Front Drivers Side Rub - Polaris RZR Forum - RZR Forums.net
post #1 of 5 Old June 23rd, 2014, 11:54 AM Thread Starter
culvert's Avatar
My RZR: 2011 rZr XP 900
Member #11469
View culvert's Photo Gallery(0)
Canada Front Drivers Side Rub
Hey Guys.
Tried looking for similar posts but havent found any yet.
Just picked up a used 2011 Rzr Xp. Checked it over good & didnt see any issues untill first ride out. I running a set a 28" Zillas, no lift and now found that the drivers side tire hits the fender under compression. I mearsured C-C of rims & have 82.5" on passengers side & 81" on driver side. So drivers side is pushed back 1.5"
Frame looks good, all mounts look good, A Arms look good. What is the problem???
culvert is offline
post #2 of 5 Old June 23rd, 2014, 08:05 PM Thread Starter
culvert's Avatar
Member #11469
Re: Front Drivers Side Rub
Pressured washed the machine & checked it all out again. It ended up being a bent A Arm.
Now the worst is no stock available for 4-6 wks locally. Checking on the best way to go next. Lift kit & arms or just Clearance arms???
culvert is offline
post #3 of 5 Old June 23rd, 2014, 08:11 PM
Sporter's Avatar
First Name: Steve
My RZR: 2012 xp 900 4
Member #40617
View Sporter's Photo Gallery(0)
Also check the frame to see if any of the powder coat is cracked.....had the same issue bent a arm but also bent the frame a bit. On another note I have a set of a arms for a 900 where are you located just took them off
2012 XP 4 900 with a Alba 935mm BB and Alba stage 2
2013 F350 Superduty Platinum DPF delete , 4" turbo back , H&S tuner with SPE 550hp tuning , stage 3 tranny tuning
2013 F150 FX4 Ecoboost stock with some wheels and tires and a load of other toys
Sporter is offline
post #4 of 5 Old June 23rd, 2014, 08:12 PM
Sporter's Avatar
First Name: Steve
Member #40617
ahhhh Cold Lake , I'm in Red Deer
Sporter is offline
post #5 of 5 Old July 28th, 2014, 08:49 PM
jw3
jw3's Avatar
Member #24371
View jw3's Photo Gallery(0)
Have you thought about foward a arms? They might be easier to lay hands on
jw3 is offline
WTB 08-10 drivers side front bearing carrier motohead446 Polaris RZR Parts For Sale 0 November 19th, 2011 09:06 PM
WTB: Lower drivers side front a-arm. beermanjoe Want to Buy 4 September 28th, 2009 07:53 PM
WTB Front Drivers Side 4x4 Hub. Hookie Polaris RZR Parts For Sale 5 July 11th, 2009 02:37 PM
WTB Front Drivers Side 4x4 Hub. Hookie Want to Buy 1 July 10th, 2009 05:35 PM
Drivers side front axle, and cv's trevorsride Want to Buy 0 July 21st, 2008 04:07 PM
