900 Xp rear wheels toe out - Polaris RZR Forum - RZR Forums.net
post #1 of 7 Old September 13th, 2015, 07:17 PM Thread Starter
Artate78's Avatar
First Name: Aaron
My RZR: 2012 800s 2012 xp900
Member #57733
View Artate78's Photo Gallery(0)
I have a 2012 Xp 900 it has a 2" bracket lift. The rear tires are toed in at the rear. The front of the rear tire is inline with the front tire . If I pull a string from front tire to rear tire. It touches the front of the rear tire at the same time the string gets square on the front tire. The sring shows rear tire 1-1/2" in at the rear of tire. I bought this rzr with bad motor. I took rear suspension apart to pull motor and Trans same day I bought it. I didn't notice the tire toe out then but it could have been. Getting every thing back together now and trying to get this figured out. Any one Sean this before?
Artate78 is offline
post #2 of 7 Old September 25th, 2015, 11:08 PM
64tbolt's Avatar
First Name: Glen
My RZR: 2011 900xp
Member #83012
View 64tbolt's Photo Gallery(0)
Re: 900 Xp rear wheels toe out
is it toed out or is the rear wider than the front. I think it is and would cause the string to not work. I could be wrong but worth checking.
64tbolt is offline
post #3 of 7 Old September 25th, 2015, 11:23 PM
Fimea's Avatar
First Name: Rick
My RZR: 2015 XP1000, 2014 XP4K, 2011 XP900
Member #29192
View Fimea's Photo Gallery(0)
My Xp900 did the same thing, and the dealer told me he could see nothing wrong with the arms, and he couldn't adjust them either. My extended warranty wouldn't cover it, and referred me to my insurance company, even though I've never been in a crash! I ended up buying a new pair of arms to get the alignment correct.
2013 Ram 2500 & 3500 dually, diesel, crew cab
2002 Ford F-250 7.3L diesel, crew cab
2004 Wanderer Toyhauler
2015 RZR XP1000 Voodoo Blue
2014 XP4
2011 RZR XP900 LE White Lightning
2008 LTR450, 2004 YFZ450,2003 YFS200
Fimea is offline
post #4 of 7 Old November 21st, 2015, 11:16 AM
DCS
DCS's Avatar
Member #80717
View DCS's Photo Gallery(0)
make sure the string is layed out in a perfect square. Don't just wrap a string around the machine. Really pay attention to the string width at the rear of front tires and front of rear tires. Has to be exactly the same numbers there or you'll get false numbers.
DCS is offline
post #5 of 7 Old November 23rd, 2015, 11:23 AM
rzrguy83's Avatar
My RZR: 2012 900 XP
Member #75830
View rzrguy83's Photo Gallery(0)
I just noticed I have a similar problem when cleaning up the RZR.
The driver rear tire was definitely sicking out more at the front than the rear.
Using a straightedge I determined the trailing arm is bent.
Plan to straighten it in the press tonight.
rzrguy83 is offline
post #6 of 7 Old January 13th, 2016, 04:46 PM
64tbolt's Avatar
First Name: Glen
My RZR: 2011 900xp
Member #83012
Got me to thinking so I went out & measured mine. Outside tire to tire my front is wider than the rear by an inch or so. Stock wheels & oem tires.
64tbolt is offline
post #7 of 7 Old December 25th, 2018, 06:14 PM
serpa4's Avatar
First Name: Lorne
My RZR: 2010 RZR 800 Trail
Member #259000
View serpa4's Photo Gallery(0)
Old post,but I have 2 inches of tow out on my 2013 rear (stock). Where did your trailing arms bend? What should be straight so I can lay a straight edge along it?
Thanks!!
serpa4 is offline
Rear wheels cersos RZR 800 Specific Discussion 9 March 4th, 2015 10:03 PM
rzr14" wheels, bighorn tires, front/rear bumpers, winch, fog lights, rear rack extend ingeniusone7 Want to Buy 10 June 17th, 2014 08:22 PM
Rear Wheel Camber Not The Same on Rear Wheels JDRM General RZR Discussion 4 November 28th, 2013 07:00 AM
Rear RZR 4 wheels prbishop12 Polaris RZR Parts For Sale 1 June 8th, 2011 10:30 AM
Looking for Rzr S rear wheels. Rob4092xx Wheels and Tires 0 April 1st, 2009 12:39 AM
