Longer trailing arms ( extended wheel base) - Polaris RZR Forum - RZR Forums.net
post #1 of 9 Old January 2nd, 2015, 05:16 PM Thread Starter
rockcrawlerZJ's Avatar
Member #39177
View rockcrawlerZJ's Photo Gallery(0)
I was reading about the HCR long travel kit and I like that it adds 2" of wheelbase in the rear. I would like to know how this is obtained. Are they just making longer trailing arms or are the modifying the radius rod mounting in order to keep the radius rods straight? If someone were to build a set of trailing arms that were 2" longer, but kept the radius rod mounting at the frame in the stock location ( and had a heim joint at the hub) would there be any binding? Very interested in getting a couple extra inches of wheelbase in the rear.
rockcrawlerZJ is offline
post #2 of 9 Old January 2nd, 2015, 05:50 PM
colter2's Avatar
First Name: Colt
My RZR: This one
Member #69451
View colter2's Photo Gallery(0)
Re: Longer trailing arms ( extended wheel base)
Subscribed. I would love to have some more info on this as well. ORB built some high clearance "+2 trailing arms" but they are no longer on their site
colter2 is offline
post #3 of 9 Old January 3rd, 2015, 09:51 AM
223
223's Avatar
Member #74747
View 223's Photo Gallery(0)
just use high mis heims and im sure it would work. just mock it up and cycle it. I don't know about axle problems though. it would be hard to notice only 2 inches longer
223 is offline
post #4 of 9 Old January 5th, 2015, 08:16 AM Thread Starter
Member #39177
As I thought about, you would have to use heims at both end of the radius rod (hopefully there would be no interference with the frame or hub) if you didn't offset the mounting location at the frame. I am not sure about the axles either. I have 1.5" forward a-arms and have had ZERO axles issues with the added length. I can see a great improvement on the 800s when adding 1.5 front and 1.5 rears (3" total) over the stock length. I would assume one would see the same benefits from a 900 that was also 3-3.5" longer. I may toy with the idea more. Just wasnt sure exactly how HCR obtained their added wheel base.
post #5 of 9 Old August 21st, 2017, 12:03 PM
FitzRZR's Avatar
My RZR: 08 RZR w/ S conversion
Member #84515
View FitzRZR's Photo Gallery(0)
post from the past, but did anybody ever add length to trailing arms? shock location would have to change and heims are needed on radius rods, but just curious why no one ever did this.
2013 RZR XP900
FitzRZR is offline
post #6 of 9 Old August 23rd, 2017, 08:29 AM
Ruko's Avatar
First Name: Rob
My RZR: 2013 900XP W.E.
Member #47257
View Ruko's Photo Gallery(0)
https://www.rzrforums.net/rzr-xp-900/...pension-3.html
Not sure what ever became of these or if they are still available but they are no longer listed on their website.
Ruko is offline
post #7 of 9 Old January 6th, 2019, 09:33 PM
Mr.shocker's Avatar
Member #141017
View Mr.shocker's Photo Gallery(0)
If your still looking for the answer to the question they do move the wheel back. When I got the kit I ordered the box radius arms.
The frame side of radius are a bushing set up like the front a arms and the wheel side has heims
Uses stock location on the frame side.
Donít like the boxed set up with the bushing in frame side because when bolting the trailing arm back on I always have to pry the radius arm back to get it in the knuckle
Mr.shocker is offline
post #8 of 9 Old January 7th, 2019, 05:20 AM
todztoyz's Avatar
My RZR: 14 xp1k
Member #193809
View todztoyz's Photo Gallery(0)
I have some swingarm gussets to weld in soon and have been contemplating adding 1-2" to the length. This does not seem that common so I'm wondering about the axles. Who has added inches in the rear....any axle bind? Thank you for any help on this.
todztoyz is offline
post #9 of 9 Old January 7th, 2019, 06:58 AM
Mr.shocker's Avatar
Member #141017
I havenít had any issues with axle bind at all. I did do the 570 upgrade on the rear axles to help in strength
Arched A Arms, Radius Rods, & High Clearance Trailing Arms GAZ69OK RZR XP 4 900 Specific Discussion 65 January 13th, 2015 04:36 PM
Special Carriers mfg. Check out our a-arms,trailing arms&radius rods SpecialCarriersmfg RZR XP 900 1 May 7th, 2014 07:44 PM
Highlifter lift kit, radius arms,trailing arms, and 30x10x14 tires for sale RZRguy52 Polaris RZR Parts For Sale 10 February 23rd, 2014 07:22 PM
Super ATV forward A-arms for more wheel base?? rardoin Suspension 4 May 17th, 2011 08:25 AM
