Crossthreaded walker evans right rear shock:( - Polaris RZR Forum - RZR Forums.net
post #1 of 4 Old March 14th, 2017, 05:23 AM Thread Starter
cincykid's Avatar
Member #32627
View cincykid's Photo Gallery(0)
So, while working on installing my new stage 4 kits from shock therapists, while threading the ring to the top of the shock, got stuck, then looks to be cross threaded. Need to ship In-N-Out to get repaired or just buy a new right rear shock with no springs. Suggestions? This sucks. I wish there was someone in Cincinnati that could fix it.
cincykid is offline
post #2 of 4 Old March 14th, 2017, 02:12 PM
JXsedan's Avatar
First Name: Joe
My RZR: 2013 Jagged X 900HO
Member #94338
View JXsedan's Photo Gallery(0)
Re: Crossthreaded walker evans right rear shock:(
Did it cross near the top of the threads or down by the spring? I would look for a new nut, cut that one off, use a thread file to clean up the threads. Then, long as nut is not on the bad spot when the preload is set I wouldn't worry about it.
JXsedan is offline
post #3 of 4 Old March 14th, 2017, 05:32 PM
RFish's Avatar
Member #56342
View RFish's Photo Gallery(0)
Ya theres a few threads on this. . . . I ended up getting Warrenty on mine cuz happened in first couple months. . . They now come with anodized black looking nuts because of this. Does yours have those? You have to make sure it so so so absolutely cleaned out before u try and turn anything. Not sure if anyone makes a 2 piece nut u can clamp on after cutting yours off. If not you have to disassemble the whole shock/oil/pressure I'm pretty sure to thread it on from the top.
RFish is offline
post #4 of 4 Old March 15th, 2017, 05:59 AM
PaulK's Avatar
First Name: Paul
My RZR: 17 XP Turbo
Member #34432
View PaulK's Photo Gallery(2)
Shock thearpy sells a 2 piece nut for the 2.5 Walker Shock
Walker 2.5" Two Piece Pre-Load Collar - Shock Therapy, LLC
PaulK is offline
resprung and valved walker Evans shocks for polaris rzr 1000 davidsilver818 Polaris RZR Parts For Sale 5 July 13th, 2017 07:05 AM
Walker Evans shock rebuild R_Harris RZR 4 Specific Discussion 0 September 26th, 2016 04:57 PM
Walker Evans Shock Eyeball Loose Maxum02 Suspension 2 May 6th, 2016 06:14 PM
Walker Evans shock failure? Any help? Wateroutlaw RZR XP 1000 5 March 21st, 2016 09:28 PM
