Shock therapy spring kit - Polaris RZR Forum - RZR Forums.net
RZR XP Turbo EPS Dynamix Edition Discuss the Polaris RZR XP Turbo EPS Dynamix Edition
 5Likes
post #1 of 16 Old January 17th, 2018, 10:18 AM Thread Starter
Palm70's Avatar
Member #222954
View Palm70's Photo Gallery(0)
I just competed the install. Took it for a ride. The live valve is stuck at the 10 setting in all modes. It will change from comfort to sport ect but the settings that are suppose to change with the mode donít change. Stuck on 10 the firm setting. Did anyone have this problem after installing spring kit?
Palm70 is offline
post #2 of 16 Old January 17th, 2018, 10:23 AM Thread Starter
Palm70's Avatar
Member #222954
Sorry I forgot to plug in 1 sensor! Haha
Palm70 is offline
post #3 of 16 Old January 17th, 2018, 10:25 AM Thread Starter
Palm70's Avatar
Member #222954
If anybody has any questions on the install let me know.
Palm70 is offline
post #4 of 16 Old January 17th, 2018, 12:48 PM
RedShadow's Avatar
Member #198041
View RedShadow's Photo Gallery(0)
Re: Shock therapy spring kit
Did you have any issues getting the sensors unplugged on the top of the shocks? I do not want to break anything. I have the Spring Threapy kit also. Thanks for any advice to make the installation go smooth.
RedShadow is offline
post #5 of 16 Old January 17th, 2018, 03:47 PM Thread Starter
Palm70's Avatar
Member #222954
No your good. Just press the piece in middle down and pull them out. You wonít hurt anything. Their is a zip tie you will have to cut to break it away from the shock. Once you pull the sensor plug out you will see it.
RedShadow likes this.
Palm70 is offline
post #6 of 16 Old January 23rd, 2018, 08:33 PM
kmzeidler's Avatar
First Name: Kevin
Member #64019
View kmzeidler's Photo Gallery(0)
Hey plugging it in always helps! LOL
www.ConcordPolaris.com
Polaris since 93' -Custom UTV Builds and Accessories
Instagram: ConcordPolaris_UTV
kmzeidler is offline
post #7 of 16 Old September 11th, 2018, 10:04 AM
whitelightning800S's Avatar
My RZR: 2018 XP1000 Turbo Dynamix
Member #82332
View whitelightning800S's Photo Gallery(0)
so to switch over sprigs, Just unbolt the shock like you would, disconnect whatever it is from the top where you see something connected to the shock and pull out and change the springs over?
whitelightning800S is offline
post #8 of 16 Old September 11th, 2018, 10:59 AM
sandblster's Avatar
My RZR: 2018 Dynamix
Member #46247
Yep! That's about it. Very worth while project.
sandblster is offline
post #9 of 16 Old September 11th, 2018, 11:05 AM
ElmoEOD's Avatar
Member #30632
View ElmoEOD's Photo Gallery(0)
Than repeat about 5 time or so till you get the ride heigth adjusted to 14" in front and 13.5" in rear.... trust me, it makes a huge difference
2014 Titanium - sold
2018 Dynamix - just starting
ElmoEOD is offline
post #10 of 16 Old September 11th, 2018, 11:13 AM
sandblster's Avatar
Member #46247
Front is easy to adjust on. Take weight off, unlock nuts, grab spring and twist. Rear, more work, remove the big air duct's, use a spanner wrench and adjust.
post #11 of 16 Old September 14th, 2018, 02:59 PM
gpr
gpr's Avatar
Member #75181
View gpr's Photo Gallery(0)
How did everyone like the Shock Therapy Spring Kit? does it significantly smooth out the ride? I'd like to do something to take out the chop/roughness on trails. Was debating their springs, but wasn't sure how much they would help, or if valving would be better.
Where are you measuring the ride height from? just to the lowest spot on the frame in the front and rear? Or to the center of the control arm bolts?
gpr is offline
post #12 of 16 Old September 14th, 2018, 03:33 PM
sandblster's Avatar
Member #46247
The spring kit helps a lot on 2018 Dynamix and it had a good ride to start with. Will do valving next.
Measure from the bottom of frame.
ElmoEOD likes this.
post #13 of 16 Old September 18th, 2018, 08:30 AM
Idaho308's Avatar
Member #258642
View Idaho308's Photo Gallery(0)
I installed the Shock Therapy Dual Rate Spring Kit on our 2018 RZR Turbo Dynamix. It was an easy install and the ride is much better.
I would have liked to test it a bit more, but our RZR transmission appears to have grenaded itself after 20 hours of easy driving...no jumping, no abuse, nothing just sounded like a blender going off as we backed it off the trailer...oh, and the front diff has been leaing fluid from day one. 2-months old, 200 miles, 20 hours and all we do is drive easy on the trails.
Idaho308 is offline
post #14 of 16 Old September 18th, 2018, 08:36 AM
sandblster's Avatar
Member #46247
Did you change out the oil in the diff? I always run a bit and change all fluids over to Amsoil. Suspect you had a defective build that should be taken care of if you have a good dealer. Sorry it failed on you, but better backing off trailer then 50 miles out. I really, really like my Dynamix and the shock therapy springs. Next month hope to send them in for valve work.
Idaho308 likes this.
post #15 of 16 Old September 18th, 2018, 08:46 AM
Idaho308's Avatar
Member #258642
I did not change any oils, but did add some front diff fluid...maybe an ounce or two. The RZR is under warranty and is in the shop now.
My wife said the same thing as you about being thankful it happened coming off the trailer rather than way out in BFE! I'm thankful of that as well.
Idaho308 is offline
Eibach Pro UTV Stage 2 Spring Kit rynomx785 RZR XP 4 Turbo 46 September 25th, 2018 06:23 PM
Shock Therapy confusion DaveT1 General RZR Discussion 3 May 28th, 2017 09:19 AM
Shock revalve vs spring kit Cubhunter2297 RZR S 900 6 February 5th, 2017 05:09 PM
Shock therapy 900 trail spring kit 6.7powerstroke Polaris RZR Parts For Sale 2 January 31st, 2017 06:24 PM
Shock therapy full spring kit winstonblu22 RZR XP 1000 4 January 4th, 2016 06:51 AM
