Trailing arm mud/rock flaps for HCR arms? - Polaris RZR Forum - RZR Forums.net
 6Likes
  • 1 Post By ShakyDog
  • 1 Post By moneypit
  • 1 Post By NateSS415
  • 3 Post By NateSS415
post #1 of 13 Old December 12th, 2015, 11:07 AM Thread Starter
Site Founder
Brian B's Avatar
First Name: Brian
My RZR: XP Turbo
Member #2
View Brian B's Photo Gallery(0)
Has anyone produced a mud flap kit for HCR Racing trailing arms?
KOH-BITD#1911
Terracross #88
My Racing Page
Brian B is offline
post #2 of 13 Old December 12th, 2015, 02:37 PM
evantwheeler's Avatar
First Name: Evan
My RZR: 2015 XP1000
Member #80253
View evantwheeler's Photo Gallery(1)
Re: Trailing arm mud/rock flaps for HCR arms?
I contacted HCR and they didn't have any input as to whether any of the currently available aftermarket kits would work or not. There are a few kits out there, but I plan to get a set of these and modify as necessary to make them work.
RZR XP1000 Suspension & Chassis Trailing Arm Mud Flaps - Lone Star Racing - $135.00
evantwheeler is offline
post #3 of 13 Old December 13th, 2015, 08:33 AM Thread Starter
Site Founder
Brian B's Avatar
First Name: Brian
My RZR: XP Turbo
Member #2
The LSR flaps do not fit the HCR arm. FYI
KOH-BITD#1911
Terracross #88
My Racing Page
Brian B is offline
post #4 of 13 Old December 17th, 2015, 10:54 AM Thread Starter
Site Founder
Brian B's Avatar
First Name: Brian
My RZR: XP Turbo
Member #2
Bump
KOH-BITD#1911
Terracross #88
My Racing Page
Brian B is offline
post #5 of 13 Old February 1st, 2016, 12:30 PM Thread Starter
Site Founder
Brian B's Avatar
First Name: Brian
My RZR: XP Turbo
Member #2
Anyone?
KOH-BITD#1911
Terracross #88
My Racing Page
Brian B is offline
post #6 of 13 Old December 29th, 2018, 09:09 PM
NateSS415's Avatar
First Name: Nate
My RZR: RZR XP4T Dynamix Edition, RZR 1000 S, and General 1000
Member #207089
View NateSS415's Photo Gallery(0)
Hey guys, I know this is thread has been inactive for a while but I came up with a trailing arm guard/mud flap setup that uses the HCR sway bar mounting location. I am in the testing phase right now to make sure everything fits and lines up correctly, and then once I produce some metal prototypes I will probably be testing them to check durability. Attached are some pictures of what I have planned along with some pictures of my CAD model. FYI I am a full-time college student so I'm doing this in my spare time over break so I will try and keep posting updates of my progress.
Below are 3D printed prototypes to check tolerances and start the design of the mudflap itself. I'm sure many of you know, but the inside of the trailing arm gets peppered with rocks and other debris, so I wanted to make sure the flap was both long and wide enough to prevent this from happening.
Here is what I plan the mudflap to look like. I plan on using polyethylene resin mudflap which is pretty strong, so I don't have any worries about the lack of support on the farther edges of the mudflap. I also allowed space for the bolt along with the brake line that runs through this area. A longer sway bar bolt may be needed in order to accommodate for the added material.
I've spent a lot of time measuring and design this and am very proud of how it turned out for the first time "reverse engineering" a part and trying to make everything fit and line up. If you have any comments or concerns about it let me know, and I'll try and keep everyone updated on the progress so far. Going to see if any local shops to me like HMF or EMP would like to help out with this project!
NateSS415 is offline
post #7 of 13 Old January 2nd, 2019, 09:02 AM
ShakyDog's Avatar
My RZR: 2013 Jagged X
Member #41826
View ShakyDog's Photo Gallery(0)
I like your design and it looks to be easily adaptable to just about any brand trailing arm.
Steve
NateSS415 likes this.
ShakyDog is offline
post #8 of 13 Old January 2nd, 2019, 09:04 AM
NateSS415's Avatar
First Name: Nate
Member #207089
Steve
Thanks, I may have to modify/reinforce some areas depending on what i find with testing but I wanted to make it simple. They are relatively small pieces and one I get them laser cut out of steel I believe they will be strong enough.
post #9 of 13 Old January 3rd, 2019, 07:26 PM
moneypit's Avatar
My RZR: 17 XPT4, 14 xp1k
Member #2419
View moneypit's Photo Gallery(0)
interested in a few sets. let me know
14 xp1k black pearl
HCR/FUTV/warn/SSV/Beard's/DJ/tribal's/Rigid/PA doors/Isota/axia/MS lok2/Motovators
17 XPT4 Cruiser black
HCR/Motovators/MSA lok2/BD lighting/SSV/PA doors/Beard seats/Tribal's/Isota/FUTV
moneypit is offline
post #10 of 13 Old January 3rd, 2019, 07:29 PM
NateSS415's Avatar
First Name: Nate
Member #207089
Will do! Talked with a local company to get some prototypes made up for testing. Should be made in a few weeks so I will post updates on the progress.
moneypit likes this.
post #11 of 13 Old January 9th, 2019, 10:49 AM
NateSS415's Avatar
First Name: Nate
Member #207089
Just wanted to post an update on the prototype. I was able to get the guard cut out and will be testing shortly after the brackets come in. They are looking good!
post #12 of 13 Old January 10th, 2019, 07:03 PM
moneypit's Avatar
Member #2419
nice!
14 xp1k black pearl
moneypit is offline
post #13 of 13 Old February 9th, 2019, 12:40 PM
NateSS415's Avatar
First Name: Nate
Member #207089
I got the first set installed. Clearance looks good on everything and as you can see it protects everything that previously got destroyed by rocks. I'll be seeing how these hold up and if any changes need to to be made.
Super ATV trailing arm toe in. sidlives RZR XP 900 12 January 22nd, 2016 10:32 AM
900xp trailing arm and upper radius rod F/S!!!! travisH3 Polaris RZR Parts For Sale 6 December 13th, 2015 03:38 PM
WTB: XP 1000 Trailing Arm kyle_n Polaris RZR Parts For Sale 1 November 30th, 2015 01:13 PM
XP900 Trailing arms and upper control arms-FREE jmarx82 Polaris RZR Parts For Sale 3 November 27th, 2015 01:10 PM
