Any one else seen this, less than 500 miles. It was very cold though.
Thoughts?
turbojoe is offline
post #2 of 16 Old November 18th, 2018, 04:57 PM
RMR Man's Avatar
First Name: Steve
Member #11566
Re: Hard shift
Will it make the loud pop with the engine off, as in No Pressure on the drive line? Possibly a clutch-belt issue allowing a slight amount of pressure on the trans when it is running at idle?
RMR Man is offline
post #3 of 16 Old November 18th, 2018, 06:35 PM Thread Starter
turbojoe's Avatar
Member #229913
Re: Hard shift
Thanks Ill check it out
turbojoe is offline
post #4 of 16 Old December 12th, 2018, 08:54 PM
fanclutch83's Avatar
Member #91817
View fanclutch83's Photo Gallery(0)
Get a B&M lever pull gated shifter with hill killer If you sign up for their news letters you can get it shipped for $200. One of my best mods to take care of all the shifting aggervasions. No searching for the gear positions. No more noises.
fanclutch83 is offline
post #5 of 16 Old January 23rd, 2019, 10:03 PM
Bizill's Avatar
My RZR: 2016 XP 1000
Member #261600
View Bizill's Photo Gallery(0)
Re: Hard shift
Can you tell me more about the signing up to get it for $200 shipped? They send you a coupon code to use on anything or was it a particular sale?
Bizill is offline
post #6 of 16 Old January 25th, 2019, 06:11 PM
Member #91817
Have not checked if they are still doing it, this was back in September but yeah. Sign up for their newsletter and they send a 15% off coupon to the email you used to sign up with.
post #7 of 16 Old January 25th, 2019, 09:09 PM
Bizill's Avatar
Member #261600
Re: Hard shift
They said it ended last year...
Bizill is offline
post #8 of 16 Old January 25th, 2019, 09:25 PM
Chedox's Avatar
Member #253553
View Chedox's Photo Gallery(0)
Re: Hard shift
It could be clutch problems,
Transmisión alignment or engine crankshaft bar problem.
Check if your secondary clutch still work if you shift P or N.
I have the same problem in mine. I have change already complete transmission and the problem still there.
https://www.rzrforums.net/rzr-xp-tur...-new-post.html
Check my post.
Thanks.
Chedox is offline
post #9 of 16 Old February 11th, 2019, 08:19 PM
rmharvey's Avatar
Member #73380
View rmharvey's Photo Gallery(0)
Re: Hard shift
From the day I bought my 2018 Dynamix last January I had a very hard shift. Went to 3 different dealers that told me it just had to be broken in - wrong! I also noticed that my secondary was constantly turning (in P & N). Through research I found out that it was due to an alignment problem caused by Polaris's great snap ring idea. I used the snap ring deletion kit from Aftermarket Assassins and no more hard shift and no more secondary turning when it is not supposed to. I have about 250 miles on it since the change. Unfortunately the alignment problem caused by their snap ring solution is a common problem with the turbo's.
ocrzrs likes this.
rmharvey is offline
post #10 of 16 Old February 12th, 2019, 02:16 AM
CB-BLR
chris_bullock's Avatar
My RZR: 2018 XP Dynamix
Member #66283
View chris_bullock's Photo Gallery(0)
Re: Hard shift
What he said ^
Chris
chris_bullock is offline
post #11 of 16 Old February 23rd, 2019, 08:44 AM
Poorboy1957's Avatar
Member #262908
View Poorboy1957's Photo Gallery(0)
Re: Hard shift
The AA delete did help, also removed clutch put the belt in clutch pulled tight and measured belt in clutch. There was .082K between the belt and sleeve after pushing belt to one side. Removed the spacer from clutch cut .055k from the counter bore inside spacer then had to cut spacer down so it would tighten down on counter bore and not ride on bearing. now belt sits in clutch true locks up quicker and shifts so easy. This bike has always been so hard to shift you could not feel what gear you was in you had to look at display see if you was in gear you wanted to be in. Very smooth now no pressure on shifter
Poorboy1957 is offline
post #12 of 16 Old April 15th, 2019, 09:36 PM
rmharvey's Avatar
Member #73380
Re: Hard shift
Another 400 miles after the Snap Ring Deletion Kit and zero problems! I'm not a salesman but this simple fix has given a lot of enjoyment!
rmharvey is offline
post #13 of 16 Old April 16th, 2019, 04:26 PM Thread Starter
turbojoe's Avatar
Member #229913
Re: Hard shift
Great Info, many ppl never follow up after the orig post.
turbojoe is offline
post #14 of 16 Old April 30th, 2019, 07:08 PM
wheelin-Roy's Avatar
First Name: Roy
My RZR: 2018 Dynamix 1000 Turbo
Member #24858
View wheelin-Roy's Photo Gallery(0)
Re: Hard shift
I bought a B&M shifter and installed it on my 2018 Dynamix. Now I can't get car in Park. I checked and everything is tight and nothing in the way. I took cover off and it showed i was in park, put cover back on and no park. I pulled boot up and looked for anything that it might be hitting. Saw nothing wrong or out of place. Never seen anything like it and it's driving me crazy. I know what your thinking something must be in the way but was checked by a couple of guys. Anyone have any suggestions on what i can go to get it in park. I'm afraid to trailer it without it being in park. Summer is coming Help Please.
Thanks Roy
If you aren't the lead dog the view never changes
wheelin-Roy is offline
post #15 of 16 Old May 1st, 2019, 04:40 AM
RZR_Joe's Avatar
Member #23438
Feedback Score: 6 reviews
Re: Hard shift
Thanks Roy
You need to adjust the shift linkage.
RZR_Joe is online now
Hard to shift CALIGOOSE General RZR Discussion 3 July 20th, 2017 07:41 AM
Clutch Shift Speed Explained Hunterworks Hunterworks 33 July 12th, 2016 10:27 AM
hard to shift from park rich51 RZR 800 Specific Discussion 17 September 7th, 2014 05:34 PM
transmission hard to shift after its been rode pawngod Engine and Drivetrain 6 March 26th, 2012 04:07 PM
Rzr hard to shift!!! mikebar4 General RZR Discussion 37 June 21st, 2011 11:53 AM
